[MOAB-dev] commit/MOAB: danwu: Fix compile warnings from some header files in src/moab/point_locater
commits-noreply at bitbucket.org
Thu Sep 5 16:50:39 CDT 2013
1 new commit in MOAB:
https://bitbucket.org/fathomteam/moab/commits/7f48c43b9254/
Changeset: 7f48c43b9254
Branch: master
User: danwu
Date: 2013-09-05 23:50:27
Summary: Fix compile warnings from some header files in src/moab/point_locater
Affected #: 6 files
diff --git a/src/moab/point_locater/element_maps/linear_hex_map.hpp b/src/moab/point_locater/element_maps/linear_hex_map.hpp
index 069d4c8..829addb 100644
--- a/src/moab/point_locater/element_maps/linear_hex_map.hpp
+++ b/src/moab/point_locater/element_maps/linear_hex_map.hpp
@@ -36,7 +36,10 @@ class Linear_hex_map {
//Constructor
Linear_hex_map() {}
//Copy constructor
- Linear_hex_map( const Self & f ) {}
+ Linear_hex_map( const Self & f ) {
+ // Remove the warning about unused parameter
+ if (NULL != &f) {}
public:
//Natural coordinates
@@ -46,19 +49,23 @@ class Linear_hex_map {
const Entity_handle & h,
const Points & v,
const Point & p,
- const double tol=1.e-6) const{
- Point result(3, 0.0);
- solve_inverse( p, result, v);
- bool point_found = solve_inverse( p, result, v, tol) &&
- is_contained( result, tol);
- return std::make_pair( point_found, result);
+ const double tol = 1.e-6) const {
+ // Remove the warnings about unused parameters
+ if (NULL != &moab) {}
+ if (NULL != &h) {}
+ Point result(3, 0.0);
+ solve_inverse( p, result, v);
+ bool point_found = solve_inverse( p, result, v, tol) &&
+ is_contained( result, tol);
+ return std::make_pair( point_found, result);
private:
//This is a hack to avoid a .cpp file and C++11
//reference_points(i,j) will be a 1 or -1;
//This should unroll..
- inline const double reference_points( const std::size_t& i,
+ inline double reference_points( const std::size_t& i,
const std::size_t& j) const{
const double rpts[8][3] = { { -1, -1, -1 },
{ 1, -1, -1 },
diff --git a/src/moab/point_locater/element_maps/linear_tet_map.hpp b/src/moab/point_locater/element_maps/linear_tet_map.hpp
index d48c63b..dedb8ed 100644
--- a/src/moab/point_locater/element_maps/linear_tet_map.hpp
+++ b/src/moab/point_locater/element_maps/linear_tet_map.hpp
@@ -18,14 +18,17 @@ class Linear_tet_map {
template< typename Moab, typename Points, typename Point>
std::pair< bool, Point> operator()( const Moab & moab,
- const Entity_handle eh,
+ const Entity_handle _eh,
const Points & v,
const Point & p,
const double tol=1e-6) {
- set_tet( eh, v);
- //TODO: Make sure this is correct
- Point result = Tinv*p;
- return std::make_pair( is_contained( result, tol), result);
+ set_tet( _eh, v);
+ //TODO: Make sure this is correct
+ Point result = Tinv*p;
+ return std::make_pair( is_contained( result, tol), result);
private:
diff --git a/src/moab/point_locater/element_maps/quadratic_hex_map.hpp b/src/moab/point_locater/element_maps/quadratic_hex_map.hpp
index 1f8b84d..92ea3ed 100644
--- a/src/moab/point_locater/element_maps/quadratic_hex_map.hpp
+++ b/src/moab/point_locater/element_maps/quadratic_hex_map.hpp
