[MOAB-dev] commit/MOAB: tautges: Substantial rewrite of ParallelComm::update_remote_data. Should be a bit faster, maybe.
commits-noreply at bitbucket.org
Thu Sep 5 13:51:37 CDT 2013
1 new commit in MOAB:
https://bitbucket.org/fathomteam/moab/commits/fd2a67afc368/
Changeset: fd2a67afc368
Branch: master
User: tautges
Date: 2013-09-05 20:51:16
Summary: Substantial rewrite of ParallelComm::update_remote_data. Should be a bit faster, maybe.
Passes all tests.
Affected #: 2 files
diff --git a/src/parallel/ParallelComm.cpp b/src/parallel/ParallelComm.cpp
index 68c10eb..ab680aa 100644
--- a/src/parallel/ParallelComm.cpp
+++ b/src/parallel/ParallelComm.cpp
@@ -2429,10 +2429,155 @@ ErrorCode ParallelComm::recv_entities(std::set<unsigned int>& recv_procs,
ErrorCode ParallelComm::update_remote_data(const EntityHandle new_h,
- const int *ps,
- const EntityHandle *hs,
- const int num_ps,
- const unsigned char add_pstat)
+ const int *ps,
+ const EntityHandle *hs,
+ const int num_ps,
+ const unsigned char add_pstat
+// the following lines left in for future debugging, at least until I trust this function; tjt, 10/4/2013
+// ,int *new_ps,
+// EntityHandle *new_hs,
+// int &new_numps,
+// unsigned char &new_pstat
+ // get initial sharing data; tag_ps and tag_hs get terminated with -1 and 0
+ // in this function, so no need to initialize; sharing data does not include
+ // this proc if shared with only one other
+ // following variables declared here to avoid compiler errors
+ int new_numps;
+ unsigned char new_pstat;
+ std::vector<int> new_ps(MAX_SHARING_PROCS, -1);
+ std::vector<EntityHandle> new_hs(MAX_SHARING_PROCS, 0);
+ new_numps = 0;
+ ErrorCode result = get_sharing_data(new_h, &new_ps[0], &new_hs[0], new_pstat, new_numps);
+ RRA("update_remote_data");
+ int num_exist = new_numps;
+ // add new pstat info to the flag
+ new_pstat |= add_pstat;
+#define plist(str, lst, siz) \
+ std::cout << str << "("; \
+ for (int i = 0; i < (int)siz; i++) std::cout << lst[i] << " "; \
+ std::cout << ") "; \
+ std::cout << "update_remote_data: rank = " << rank() << ", new_h = " << new_h << std::endl;
+ std::string ostr;
+ plist("ps", ps, num_ps);
+ plist("hs", hs, num_ps);
+ print_pstatus(add_pstat, ostr);
+ std::cout << ", add_pstat = " << ostr.c_str() << std::endl;
+ plist("tag_ps", new_ps, new_numps);
+ plist("tag_hs", new_hs, new_numps);
+ assert(new_numps <= size());
+ print_pstatus(new_pstat, ostr);
+ std::cout << ", tag_pstat=" << ostr.c_str() << std::endl;
+#ifndef NDEBUG
+ // check for duplicates in proc list
+ std::set<unsigned int> dumprocs;
+ unsigned int dp = 0;
+ for (; (int) dp < num_ps && -1 != ps[dp]; dp++)
+ dumprocs.insert(ps[dp]);
+ assert(dp == dumprocs.size());
+#endif
+ // if only one sharer and I'm the owner, insert myself in the list;
+ // otherwise, my data is checked at the end
+ if (1 == new_numps && !(new_pstat & PSTATUS_NOT_OWNED)) {
+ new_hs[1] = new_hs[0];
+ new_ps[1] = new_ps[0];
+ new_hs[0] = new_h;
+ new_ps[0] = rank();
+ new_numps = 2;
+ // now put passed-in data onto lists
+ int idx;
+ for (int i = 0; i < num_ps; i++) {
+ idx = std::find(&new_ps[0], &new_ps[0] + new_numps, ps[i]) - &new_ps[0];
+ if (idx < new_numps) {
+ if (!new_hs[idx] && hs[i])
+ // h on list is 0 and passed-in h is non-zero, replace it
