[MOAB-dev] commit/MOAB: danwu: In the constructor of Bvh_tree class, the initialization list should use entity_contains( _entity_contains) instead of entity_contains( entity_contains). The compile warning on unused parameter _entity_contains is helpful in finding this bug.
commits-noreply at bitbucket.org
Thu Sep 5 14:44:52 CDT 2013
1 new commit in MOAB:
https://bitbucket.org/fathomteam/moab/commits/874ab16eeb26/
Changeset: 874ab16eeb26
Branch: master
User: danwu
Date: 2013-09-05 21:44:42
Summary: In the constructor of Bvh_tree class, the initialization list should use entity_contains( _entity_contains) instead of entity_contains( entity_contains). The compile warning on unused parameter _entity_contains is helpful in finding this bug.
Affected #: 1 file
diff --git a/src/moab/point_locater/tree/bvh_tree.hpp b/src/moab/point_locater/tree/bvh_tree.hpp
index f050242..266d784 100644
--- a/src/moab/point_locater/tree/bvh_tree.hpp
+++ b/src/moab/point_locater/tree/bvh_tree.hpp
@@ -162,7 +162,7 @@ Bvh_tree( Entity_handles & _entities,
Parametrizer & _entity_contains): entity_handles_( _entities),
tree_(), moab( _moab),
bounding_box( _bounding_box),
- entity_contains( entity_contains){
+ entity_contains( _entity_contains){
typedef typename Entity_handles::iterator Entity_handle_iterator;
typedef ct::_Element_data< const _Box, double > Element_data;
typedef typename std::tr1::unordered_map< Entity_handle,
Repository URL: https://bitbucket.org/fathomteam/moab/
This is a commit notification from bitbucket.org. You are receiving
this because you have the service enabled, addressing the recipient of
this email.