@@ -57,18 +57,22 @@ class Quadratic_hex_map {
const Points & v,
const Point & p,
private:
const double rpts[27][3] = {
{ -1, -1, -1 },
@@ -196,24 +200,27 @@ class Quadratic_hex_map {
template< typename Point, typename Points>
- Matrix& jacobian( const Point & p, const Points & points, Matrix & J) const{
- J = Matrix(0.0);
- for (int i=0; i<27; i++){
- const double sh[3] = { SH(reference_points(i,0), p[0]),
+ Matrix& jacobian( const Point & p, const Points & points, Matrix & J) const {
+ if (NULL != &points) {}
+ J = Matrix(0.0);
+ for (int i = 0; i < 27; i++) {
+ const double sh[3] = { SH(reference_points(i,0), p[0]),
SH(reference_points(i,1), p[1]),
SH(reference_points(i,2), p[2]) };
- const double dsh[3] = { DSH(reference_points(i,0), p[0]),
+ const double dsh[3] = { DSH(reference_points(i,0), p[0]),
DSH(reference_points(i,1), p[1]),
DSH(reference_points(i,2), p[2]) };
- for (int j=0; j<3; j++) {
- // dxj/dr first column
- J(j,0)+=dsh[0]*sh[1]*sh[2]*reference_points(i,j);
- J(j,1)+= sh[0]*dsh[1]*sh[2]*reference_points(i,j); // dxj/ds
- J(j,2)+= sh[0]*sh[1]*dsh[2]*reference_points(i,j); // dxj/dt
- return J;
+ for (int j = 0; j < 3; j++) {
+ // dxj/dr first column
+ J(j, 0) += dsh[0]*sh[1]*sh[2]*reference_points(i, j);
+ J(j, 1) += sh[0]*dsh[1]*sh[2]*reference_points(i, j); // dxj/ds
+ J(j, 2) += sh[0]*sh[1]*dsh[2]*reference_points(i, j); // dxj/dt
+ return J;
private:
}; //Class Quadratic_hex_map
diff --git a/src/moab/point_locater/element_maps/spectral_hex_map.hpp b/src/moab/point_locater/element_maps/spectral_hex_map.hpp
index 1b01dca..c255545 100644
--- a/src/moab/point_locater/element_maps/spectral_hex_map.hpp
+++ b/src/moab/point_locater/element_maps/spectral_hex_map.hpp
@@ -66,15 +66,19 @@ class Spectral_hex_map {
const Points & v,
const Point & p,
const double tol=1.e-6) {
- moab.tag_get_by_ptr(_xm1Tag, &eh, 1,(const void **) &_xyz[ 0] );
- moab.tag_get_by_ptr(_ym1Tag, &eh, 1,(const void **) &_xyz[ 1] );
- moab.tag_get_by_ptr(_zm1Tag, &eh, 1,(const void **) &_xyz[ 2] );
+ moab.tag_get_by_ptr(_xm1Tag, &eh, 1,(const void **) &_xyz[ 0] );
+ moab.tag_get_by_ptr(_ym1Tag, &eh, 1,(const void **) &_xyz[ 1] );
+ moab.tag_get_by_ptr(_zm1Tag, &eh, 1,(const void **) &_xyz[ 2] );
private:
@@ -143,16 +147,19 @@ class Spectral_hex_map {
Point& evaluate( const Point & p, const Points & points, Point & f) {
- for(int d = 0; d < 3; ++d){ lagrange_0(&_ld[ d], p[ 0]); }
- for( int d = 0; d < 3; ++d){
- f[ d] = tensor_i3( _ld[ 0].J, _ld[ 0].n,
- _ld[1].J, _ld[1].n,
- _ld[2].J, _ld[2].n,
- _xyz[ d],
- _odwork);
- return f;
+ for (int d = 0; d < 3; ++d) { lagrange_0(&_ld[ d], p[ 0]); }
+ f[ d] = tensor_i3( _ld[ 0].J, _ld[ 0].n,
+ _ld[1].J, _ld[1].n,
+ _ld[2].J, _ld[2].n,
+ _xyz[ d],
+ _odwork);
+ return f;
template< typename Point, typename Field>
double evaluate_scalar_field(const Point & p, const Field & field) const {
@@ -190,7 +197,8 @@ class Spectral_hex_map {
double wj= _ld[1].J[j];
double wi= _ld[0].J[i];
Matrix3 J(0.);
- for(int i = 0; i < 8; ++i){ J(i/3, i%3) = _data.jac[ i];}
+ for (int n = 0; n < 8; n++)
+ J(n/3, n%3) = _data.jac[n];
