[MOAB-dev] buildbot failure in moab-cub-par-tru: failed shell test install
    Tim Tautges
    tautges at mcs.anl.gov
    Tue Sep 17 09:56:32 CDT 2013
Agreed.
- tim
On 09/17/2013 03:03 AM, Vijay S. Mahadevan wrote:
> If no one is using pointsearch anymore, I vote we scratch this tool and its dependencies. They break a lot of tests,
> have compiler warnings, are not a useful API anymore and trigger faults with --enable-tools anyway. Now that the new
> Coupler design is somewhat mature, any functionality that this tool provided should be alternately available in the new
> interface.
> Thoughts ?
> Vijay
> On Tue, Sep 17, 2013 at 2:59 AM, <moab-dev at mcs.anl.gov <mailto:moab-dev at mcs.anl.gov>> wrote:
>       Fathom <http://gnep.mcs.anl.gov:8010/>: moab-cub-par-tru <http://gnep.mcs.anl.gov:8010/builders/moab-cub-par-tru>
>       build #221 <http://gnep.mcs.anl.gov:8010/builders/moab-cub-par-tru/builds/221>
>     *Results:*	failed shell test install
>     *Buildslave:*	gnep
>     *Revision:*	None
>         Log Excerpt
>     /home/fathom/3rdparty/mpich2/mpich2-1.2.1/gcc/include/mpicxx.h:384: warning: unused parameter ‘oldtype’
>     /home/fathom/3rdparty/mpich2/mpich2-1.2.1/gcc/include/mpicxx.h:384: warning: unused parameter ‘keyval’
>     /home/fathom/3rdparty/mpich2/mpich2-1.2.1/gcc/include/mpicxx.h:384: warning: unused parameter ‘ex’
>     /home/fathom/3rdparty/mpich2/mpich2-1.2.1/gcc/include/mpicxx.h:384: warning: unused parameter ‘attr_in’
>     /home/fathom/3rdparty/mpich2/mpich2-1.2.1/gcc/include/mpicxx.h:384: warning: unused parameter ‘attr_out’
>     /home/fathom/3rdparty/mpich2/mpich2-1.2.1/gcc/include/mpicxx.h:386: warning: unused parameter ‘type’
>     /home/fathom/3rdparty/mpich2/mpich2-1.2.1/gcc/include/mpicxx.h:386: warning: unused parameter ‘keyval’
>     /home/fathom/3rdparty/mpich2/mpich2-1.2.1/gcc/include/mpicxx.h:386: warning: unused parameter ‘attr’
>     /home/fathom/3rdparty/mpich2/mpich2-1.2.1/gcc/include/mpicxx.h:386: warning: unused parameter ‘ex’
>     /home/fathom/3rdparty/mpich2/mpich2-1.2.1/gcc/include/mpicxx.h:388: warning: unused parameter ‘oldtype’
>     /home/fathom/3rdparty/mpich2/mpich2-1.2.1/gcc/include/mpicxx.h:388: warning: unused parameter ‘keyval’
>     /home/fathom/3rdparty/mpich2/mpich2-1.2.1/gcc/include/mpicxx.h:388: warning: unused parameter ‘ex’
>     /home/fathom/3rdparty/mpich2/mpich2-1.2.1/gcc/include/mpicxx.h:1451: warning: unused parameter ‘oldcomm’
>     /home/fathom/3rdparty/mpich2/mpich2-1.2.1/gcc/include/mpicxx.h:1451: warning: unused parameter ‘keyval’
>     /home/fathom/3rdparty/mpich2/mpich2-1.2.1/gcc/include/mpicxx.h:1451: warning: unused parameter ‘ex’
>     /home/fathom/3rdparty/mpich2/mpich2-1.2.1/gcc/include/mpicxx.h:1451: warning: unused parameter ‘attr_in’
>     /home/fathom/3rdparty/mpich2/mpich2-1.2.1/gcc/include/mpicxx.h:1451: warning: unused parameter ‘attr_out’
>     /home/fathom/3rdparty/mpich2/mpich2-1.2.1/gcc/include/mpicxx.h:1453: warning: unused parameter ‘comm’
>     /home/fathom/3rdparty/mpich2/mpich2-1.2.1/gcc/include/mpicxx.h:1453: warning: unused parameter ‘keyval’
>     /home/fathom/3rdparty/mpich2/mpich2-1.2.1/gcc/include/mpicxx.h:1453: warning: unused parameter ‘attr’
>     /home/fathom/3rdparty/mpich2/mpich2-1.2.1/gcc/include/mpicxx.h:1453: warning: unused parameter ‘ex’
>     /home/fathom/3rdparty/mpich2/mpich2-1.2.1/gcc/include/mpicxx.h:1455: warning: unused parameter ‘oldcomm’
>     /home/fathom/3rdparty/mpich2/mpich2-1.2.1/gcc/include/mpicxx.h:1455: warning: unused parameter ‘keyval’
>     /home/fathom/3rdparty/mpich2/mpich2-1.2.1/gcc/include/mpicxx.h:1455: warning: unused parameter ‘ex’
>     /home/fathom/3rdparty/mpich2/mpich2-1.2.1/gcc/include/mpicxx.h:1884: warning: unused parameter ‘oldwin’
