[MOAB-dev] commit/MOAB: danwu: Fix compile warnings from MBZoltan, including:
commits-noreply at bitbucket.org
Thu Sep 5 10:40:45 CDT 2013
1 new commit in MOAB:
https://bitbucket.org/fathomteam/moab/commits/5e989abe07d6/
Changeset: 5e989abe07d6
Branch: master
User: danwu
Date: 2013-09-05 17:36:30
Summary: Fix compile warnings from MBZoltan, including:
1) vector obj_weights defined in MBZoltan.hpp should be removed, as it is always shadowed in MBZoltan.cpp by function parameters.
2) In MBZoltan::partition_round_robin(), shared_procs defined in the inner loop shadows the one defined in the outer loop, so it is renamed to child_shared_procs.
Fix a potential bug:
In MBZoltan::partition_round_robin(), the inner loop "for (i = 0; i < n_child; i++)" should be "for (j = 0; j < n_child; j++)", as i is already used by the outer loop.
Affected #: 2 files
diff --git a/tools/mbzoltan/MBZoltan.cpp b/tools/mbzoltan/MBZoltan.cpp
index e72c97e..299e3c4 100644
--- a/tools/mbzoltan/MBZoltan.cpp
+++ b/tools/mbzoltan/MBZoltan.cpp
@@ -211,7 +211,7 @@ ErrorCode MBZoltan::balance_mesh(const char *zmethod,
exportProcs, &assignment);
if (mbpc->proc_config().proc_rank() == 0) {
- ErrorCode result = write_partition(mbpc->proc_config().proc_size(), elems, assignment,
+ result = write_partition(mbpc->proc_config().proc_size(), elems, assignment,
write_as_sets, write_as_tags);
if (MB_SUCCESS != result) return result;
@@ -579,8 +579,7 @@ ErrorCode MBZoltan::assemble_graph(const int dimension,
adjs.clear();
result = mtu.get_bridge_adjacencies(*rit, (dimension > 0 ? dimension-1 : 3),
dimension, adjs); RR;
// get the graph vertex ids of those
if (!adjs.empty()) {
assert(adjs.size() < 5*MAX_SUB_ENTITIES);
@@ -634,6 +633,10 @@ ErrorCode MBZoltan::assemble_graph(const int dimension,
const double part_geom_mesh_size,
const int n_part)
+ // To remove the warnings about unused variables
+ if (dimension > 0) {}
+ if (coords.size() > 0) {}
// get body vertex weights
DLIList<RefEntity*> body_list;
gti->ref_entity_list("body", body_list, CUBIT_FALSE);
@@ -696,7 +699,6 @@ ErrorCode MBZoltan::assemble_graph(const int dimension,
shared_surfs.reset();
for (int k = 0; k < n_shared; k++) { // add adjacencies
RefFace *face = shared_surfs.get_and_step();
- int temp_index;
std::map<int, int>::iterator iter = surf_vertex_map.find(face->id());
if (iter != surf_vertex_map.end()) {
temp_index = (*iter).second;
@@ -760,8 +762,8 @@ ErrorCode MBZoltan::assemble_graph(const int dimension,
- for (int i = 0; i < obj_weights.size(); i++) if (obj_weights[i] < 1.) obj_weights[i] = 1.;
- for (int i = 0; i < edge_weights.size(); i++) if (edge_weights[i] < 1.) edge_weights[i] = 1.;
+ for (size_t i = 0; i < obj_weights.size(); i++) if (obj_weights[i] < 1.) obj_weights[i] = 1.;
+ for (size_t i = 0; i < edge_weights.size(); i++) if (edge_weights[i] < 1.) edge_weights[i] = 1.;
return MB_SUCCESS;
