[MOAB-dev] buildbot failure in moab-cub-par-tru: failed shell test install
Vijay S. Mahadevan
vijay.m at gmail.com
Tue Sep 17 03:03:57 CDT 2013
If no one is using pointsearch anymore, I vote we scratch this tool and its
dependencies. They break a lot of tests, have compiler warnings, are not a
useful API anymore and trigger faults with --enable-tools anyway. Now that
the new Coupler design is somewhat mature, any functionality that this tool
provided should be alternately available in the new interface.
Thoughts ?
Vijay
On Tue, Sep 17, 2013 at 2:59 AM, <moab-dev at mcs.anl.gov> wrote:
> Fathom <http://gnep.mcs.anl.gov:8010/>: moab-cub-par-tru<http://gnep.mcs.anl.gov:8010/builders/moab-cub-par-tru>build
> #221 <http://gnep.mcs.anl.gov:8010/builders/moab-cub-par-tru/builds/221> *
> Results:*failed shell test install *Buildslave:*gnep *Revision:*None Log
> Excerpt
> /home/fathom/3rdparty/mpich2/mpich2-1.2.1/gcc/include/mpicxx.h:384: warning: unused parameter ‘oldtype’
> /home/fathom/3rdparty/mpich2/mpich2-1.2.1/gcc/include/mpicxx.h:384: warning: unused parameter ‘keyval’
> /home/fathom/3rdparty/mpich2/mpich2-1.2.1/gcc/include/mpicxx.h:384: warning: unused parameter ‘ex’
> /home/fathom/3rdparty/mpich2/mpich2-1.2.1/gcc/include/mpicxx.h:384: warning: unused parameter ‘attr_in’
> /home/fathom/3rdparty/mpich2/mpich2-1.2.1/gcc/include/mpicxx.h:384: warning: unused parameter ‘attr_out’
> /home/fathom/3rdparty/mpich2/mpich2-1.2.1/gcc/include/mpicxx.h:386: warning: unused parameter ‘type’
> /home/fathom/3rdparty/mpich2/mpich2-1.2.1/gcc/include/mpicxx.h:386: warning: unused parameter ‘keyval’
> /home/fathom/3rdparty/mpich2/mpich2-1.2.1/gcc/include/mpicxx.h:386: warning: unused parameter ‘attr’
> /home/fathom/3rdparty/mpich2/mpich2-1.2.1/gcc/include/mpicxx.h:386: warning: unused parameter ‘ex’
> /home/fathom/3rdparty/mpich2/mpich2-1.2.1/gcc/include/mpicxx.h:388: warning: unused parameter ‘oldtype’
> /home/fathom/3rdparty/mpich2/mpich2-1.2.1/gcc/include/mpicxx.h:388: warning: unused parameter ‘keyval’
> /home/fathom/3rdparty/mpich2/mpich2-1.2.1/gcc/include/mpicxx.h:388: warning: unused parameter ‘ex’
> /home/fathom/3rdparty/mpich2/mpich2-1.2.1/gcc/include/mpicxx.h:1451: warning: unused parameter ‘oldcomm’
> /home/fathom/3rdparty/mpich2/mpich2-1.2.1/gcc/include/mpicxx.h:1451: warning: unused parameter ‘keyval’
> /home/fathom/3rdparty/mpich2/mpich2-1.2.1/gcc/include/mpicxx.h:1451: warning: unused parameter ‘ex’
> /home/fathom/3rdparty/mpich2/mpich2-1.2.1/gcc/include/mpicxx.h:1451: warning: unused parameter ‘attr_in’
> /home/fathom/3rdparty/mpich2/mpich2-1.2.1/gcc/include/mpicxx.h:1451: warning: unused parameter ‘attr_out’
> /home/fathom/3rdparty/mpich2/mpich2-1.2.1/gcc/include/mpicxx.h:1453: warning: unused parameter ‘comm’
> /home/fathom/3rdparty/mpich2/mpich2-1.2.1/gcc/include/mpicxx.h:1453: warning: unused parameter ‘keyval’
> /home/fathom/3rdparty/mpich2/mpich2-1.2.1/gcc/include/mpicxx.h:1453: warning: unused parameter ‘attr’
> /home/fathom/3rdparty/mpich2/mpich2-1.2.1/gcc/include/mpicxx.h:1453: warning: unused parameter ‘ex’
> /home/fathom/3rdparty/mpich2/mpich2-1.2.1/gcc/include/mpicxx.h:1455: warning: unused parameter ‘oldcomm’
> /home/fathom/3rdparty/mpich2/mpich2-1.2.1/gcc/include/mpicxx.h:1455: warning: unused parameter ‘keyval’
> /home/fathom/3rdparty/mpich2/mpich2-1.2.1/gcc/include/mpicxx.h:1455: warning: unused parameter ‘ex’