+ new_hs[idx] = hs[i];
+ else
+ assert(!hs[i] || new_hs[idx] == hs[i]);
+ else {
+ if (new_numps+1 == MAX_SHARING_PROCS) {
+ result = MB_FAILURE;
+ std::ostringstream str;
+ str << "Exceeded MAX_SHARING_PROCS for " << CN::EntityTypeName( TYPE_FROM_HANDLE(new_h) )
+ << ' ' << ID_FROM_HANDLE(new_h) << " in process " << rank() << std::endl;
+ RRA(str.str().c_str());
+ new_ps[new_numps] = ps[i];
+ new_hs[new_numps] = hs[i];
+ new_numps++;
+ // add myself, if it isn't there already
+ if (new_ps[0] != (int)rank()) {
+ idx = std::find(&new_ps[0], &new_ps[0] + new_numps, rank()) - &new_ps[0];
+ if (idx == new_numps) {
+ new_ps[new_numps] = rank();
+ new_hs[new_numps] = new_h;
+ new_numps++;
+ else if (!new_hs[idx] && new_numps > 2)
+ new_hs[idx] = new_h;
+ assert(new_hs[idx] == new_h || new_numps <= 2);
+ // adjust for interface layer if necessary
+ if (add_pstat & PSTATUS_INTERFACE) {
+ idx = std::min_element(&new_ps[0], &new_ps[0]+new_numps) - &new_ps[0];
+ if (idx) {
+ int tag_proc = new_ps[idx];
+ new_ps[idx] = new_ps[0];
+ new_ps[0] = tag_proc;
+ EntityHandle tag_h = new_hs[idx];
+ new_hs[idx] = new_hs[0];
+ new_hs[0] = tag_h;
+ if (new_ps[0] != (int)rank()) new_pstat |= PSTATUS_NOT_OWNED;
+ // update for shared, multishared
+ if (new_numps > 1) {
+ if (new_numps > 2) new_pstat |= PSTATUS_MULTISHARED;
+ new_pstat |= PSTATUS_SHARED;
+ plist("new_ps", new_ps, new_numps);
+ plist("new_hs", new_hs, new_numps);
+ std::cout << ", new_pstat=" << ostr.c_str() << std::endl;
+ std::cout << std::endl;
+ result = set_sharing_data(new_h, new_pstat, num_exist, new_numps, &new_ps[0], &new_hs[0]);
+ RRA("update_remote_data: setting sharing data");
+ if (new_pstat & PSTATUS_SHARED) sharedEnts.push_back(new_h);
+ return MB_SUCCESS;
+ErrorCode ParallelComm::update_remote_data_old(const EntityHandle new_h,
+ const int *ps,
+ const int num_ps,
+ const unsigned char add_pstat)
EntityHandle tag_hs[MAX_SHARING_PROCS];
int tag_ps[MAX_SHARING_PROCS];
@@ -2547,6 +2692,17 @@ ErrorCode ParallelComm::recv_entities(std::set<unsigned int>& recv_procs,
int tag_p;
EntityHandle tag_h;
+ // update pstat
+ pstat |= add_pstat;
+ if (num_exist > 2)
+ pstat |= (PSTATUS_MULTISHARED | PSTATUS_SHARED);
+ else if (num_exist > 0)
+ pstat |= PSTATUS_SHARED;
+// compare_remote_data(new_h, num_ps, hs, ps, add_pstat,
+// num_exist, tag_hs, tag_ps, pstat);
// reset single shared proc/handle if was shared and moving to multi-shared
if (num_exist > 2 && !(pstat & PSTATUS_MULTISHARED) &&
(pstat & PSTATUS_SHARED)) {
@@ -2559,9 +2715,6 @@ ErrorCode ParallelComm::recv_entities(std::set<unsigned int>& recv_procs,
RRA("Couldn't set sharedh tag.");
- // update pstat
- pstat |= add_pstat;
// set sharing tags
if (num_exist > 2) {
std::fill(tag_ps+num_exist, tag_ps+MAX_SHARING_PROCS, -1);
@@ -2570,7 +2723,6 @@ ErrorCode ParallelComm::recv_entities(std::set<unsigned int>& recv_procs,
RRA("Couldn't set sharedps tag.");
result = mbImpl->tag_set_data(sharedhs_tag(), &new_h, 1, tag_hs);
RRA("Couldn't set sharedhs tag.");
- pstat |= (PSTATUS_MULTISHARED | PSTATUS_SHARED);
#ifndef NDEBUG
@@ -2594,7 +2746,6 @@ ErrorCode ParallelComm::recv_entities(std::set<unsigned int>& recv_procs,
RRA("Couldn't set sharedp tag.");
result = mbImpl->tag_set_data(sharedh_tag(), &new_h, 1, tag_hs);