@@ -783,6 +785,8 @@ double MBZoltan::estimate_face_mesh_load(RefEntity* face, const double h)
type == TORUS_SURFACE_TYPE) {
return 2.352511671418708e-4*n_logn;
+ return 0.0;
double MBZoltan::estimate_face_comm_load(RefEntity* face, const double h)
@@ -843,9 +847,9 @@ ErrorCode MBZoltan::write_partition(const int nparts,
int n_vol = volumes.size();
volumes.reset();
for (int j = 0; j < n_vol; j++) {
- RefEntity *vol = volumes.get_and_step();
- td_par = (TDParallel *) vol->get_TD(&TDParallel::is_parallel);
- if (td_par == NULL) td_par = new TDParallel(vol, NULL, &shared_procs);
+ RefEntity *vol = volumes.get_and_step();
+ td_par = (TDParallel *) vol->get_TD(&TDParallel::is_parallel);
+ if (td_par == NULL) td_par = new TDParallel(vol, NULL, &shared_procs);
@@ -867,7 +871,7 @@ ErrorCode MBZoltan::write_partition(const int nparts,
shared_procs.append(proc); // local proc
parents.reset();
- for (int i = 0 ; i < 2; i++) {
+ for (int j = 0 ; j < 2; j++) {
RefEntity *parent = parents.get_and_step();
TDParallel *parent_td = (TDParallel *) parent->get_TD(&TDParallel::is_parallel);
@@ -887,8 +891,8 @@ ErrorCode MBZoltan::write_partition(const int nparts,
if (debug) {
std::cout << "surf" << entity->id() << "_is_partitioned_to_p";
- for (int i = 0; i < shared_procs.size(); i++) {
- std::cout << "," << shared_procs[i];
+ for (int j = 0; j < shared_procs.size(); j++) {
+ std::cout << "," << shared_procs[j];
std::cout << std::endl;
@@ -1035,7 +1039,7 @@ ErrorCode MBZoltan::partition_surface(const int nparts,
ErrorCode MBZoltan::partition_round_robin(const int n_part)
- int i, j;
+ int i, j, k;
double* loads = new double[n_part]; // estimated loads for each processor
double* ve_loads = new double[n_part]; // estimated loads for each processor
for (i = 0; i < n_part; i++) {
@@ -1055,13 +1059,14 @@ ErrorCode MBZoltan::partition_round_robin(const int n_part)
for (i = 0; i < n_entity; i++) {
if (i == i_entity_proc) {
proc++;
- if (proc < n_part) i_entity_proc += n_entity_proc;
+ if (proc < n_part)
+ i_entity_proc += n_entity_proc;
else {
proc %= n_part;
i_entity_proc++;
// assign to bodies
entity = body_entity_list.get_and_step();
DLIList<int> shared_procs;
@@ -1069,7 +1074,7 @@ ErrorCode MBZoltan::partition_round_robin(const int n_part)
TDParallel *td_par = (TDParallel *) entity->get_TD(&TDParallel::is_parallel);
if (td_par == NULL) td_par = new TDParallel(entity, NULL, &shared_procs);
loads[proc] += entity->measure();
// assign to volumes, it should be removed in future
DLIList<RefVolume*> volumes;
(dynamic_cast<TopologyEntity*> (entity))->ref_volumes(volumes);
@@ -1080,7 +1085,7 @@ ErrorCode MBZoltan::partition_round_robin(const int n_part)
// add local surface load
DLIList<RefFace*> faces;
(dynamic_cast<TopologyEntity*> (entity))->ref_faces(faces);
@@ -1089,78 +1094,74 @@ ErrorCode MBZoltan::partition_round_robin(const int n_part)
for (j = 0; j < n_face; j++) {