> /home/fathom/3rdparty/mpich2/mpich2-1.2.1/gcc/include/mpicxx.h:1884: warning: unused parameter ‘oldwin’
> /home/fathom/3rdparty/mpich2/mpich2-1.2.1/gcc/include/mpicxx.h:1884: warning: unused parameter ‘keyval’
> /home/fathom/3rdparty/mpich2/mpich2-1.2.1/gcc/include/mpicxx.h:1884: warning: unused parameter ‘ex’
> /home/fathom/3rdparty/mpich2/mpich2-1.2.1/gcc/include/mpicxx.h:1884: warning: unused parameter ‘attr_in’
> /home/fathom/3rdparty/mpich2/mpich2-1.2.1/gcc/include/mpicxx.h:1884: warning: unused parameter ‘attr_out’
> /home/fathom/3rdparty/mpich2/mpich2-1.2.1/gcc/include/mpicxx.h:1886: warning: unused parameter ‘win’
> /home/fathom/3rdparty/mpich2/mpich2-1.2.1/gcc/include/mpicxx.h:1886: warning: unused parameter ‘keyval’
> /home/fathom/3rdparty/mpich2/mpich2-1.2.1/gcc/include/mpicxx.h:1886: warning: unused parameter ‘attr’
> /home/fathom/3rdparty/mpich2/mpich2-1.2.1/gcc/include/mpicxx.h:1886: warning: unused parameter ‘ex’
> /home/fathom/3rdparty/mpich2/mpich2-1.2.1/gcc/include/mpicxx.h:1888: warning: unused parameter ‘oldwin’
> /home/fathom/3rdparty/mpich2/mpich2-1.2.1/gcc/include/mpicxx.h:1888: warning: unused parameter ‘keyval’
> /home/fathom/3rdparty/mpich2/mpich2-1.2.1/gcc/include/mpicxx.h:1888: warning: unused parameter ‘ex’
> In file included from point_search.cpp:25:
> ../src/moab/point_locater/tree/bvh_tree.hpp: In member function ‘typename _Entity_handles::value_type moab::Bvh_tree<_Entity_handles, _Box, _Moab, _Parametrizer>::bruteforce_find(const Vector&, double) const [with Vector = std::vector** >, _Entity_handles = moab::Range, _Box = moab::common_tree::Box**, _Moab = moab::Core, _Parametrizer = moab::element_utility::Parametrizer]’:
> ../src/moab/point_locater/point_locater.hpp:139: instantiated from ‘int moab::Point_search<_Tree, _Boxes>::bruteforce_locate_points(const Points&, Entities&, double) const [with Points = std::vector** >, std::allocator** > > >, Entities = std::vector** > >, std::allocator** > > > >, _Tree = moab::Bvh_tree**, moab::Core, moab::element_utility::Parametrizer>, _Boxes = std::vector**, std::allocator** > >]’
> point_search.cpp:204: instantiated from here
> ../src/moab/point_locater/tree/bvh_tree.hpp:728: warning: declaration of ‘Node’ shadows a member of 'this'
> In file included from point_search.cpp:26:
> ../src/moab/point_locater/parametrizer.hpp: In member function ‘std::pair** moab::element_utility::Parametrizer::operator()(Moab&, const Entity_handle&, const Point&) [with Moab = moab::Core, Entity_handle = long unsigned int, Point = std::vector** >]’:
> ../src/moab/point_locater/tree/bvh_tree.hpp:739: instantiated from ‘typename _Entity_handles::value_type moab::Bvh_tree<_Entity_handles, _Box, _Moab, _Parametrizer>::bruteforce_find(const Vector&, double) const [with Vector = std::vector** >, _Entity_handles = moab::Range, _Box = moab::common_tree::Box**, _Moab = moab::Core, _Parametrizer = moab::element_utility::Parametrizer]’
> ../src/moab/point_locater/parametrizer.hpp:76: error: ‘hex_map’ was not declared in this scope
> ../src/moab/point_locater/parametrizer.hpp:79: error: ‘tet_map’ was not declared in this scope
> ../src/moab/point_locater/parametrizer.hpp:84: error: ‘quadratic_hex_map’ was not declared in this scope
> ../src/moab/point_locater/parametrizer.hpp:87: error: ‘spectral_hex_map’ was not declared in this scope
URL: <http://lists.mcs.anl.gov/pipermail/moab-dev/attachments/20130917/4c518edc/attachment.html>