double bm = wk*wj*wi* J.determinant();
integral+= bm*field[index++];
//volume +=bm;
@@ -201,23 +209,27 @@ class Spectral_hex_map {
return integral;
- template< typename Point, typename Points>
- Matrix& jacobian( const Point & p, const Points & points, Matrix & J) {
+ template< typename Point, typename Points>
+ Matrix& jacobian( const Point & p, const Points & points, Matrix & J) {
+ if (NULL != &p) {}
real x[ 3];
- for(int i = 0; i < 3; ++i){ _data.elx[ i] = _xyz[ i]; }
- opt_vol_set_intp_3(& _data,x);
- for(int i = 0; i < 9; ++i){ J(i%3, i/3) = _data.jac[ i]; }
- return J;
+ for (int i = 0; i < 3; ++i) { _data.elx[ i] = _xyz[ i]; }
+ opt_vol_set_intp_3(& _data, x);
+ for (int i = 0; i < 9; ++i) { J(i%3, i/3) = _data.jac[ i]; }
+ return J;
private:
- bool _init;
- int _n;
- real * _z[ 3];
- lagrange_data _ld[ 3];
- opt_data_3 _data;
- real * _odwork;
- real * _xyz[ 3];
+ bool _init;
+ int _n;
+ real * _z[ 3];
+ lagrange_data _ld[ 3];
+ opt_data_3 _data;
+ real * _odwork;
+ real * _xyz[ 3];
}; //Class Spectral_hex_map
}// namespace element_utility
diff --git a/src/moab/point_locater/tree/bvh_tree.hpp b/src/moab/point_locater/tree/bvh_tree.hpp
index 266d784..2f92b19 100644
--- a/src/moab/point_locater/tree/bvh_tree.hpp
+++ b/src/moab/point_locater/tree/bvh_tree.hpp
@@ -503,7 +503,7 @@ void find_split(const Iterator & begin,
const Iterator & end, Split_data & data) const{
typedef typename Iterator::value_type Map_iterator;
typedef typename Map_iterator::value_type::second_type Box_data;
- typedef typename Box_data::first_type Bounding_box;
+ typedef typename Box_data::first_type _Bounding_box; // Note, not global typedef moab::common_tree::Box< double> Bounding_box;
typedef typename std::vector< Split_data> Split_list;
typedef typename std::vector< Split_list> Splits;
typedef typename Splits::iterator Split_iterator;
@@ -512,7 +512,7 @@ void find_split(const Iterator & begin,
Buckets buckets( NUM_DIM, Bucket_list( NUM_BUCKETS) );
Splits splits( NUM_DIM, Split_list( NUM_SPLITS, data));
- const Bounding_box interval = data.bounding_box;
+ const _Bounding_box interval = data.bounding_box;
establish_buckets( begin, end, interval, buckets);
initialize_splits( splits, buckets, data);
choose_best_split( splits, data);
diff --git a/src/moab/point_locater/tree/element_tree.hpp b/src/moab/point_locater/tree/element_tree.hpp
index 2b0b86c..261c4a5 100644
--- a/src/moab/point_locater/tree/element_tree.hpp
+++ b/src/moab/point_locater/tree/element_tree.hpp
@@ -45,7 +45,7 @@ bool operator()(const Value & a, const Value & b){
template< typename Data>
struct Split_comparator {
//we minimizes ||left| - |right|| + |middle|^2
- const double split_objective( const Data & a) const {
+ double split_objective( const Data & a) const {
if (a.second.sizes[ 2]==0 || a.second.sizes[ 0] == 0){
return std::numeric_limits< std::size_t>::max();
Repository URL: https://bitbucket.org/fathomteam/moab/
This is a commit notification from bitbucket.org. You are receiving
this because you have the service enabled, addressing the recipient of
this email.