RefFace* face = faces.get_and_step();
TopologyEntity *te = CAST_TO(face, TopologyEntity);
- if (te->bridge_manager()->number_of_bridges() < 2) {
+ if (te->bridge_manager()->number_of_bridges() < 2)
loads[proc] = loads[proc] + face->measure();
// Get all child entities
DLIList<RefEntity*> child_list;
RefEntity::get_all_child_ref_entities(body_entity_list, child_list);
int n_child = child_list.size();
// assign processors to interface entities
child_list.reset();
- for (i = 0; i < n_child; i++) {
+ for (j = 0; j < n_child; j++) {
entity = child_list.get_and_step();
TopologyEntity *te = CAST_TO(entity, TopologyEntity);
if (te->bridge_manager()->number_of_bridges() > 1) {
DLIList<Body*> parent_bodies;
- DLIList<int> shared_procs;
- (dynamic_cast<TopologyEntity*> (entity))->bodies(parent_bodies);
- int n_parent = parent_bodies.size();
+ DLIList<int> child_shared_procs; // Shared processors of each child entity
+ (dynamic_cast<TopologyEntity*> (entity))->bodies(parent_bodies);
+ int n_parent = parent_bodies.size();
- for (j = 0; j < n_parent; j++) {
- RefEntity *parent_vol = CAST_TO(parent_bodies.get_and_step(), RefEntity);
- TDParallel *parent_td = (TDParallel *) parent_vol->get_TD(&TDParallel::is_parallel);
- if (parent_td == NULL) {
- PRINT_ERROR("parent Volume has to be partitioned.");
- return MB_FAILURE;
- shared_procs.append_unique(parent_td->get_charge_proc());
- if (shared_procs.size() > 1) { // if it is interface
- TDParallel *td_par = (TDParallel *) entity->get_TD(&TDParallel::is_parallel);
- if (td_par == NULL) {
+ for (k = 0; k < n_parent; k++) {
+ RefEntity *parent_vol = CAST_TO(parent_bodies.get_and_step(), RefEntity);
+ TDParallel *parent_td = (TDParallel *) parent_vol->get_TD(&TDParallel::is_parallel);
+ if (parent_td == NULL) {
+ PRINT_ERROR("parent Volume has to be partitioned.");
+ return MB_FAILURE;
+ child_shared_procs.append_unique(parent_td->get_charge_proc());
+ if (child_shared_procs.size() > 1) { // if it is interface
+ td_par = (TDParallel *) entity->get_TD(&TDParallel::is_parallel);
+ if (td_par == NULL) {
int merge_id = TDUniqueId::get_unique_id(entity);
- if (entity->entity_type_info() == typeid(RefFace)) { // face
- if (shared_procs.size() != 2) {
- PRINT_ERROR("Error: # of shared processors of interface surface should be 2.");
- // balance interface surface loads
- if (loads[shared_procs[0]] > loads[shared_procs[1]]) {
- shared_procs.reverse();
- loads[shared_procs[0]] = loads[shared_procs[0]] + entity->measure();
- td_par = new TDParallel(entity, NULL, &shared_procs, NULL,
- merge_id, 1);
- else if (entity->entity_type_info() == typeid(RefEdge) ||
- entity->entity_type_info() == typeid(RefVertex)) {
+ if (entity->entity_type_info() == typeid(RefFace)) { // face
+ if (child_shared_procs.size() != 2) {
+ PRINT_ERROR("Error: # of shared processors of interface surface should be 2.");
- int min_p = shared_procs[0];
