[MOAB-dev] some errors I met I build moab
Vijay S. Mahadevan
vijay.m at gmail.com
Tue Sep 17 02:14:08 CDT 2013
> test/parallel/Makefile.am:30: `:='-style assignments are not portable
This is a warning.
> tools/mbcoupler
> tools/mbcslam
> tools/dagmc
> test/perf
What do you mean by "cannot find tools" ? If make check passes all
tests, you should be fine. But avoid hacking the makefile after
configure since you will lose these changes when reconfiguring. If you
want us to help you better, send configure.log and a better
description of what doesn't work.
> I still can't compile the tools/mbzoltan and tools/qvdual, and I havn't
You disabled these during configure. --disable-mbzoltan --disable-qvdual
Vijay
On Mon, Sep 16, 2013 at 10:36 PM, 魏华祎 <huayiwei1984 at gmail.com> wrote:
> Hi there,
> I checked out moab from https://bitbucket.org/fathomteam/moab. When I
> build, I meet some error, I think maybe they are bugs.
> First , when I run the following command and meet an error like:
> $ autoreconf -fi
> After I change ":=" to "=", it work well.
> Then I configure it by:
> ./configure --prefix=/home/why/software/moab/20130914 --enable-static
> --enable-igeom --enable-debug --enable-tools --enable-docs
> --disable-mbzoltan --disable-qvdual \
> --with-netcdf \
> --with-mpi \
> --with-hdf5 \
> --with-zoltan=/usr/local \
> --with-parmetis=/usr \
> --with-cgm=/home/why/software/cgma/6070 \
> --with-vtk=/home/why/software/vtk
> and when I make it, I find I can't compile three tools and a test:
> tools/mbcoupler
> tools/mbcslam
> tools/dagmc
> test/perf
> The problem is that they can't link with cgm. I find that the problem come
> from the Makefile in these directories. So I just change the line
> "LIBS = -lm" to "LIBS = -lm ${CGM_LIBS}", then make can pass, and make
> check also work well.
> figure out the reason why.
> Hope these informatin can improve the build process of Moad.
> Best
> Huayi