- pstat |= PSTATUS_SHARED;
// now set new pstatus
@@ -2689,8 +2840,6 @@ ErrorCode ParallelComm::recv_entities(std::set<unsigned int>& recv_procs,
num_ps = 0;
- // num_ps is unsigned, so comparison with zero is pointless
- //assert(0 <= num_ps && MAX_SHARING_PROCS >= num_ps);
assert(MAX_SHARING_PROCS >= num_ps);
return MB_SUCCESS;
@@ -5765,9 +5914,6 @@ ErrorCode ParallelComm::resolve_shared_ents(EntityHandle this_set,
int old_nump, int new_nump,
int *ps, EntityHandle *hs)
- assert("Should call this function only when reducing sharing procs." &&
- new_nump < old_nump);
// set sharing data to what's passed in; may have to clean up existing sharing tags
// if things changed too much
@@ -5804,7 +5950,16 @@ ErrorCode ParallelComm::resolve_shared_ents(EntityHandle this_set,
assert(dp == (int)dumprocs.size());
-#endif
+#endif
+ if (old_nump < 3) {
+ // reset sharedp and sharedh tags
+ int tmp_p = -1;
+ EntityHandle tmp_h = 0;
+ result = mbImpl->tag_set_data(sharedp_tag(), &ent, 1, &tmp_p);
+ RRA("");
+ result = mbImpl->tag_set_data(sharedh_tag(), &ent, 1, &tmp_h);
+ RRA("");
else {
unsigned int j = (ps[0] == (int)procConfig.proc_rank() ? 1 : 0);
@@ -8586,8 +8741,9 @@ ErrorCode ParallelComm::post_irecv(std::vector<unsigned int>& shared_procs,
* so on average, the message size is num_edges *( sizeof(eh) + sizeof(int) + 1*3*sizeof(double) )
* = num_edges * (8+4+24)
ErrorCode ParallelComm::settle_intersection_points(Range & edges, Range & shared_edges_owned,
- std::vector<std::vector<EntityHandle> *> & extraNodesVec, double tolerance)
+ std::vector<std::vector<EntityHandle> *> & extraNodesVec, double tolerance)
// the index of an edge in the edges Range will give the index for extraNodesVec
// the strategy of this follows exchange tags strategy:
@@ -8812,5 +8968,19 @@ ErrorCode ParallelComm::settle_intersection_points(Range & edges, Range & shared
// end copy
+void ParallelComm::print_pstatus(unsigned char pstat, std::string &ostr)
+ int num = 0;
+#define ppstat(a, b) {if (pstat & a) {if (num) str << ", "; str << b; num++;};}
+ ppstat(PSTATUS_NOT_OWNED, "NOT_OWNED");
+ ppstat(PSTATUS_SHARED, "SHARED");
+ ppstat(PSTATUS_MULTISHARED, "MULTISHARED");
+ ppstat(PSTATUS_INTERFACE, "INTERFACE");
+ ppstat(PSTATUS_GHOST, "GHOST");
+ ostr = str.str();
} // namespace moab
diff --git a/src/parallel/moab/ParallelComm.hpp b/src/parallel/moab/ParallelComm.hpp
index 93dc716..f0f1a2b 100644
--- a/src/parallel/moab/ParallelComm.hpp
+++ b/src/parallel/moab/ParallelComm.hpp
@@ -657,6 +657,13 @@ namespace moab {
Tag part_tag() { return partition_tag(); }
+ // \section DEBUGGING AIDS
+ //! print contents of pstatus value in human-readable form
+ void print_pstatus(unsigned char pstat, std::string &ostr);
// \section IMESHP-RELATED FUNCTIONS
@@ -1320,6 +1327,12 @@ namespace moab {
const int num_ps,
const unsigned char add_pstat);
+ ErrorCode update_remote_data_old(const EntityHandle new_h,
+ const int *ps,
+ const int num_ps,
+ const unsigned char add_pstat);
/** \brief Set pstatus tag interface bit on entities in sets passed in
ErrorCode tag_iface_entities();
Repository URL: https://bitbucket.org/fathomteam/moab/
This is a commit notification from bitbucket.org. You are receiving
this because you have the service enabled, addressing the recipient of
this email.