- int n_shared_proc = shared_procs.size();
- for (int i = 1; i < n_shared_proc; i++) {
- if (ve_loads[shared_procs[i]] < ve_loads[min_p]) {
- min_p = shared_procs[i];
+ if (loads[child_shared_procs[0]] > loads[child_shared_procs[1]])
+ child_shared_procs.reverse();
+ loads[child_shared_procs[0]] = loads[child_shared_procs[0]] + entity->measure();
+ td_par = new TDParallel(entity, NULL, &child_shared_procs, NULL, merge_id, 1);
+ } // face
+ else if (entity->entity_type_info() == typeid(RefEdge) ||
+ entity->entity_type_info() == typeid(RefVertex)) { // edge or vertex
+ // balance interface surface loads
+ int min_p = child_shared_procs[0];
+ int n_shared_proc = child_shared_procs.size();
+ for (k = 1; k < n_shared_proc; k++) {
+ if (ve_loads[child_shared_procs[k]] < ve_loads[min_p])
+ min_p = child_shared_procs[k];
ve_loads[min_p] = ve_loads[min_p] + entity->measure();
- shared_procs.remove(min_p);
- shared_procs.insert_first(min_p);
- merge_id, 1);
+ child_shared_procs.remove(min_p);
+ child_shared_procs.insert_first(min_p);
+ } // edge or vertex
+ } // if (td_par == NULL)
+ } // if it is interface
+ } // if (te->bridge_manager()->number_of_bridges() > 1)
+ } // for (j = 0; j < n_child; j++)
+ } // for (i = 0; i < n_entity; i++)
return MB_SUCCESS;
@@ -1357,14 +1358,14 @@ ErrorCode MBZoltan::write_partition(const int nparts,
// check for empty sets, warn if there are any
Range empty_sets;
- for (Range::iterator rit = partSets.begin(); rit != partSets.end(); rit++) {
+ for (rit = partSets.begin(); rit != partSets.end(); rit++) {
int num_ents = 0;
result = mbImpl->get_number_entities_by_handle(*rit, num_ents);
if (MB_SUCCESS != result || !num_ents) empty_sets.insert(*rit);
if (!empty_sets.empty()) {
std::cout << "WARNING: " << empty_sets.size() << " empty sets in partition: ";
- for (Range::iterator rit = empty_sets.begin(); rit != empty_sets.end(); rit++)
+ for (rit = empty_sets.begin(); rit != empty_sets.end(); rit++)
std::cout << *rit << " ";
@@ -1476,16 +1477,14 @@ int MBZoltan::mbInitializePoints(int npts, double *pts, int *ids,
int *sendNborId;
int *sendProcs;
- if (mbpc->proc_config().proc_rank() == 0)
+ if (mbpc->proc_config().proc_rank() == 0) {
/* divide pts to start */
numPts = (int *)malloc(sizeof(int) * mbpc->proc_config().proc_size());
ptsPerProc = npts / mbpc->proc_config().proc_size();
ptsAssigned = 0;
- for (i=0; i < mbpc->proc_config().proc_size()-1; i++)
+ for (i = 0; i < mbpc->proc_config().proc_size() - 1; i++) {
numPts[i] = ptsPerProc;
ptsAssigned += ptsPerProc;
@@ -1498,37 +1497,36 @@ int MBZoltan::mbInitializePoints(int npts, double *pts, int *ids,
sendEdges = length + numPts[0];
sum = 0;
- for (j=0; j<numPts[0]; j++)
+ for (j = 0; j < numPts[0]; j++)
sum += length[j];
sendNborId = adjs + sum;
- for (j=numPts[0]; j<npts; j++)
+ for (j = numPts[0]; j < npts; j++)
sum += length[j];
nborProcs = (int *)malloc(sizeof(int) * sum);
