[MOAB-dev] SCDMesh for meshing IGES geometry
    Rajeev Jain
    jain at mcs.anl.gov
    Wed Sep 11 12:30:04 CDT 2013
Hi Greg,
Thanks for the inquiry. You are right, SCDMesh algorithm in MeshKit was developed to do this sort of task.
It usesScdInterface (http://www.mcs.anl.gov/~fathom/moab-docs/html/contents.html#representation) defined in MOAB.
The meshing task you describe is covered in this test in MeshKit:
http://www.mcs.anl.gov/~fathom/meshkit-docs/html/test__scdmesh_8cpp_source.html
For SCDMesh algorithm details see: http://www.mcs.anl.gov/~fathom/meshkit-docs/html/algorithm_scdmesh.html
Rajeev
 From: "Fischer, Greg A." <FischeGA at westinghouse.com>
To: "jain at mcs.anl.gov" <jain at mcs.anl.gov>
Cc: "Fischer, Greg A." <FischeGA at westinghouse.com>
Sent: Wednesday, September 11, 2013 11:45 AM
Subject: SCDMesh for meshing IGES geometry
Hi Rajeev,
I came across MeshKit today, and it looks like you have made the most recent commits.  I’ve reviewed the 2011 CS&E presentation, and so far as I can tell, the SCDMesh component inside MeshKit might do what I want it to do.  Namely, I’d like to take geometry data (in IGES format, for example), and generate a Cartesian mesh structure that can be input into one of our solvers.  Our solver requires a structured, Cartesian grid, but it cannot accommodate embedded boundaries.
Can MeshKit do this?
Greg Fischer
Senior Engineer
Radiation Engineering & Analysis
Phone:  +1 (412) 374-2773
Email:  fischega at westinghouse.com
Home Page:  www.westinghousenuclear.com
URL: <http://lists.mcs.anl.gov/pipermail/moab-dev/attachments/20130911/a39fde31/attachment-0001.html>