>     /home/fathom/3rdparty/mpich2/mpich2-1.2.1/gcc/include/mpicxx.h:1884: warning: unused parameter ‘keyval’
>     /home/fathom/3rdparty/mpich2/mpich2-1.2.1/gcc/include/mpicxx.h:1884: warning: unused parameter ‘ex’
>     /home/fathom/3rdparty/mpich2/mpich2-1.2.1/gcc/include/mpicxx.h:1884: warning: unused parameter ‘attr_in’
>     /home/fathom/3rdparty/mpich2/mpich2-1.2.1/gcc/include/mpicxx.h:1884: warning: unused parameter ‘attr_out’
>     /home/fathom/3rdparty/mpich2/mpich2-1.2.1/gcc/include/mpicxx.h:1886: warning: unused parameter ‘win’
>     /home/fathom/3rdparty/mpich2/mpich2-1.2.1/gcc/include/mpicxx.h:1886: warning: unused parameter ‘keyval’
>     /home/fathom/3rdparty/mpich2/mpich2-1.2.1/gcc/include/mpicxx.h:1886: warning: unused parameter ‘attr’
>     /home/fathom/3rdparty/mpich2/mpich2-1.2.1/gcc/include/mpicxx.h:1886: warning: unused parameter ‘ex’
>     /home/fathom/3rdparty/mpich2/mpich2-1.2.1/gcc/include/mpicxx.h:1888: warning: unused parameter ‘oldwin’
>     /home/fathom/3rdparty/mpich2/mpich2-1.2.1/gcc/include/mpicxx.h:1888: warning: unused parameter ‘keyval’
>     /home/fathom/3rdparty/mpich2/mpich2-1.2.1/gcc/include/mpicxx.h:1888: warning: unused parameter ‘ex’
>     In file included from point_search.cpp:25:
>     ../src/moab/point_locater/tree/bvh_tree.hpp: In member function ‘typename _Entity_handles::value_type moab::Bvh_tree<_Entity_handles, _Box, _Moab, _Parametrizer>::bruteforce_find(const Vector&, double) const [with Vector = std::vector__  >, _Entity_handles = moab::Range, _Box = moab::common_tree::Box__, _Moab = moab::Core, _Parametrizer = moab::element_utility::Parametrizer]’:
>     ../src/moab/point_locater/point_locater.hpp:139:   instantiated from ‘int moab::Point_search<_Tree, _Boxes>::bruteforce_locate_points(const Points&, Entities&, double) const [with Points = std::vector__  >, std::allocator__  > > >, Entities = std::vector__  > >, std::allocator__  > > > >, _Tree = moab::Bvh_tree__, moab::Core, moab::element_utility::Parametrizer>, _Boxes = std::vector__, std::allocator__  > >]’
>     point_search.cpp:204:   instantiated from here
>     ../src/moab/point_locater/tree/bvh_tree.hpp:728: warning: declaration of ‘Node’ shadows a member of 'this'
>     In file included from point_search.cpp:26:
>     ../src/moab/point_locater/parametrizer.hpp: In member function ‘std::pair__  moab::element_utility::Parametrizer::operator()(Moab&, const Entity_handle&, const Point&) [with Moab = moab::Core, Entity_handle = long unsigned int, Point = std::vector__  >]’:
>     ../src/moab/point_locater/tree/bvh_tree.hpp:739:   instantiated from ‘typename _Entity_handles::value_type moab::Bvh_tree<_Entity_handles, _Box, _Moab, _Parametrizer>::bruteforce_find(const Vector&, double) const [with Vector = std::vector__  >, _Entity_handles = moab::Range, _Box = moab::common_tree::Box__, _Moab = moab::Core, _Parametrizer = moab::element_utility::Parametrizer]’
>     ../src/moab/point_locater/parametrizer.hpp:76: error: ‘hex_map’ was not declared in this scope
>     ../src/moab/point_locater/parametrizer.hpp:79: error: ‘tet_map’ was not declared in this scope
>     ../src/moab/point_locater/parametrizer.hpp:84: error: ‘quadratic_hex_map’ was not declared in this scope
>     ../src/moab/point_locater/parametrizer.hpp:87: error: ‘spectral_hex_map’ was not declared in this scope
   steadfast, because he trusts in you."               Isaiah 26:3
              Tim Tautges            Argonne National Laboratory
          (tautges at mcs.anl.gov)      (telecommuting from UW-Madison)
  phone (gvoice): (608) 354-1459      1500 Engineering Dr.
             fax: (608) 263-4499      Madison, WI 53706