- for (j=0; j<sum; j++)
- if ((i = adjs[j]/ptsPerProc) < mbpc->proc_config().proc_size())
+ for (j = 0; j < sum; j++)
+ if ((i = adjs[j] / ptsPerProc) < mbpc->proc_config().proc_size())
nborProcs[j] = i;
else
nborProcs[j] = mbpc->proc_config().proc_size() - 1;
sendProcs = nborProcs + (sendNborId - adjs);
- for (i=1; i<mbpc->proc_config().proc_size(); i++)
- MPI_Send(&numPts[i], 1, MPI_INT, i, 0x00,MPI_COMM_WORLD);
- MPI_Send(sendPts, 3 * numPts[i], MPI_DOUBLE, i, 0x01,MPI_COMM_WORLD);
- MPI_Send(sendIds, numPts[i], MPI_INT, i, 0x03,MPI_COMM_WORLD);
- MPI_Send(sendEdges, numPts[i], MPI_INT, i, 0x06,MPI_COMM_WORLD);
+ for (i = 1; i < mbpc->proc_config().proc_size(); i++) {
+ MPI_Send(&numPts[i], 1, MPI_INT, i, 0x00, MPI_COMM_WORLD);
+ MPI_Send(sendPts, 3 * numPts[i], MPI_DOUBLE, i, 0x01, MPI_COMM_WORLD);
+ MPI_Send(sendIds, numPts[i], MPI_INT, i, 0x03, MPI_COMM_WORLD);
+ MPI_Send(sendEdges, numPts[i], MPI_INT, i, 0x06, MPI_COMM_WORLD);
sum = 0;
- for (j=0; j<numPts[i]; j++)
+ for (j = 0; j < numPts[i]; j++)
sum += sendEdges[j];
- MPI_Send(sendNborId, sum, MPI_INT, i, 0x07,MPI_COMM_WORLD);
- MPI_Send(sendProcs, sum, MPI_INT, i, 0x08,MPI_COMM_WORLD);
+ MPI_Send(sendNborId, sum, MPI_INT, i, 0x07, MPI_COMM_WORLD);
+ MPI_Send(sendProcs, sum, MPI_INT, i, 0x08, MPI_COMM_WORLD);
sendPts += (3 * numPts[i]);
sendIds += numPts[i];
sendEdges += numPts[i];
@@ -1538,8 +1536,7 @@ int MBZoltan::mbInitializePoints(int npts, double *pts, int *ids,
free(numPts);
- else
+ else {
MPI_Recv(&mySize, 1, MPI_INT, 0, 0x00, MPI_COMM_WORLD, &stat);
pts = (double *)malloc(sizeof(double) * 3 * mySize);
ids = (int *)malloc(sizeof(int) * mySize);
@@ -1550,7 +1547,7 @@ int MBZoltan::mbInitializePoints(int npts, double *pts, int *ids,
MPI_Recv(length, mySize, MPI_INT, 0, 0x06, MPI_COMM_WORLD, &stat);
sum = 0;
- for (j=0; j<mySize; j++)
+ for (j = 0; j < mySize; j++)
sum += length[j];
adjs = (int *)malloc(sizeof(int) * sum);
@@ -1559,7 +1556,7 @@ int MBZoltan::mbInitializePoints(int npts, double *pts, int *ids,
MPI_Recv(adjs, sum, MPI_INT, 0, 0x07, MPI_COMM_WORLD, &stat);
MPI_Recv(nborProcs, sum, MPI_INT, 0, 0x08, MPI_COMM_WORLD, &stat);
Points = pts;
GlobalIds = ids;
NumPoints = mySize;
@@ -1569,7 +1566,7 @@ int MBZoltan::mbInitializePoints(int npts, double *pts, int *ids,
ObjWeights = obj_weights;
EdgeWeights = edge_weights;
Parts = parts;
return mySize;
@@ -1590,33 +1587,29 @@ void MBZoltan::mbFinalizePoints(int npts, int numExport,
else
MyAssignment = (int *)malloc(sizeof(int) * NumPoints);
- for (i=0; i<NumPoints; i++)
+ for (i = 0; i < NumPoints; i++)
MyAssignment[i] = mbpc->proc_config().proc_rank();
- for (i=0; i<numExport; i++)
+ for (i = 0; i < numExport; i++)
MyAssignment[exportLocalIDs[i]] = exportProcs[i];
/* collect pts */
recvA = MyAssignment + NumPoints;
- for (i=1; i< (int) mbpc->proc_config().proc_size(); i++)
- MPI_Recv(&numPts, 1, MPI_INT, i, 0x04, MPI_COMM_WORLD, &stat);
