[MOAB-dev] some errors I met I build moab
魏华祎
huayiwei1984 at gmail.com
Mon Sep 16 22:36:30 CDT 2013
Hi there,
I checked out moab from
https://bitbucket.org/fathomteam/moab<https://bitbucket.org/fathomteam/moab>.
When I build, I meet some error, I think maybe they are bugs.
First , when I run the following command and meet an error like:
$ autoreconf -fi
test/parallel/Makefile.am:30: `:='-style assignments are not portable
After I change ":=" to "=", it work well.
Then I configure it by:
./configure --prefix=/home/why/software/moab/20130914 --enable-static
--enable-igeom --enable-debug --enable-tools --enable-docs
--disable-mbzoltan --disable-qvdual \
--with-netcdf \
--with-mpi \
--with-hdf5 \
--with-zoltan=/usr/local \
--with-parmetis=/usr \
--with-cgm=/home/why/software/cgma/6070 \
--with-vtk=/home/why/software/vtk
and when I make it, I find I can't compile three tools and a test:
tools/mbcoupler
tools/mbcslam
tools/dagmc
test/perf
The problem is that they can't link with cgm. I find that the problem come
from the Makefile in these directories. So I just change the line
"LIBS = -lm" to "LIBS = -lm ${CGM_LIBS}", then make can pass, and make
check also work well.
I still can't compile the tools/mbzoltan and tools/qvdual, and I havn't
figure out the reason why.
Hope these informatin can improve the build process of Moad.
Best
Huayi
URL: <http://lists.mcs.anl.gov/pipermail/moab-dev/attachments/20130917/d0dda54b/attachment.html>