- MPI_Recv(recvA, numPts, MPI_INT, i, 0x05, MPI_COMM_WORLD, &stat);
- recvA += numPts;
- *assignment = MyAssignment;
+ for (i = 1; i< (int) mbpc->proc_config().proc_size(); i++) {
+ MPI_Recv(&numPts, 1, MPI_INT, i, 0x04, MPI_COMM_WORLD, &stat);
+ MPI_Recv(recvA, numPts, MPI_INT, i, 0x05, MPI_COMM_WORLD, &stat);
+ recvA += numPts;
- else
- MPI_Send(&NumPoints, 1, MPI_INT, 0, 0x04,MPI_COMM_WORLD);
- MPI_Send(MyAssignment, NumPoints, MPI_INT, 0, 0x05,MPI_COMM_WORLD);
- free(MyAssignment);
+ *assignment = MyAssignment;
+ else {
+ MPI_Send(&NumPoints, 1, MPI_INT, 0, 0x04, MPI_COMM_WORLD);
+ MPI_Send(MyAssignment, NumPoints, MPI_INT, 0, 0x05, MPI_COMM_WORLD);
+ free(MyAssignment);
int MBZoltan::mbGlobalSuccess(int rc)
@@ -1627,8 +1620,8 @@ int MBZoltan::mbGlobalSuccess(int rc)
MPI_Allgather(&rc, 1, MPI_INT, vals, 1, MPI_INT, MPI_COMM_WORLD);
- for (i=0; i<mbpc->proc_config().proc_size(); i++){
- if (vals[i] != ZOLTAN_OK){
+ for (i = 0; i<mbpc->proc_config().proc_size(); i++) {
+ if (vals[i] != ZOLTAN_OK) {
if (0 == mbpc->proc_config().proc_rank()){
mbShowError(vals[i], "Result on process ");
@@ -1653,15 +1646,15 @@ void MBZoltan::mbPrintGlobalResult(const char *s,
v1[2] = exp;
v1[3] = change;
- if (mbpc->proc_config().proc_rank() == 0){
v2 = (int *)malloc(4 * mbpc->proc_config().proc_size() * sizeof(int));
MPI_Gather(v1, 4, MPI_INT, v2, 4, MPI_INT, 0, MPI_COMM_WORLD);
- fprintf(stdout,"======%s======\n",s);
- for (i=0, v=v2; i<mbpc->proc_config().proc_size(); i++, v+=4){
+ fprintf(stdout, "======%s======\n", s);
+ for (i = 0, v = v2; i < mbpc->proc_config().proc_size(); i++, v += 4) {
fprintf(stdout,"%d: originally had %d, import %d, exp %d, %s\n",
i, v[0], v[1], v[2],
v[3] ? "a change of partitioning" : "no change");
@@ -1678,11 +1671,9 @@ void MBZoltan::mbPrintGlobalResult(const char *s,
void MBZoltan::mbShowError(int val, const char *s)
if (s)
- printf("%s ",s);
- switch (val)
+ printf("%s ", s);
+ switch (val) {
case ZOLTAN_OK:
printf("%d: SUCCESSFUL\n", mbpc->proc_config().proc_rank());
break;
@@ -1699,7 +1690,6 @@ void MBZoltan::mbShowError(int val, const char *s)
printf("%d: INVALID RETURN CODE\n", mbpc->proc_config().proc_rank());
break;
- return;
@@ -1708,6 +1698,9 @@ void MBZoltan::mbShowError(int val, const char *s)
int mbGetNumberOfAssignedObjects(void *userDefinedData, int *err)
+ if (userDefinedData) {}
*err = 0;
return NumPoints;
@@ -1716,56 +1709,64 @@ void mbGetObjectList(void *userDefinedData, int numGlobalIds, int numLids,
ZOLTAN_ID_PTR gids, ZOLTAN_ID_PTR lids, int wgt_dim, float *obj_wgts,
int *err)
- int i;
+ if (numGlobalIds > 0){}
+ if (numLids > 0) {}
+ if (gids) {}
+ if (lids) {}
+ for (int i = 0; i < NumPoints; i++) {
gids[i] = GlobalIds[i];
lids[i] = i;
- if (wgt_dim>0) obj_wgts[i] = ObjWeights[i];
+ if (wgt_dim > 0)
+ obj_wgts[i] = ObjWeights[i];
*err = 0;
- return;
int mbGetObjectSize(void *userDefinedData, int *err)
*err = 0;
return 3;
void mbGetObject(void *userDefinedData, int numGlobalIds, int numLids, int numObjs,
ZOLTAN_ID_PTR gids, ZOLTAN_ID_PTR lids, int numDim, double *pts, int *err)
+ if (numGlobalIds > 0) {}
+ if (gids) {}
+ if (lids) {}
int i, id, id3;
int next = 0;
- if (numDim != 3)
+ if (numDim != 3) {
*err = 1;
return;
- for (i=0; i<numObjs; i++)
+ for (i = 0; i < numObjs; i++) {
id = lids[i];
- if ((id < 0) || (id >= NumPoints))
+ if ((id < 0) || (id >= NumPoints)) {
*err = 1;
return;
id3 = lids[i] * 3;
pts[next++] = Points[id3];
pts[next++] = Points[id3 + 1];
pts[next++] = Points[id3 + 2];
void mbGetNumberOfEdges(void *userDefinedData, int numGlobalIds, int numLids,
@@ -1773,21 +1774,26 @@ void mbGetNumberOfEdges(void *userDefinedData, int numGlobalIds, int numLids,
ZOLTAN_ID_PTR gids, ZOLTAN_ID_PTR lids, int *numEdges,
int *err)
+ if (gids) {}
+ if (lids) {}
int i, id;
int next = 0;
- id = lids[i];
- *err = 1;
- return;
+ id = lids[i];
- numEdges[next++] = NumEdges[id];
+ *err = 1;
+ return;
+ numEdges[next++] = NumEdges[id];
void mbGetEdgeList(void *userDefinedData, int numGlobalIds, int numLids,
@@ -1796,50 +1802,62 @@ void mbGetEdgeList(void *userDefinedData, int numGlobalIds, int numLids,
ZOLTAN_ID_PTR nborGlobalIds, int *nborProcs, int wgt_dim,
float *edge_wgts, int *err)
+ if (gids) {}
+ if (lids) {}
+ if (numEdges) {}
int i, id, idSum, j;
int next = 0;
- id = lids[i];
- *err = 1;
- return;
- idSum = 0;
- for (j=0; j<id; j++)
- idSum += NumEdges[j];
- for (j=0; j<NumEdges[id]; j++)
- nborGlobalIds[next] = NborGlobalId[idSum];
- nborProcs[next] = NborProcs[idSum];
- if (wgt_dim > 0) edge_wgts[next] = EdgeWeights[idSum];
- next++;
- idSum++;
+ id = lids[i];
+ *err = 1;
+ return;
+ idSum = 0;
+ for (j = 0; j < id; j++)
+ idSum += NumEdges[j];
+ for (j = 0; j < NumEdges[id]; j++) {
+ nborGlobalIds[next] = NborGlobalId[idSum];
+ nborProcs[next] = NborProcs[idSum];
+ if (wgt_dim > 0) edge_wgts[next] = EdgeWeights[idSum];
+ next++;
+ idSum++;
void mbGetPart(void *userDefinedData, int numGlobalIds, int numLids,
int numObjs, ZOLTAN_ID_PTR gids, ZOLTAN_ID_PTR lids,
int *part, int *err)
+ if (gids) {}
+ if (lids) {}
int i, id;
int next = 0;
id = lids[i];
*err = 1;
return;
part[next++] = Parts[id];
diff --git a/tools/mbzoltan/MBZoltan.hpp b/tools/mbzoltan/MBZoltan.hpp
index 92585e7..e36ec13 100644
--- a/tools/mbzoltan/MBZoltan.hpp
+++ b/tools/mbzoltan/MBZoltan.hpp
@@ -201,8 +201,6 @@ using namespace moab;
#ifdef CGM
std::map<int, int> body_vertex_map, surf_vertex_map;
- std::vector<double> obj_weights;
ErrorCode assemble_graph(const int dimension,
std::vector<double> &coords,
std::vector<int> &moab_ids,
Repository URL: https://bitbucket.org/fathomteam/moab/
This is a commit notification from bitbucket.org. You are receiving
this because you have the service enabled, addressing the recipient of
this email.
