[MOAB-dev] commit/MOAB: tautges: Removing old file.
commits-noreply at bitbucket.org
Sat Jul 27 22:03:15 CDT 2013
1 new commit in MOAB:
https://bitbucket.org/fathomteam/moab/commits/9ab30eb3b32d/
Changeset: 9ab30eb3b32d
Branch: master
User: tautges
Date: 2013-07-28 05:03:08
Summary: Removing old file.
Affected #: 1 file
diff --git a/examples/HelloMoabPar.cpp b/examples/HelloMoabPar.cpp
deleted file mode 100644
index a5a71aa..0000000
--- a/examples/HelloMoabPar.cpp
+++ /dev/null
@@ -1,154 +0,0 @@
-/** @example HelloMoabPar.cpp \n
- * \brief Read mesh into MOAB in parallel \n
- * This example shows the simplest way of telling MOAB to read in parallel.
- * -# Initialize MPI and get the rank and number of processors \n
- * -# Process arguments (file name and options for parallel read) \n
- * -# Initialize MOAB \n
- * -# Load a partitioned file in parallel; \n
- * -# retrieve shared entities on each processor \n
- * -# Filter owned entities among shared ones on each processor \n
- * -# Exchange ghost layers, and repeat the reports \n
- * <b>To compile</b>: \n
- * make HelloMoabPar MOAB_DIR=<installdir> \n
- * <b>To run</b>: mpiexec -np 4 HelloMoabPar \n
- * (depending on your configuration, LD_LIBRARY_PATH may need to contain <hdf5>/lib folder)
-#include "moab/ParallelComm.hpp"
-#include "MBParallelConventions.h"
-#include "moab/Core.hpp"
-#include <iostream>
-using namespace moab;
-int main(int argc, char **argv)
- MPI_Init(&argc, &argv);
- int nprocs, rank;
- MPI_Comm_size(MPI_COMM_WORLD, &nprocs);
- MPI_Comm_rank(MPI_COMM_WORLD, &rank);
- std::string filename;
- std::string options;
- if (3 != argc)
- if (rank == 0)
- std::cout << "Usage: " << argv[0] << " <filename><options (separated by;)>\n ";
- /* this file has a partition with 4 parts */
- filename = "../MeshFiles/unittest/disk.h5m";
- /* Options for reading
- * - read in parallel
- * - use PARALLEL_PARTITION tag
- * - resolve shared entities after reading
- options = "PARALLEL=READ_PART;PARTITION=PARALLEL_PARTITION;PARALLEL_RESOLVE_SHARED_ENTS";
- else
- filename = argv[1];
- options = argv[2];
- if (rank == 0)
- std::cout << "reading file " << filename << "\n with options:" << options <<
- "\n on " << nprocs << " processors\n";
- // get MOAB instance and read the file with the specified options
- Interface *mbImpl = new Core;
- if (NULL == mbImpl) return 1;
- ErrorCode rval = mbImpl->load_file(filename.c_str(), 0, options.c_str());
- if (rval != MB_SUCCESS) return 1;
- // get the ParallelComm instance
- ParallelComm* pcomm = ParallelComm::get_pcomm(mbImpl, 0);
- MPI_Comm comm = pcomm->comm();
- if (0 == pcomm) return 1;
- // get all shared entities with other processors
- Range shared_ents;
- rval = pcomm->get_shared_entities(-1, // -1 means all other processors Range &shared_ents,
- shared_ents);
- /* Among shared entities, get those owned by the current processor
- * For this, use a filter operation;
- * Each shared entity is owned by exactly one processor;
- * An entity could be simply-shared (with exactly one other processor) or
- * multi-shared.
- Range owned_entities;
- rval = pcomm->filter_pstatus(shared_ents, // pass entities that we want to filter
- PSTATUS_NOT_OWNED, // status we are looking for
- PSTATUS_NOT, // operation applied ; so it will return owned entities (!not_owned = owned)
- -1, // this means all processors
- &owned_entities);
- unsigned int nums[4]={0}; // to store the owned entities per dimension
- for (int i=0; i<3; i++)
- nums[i]=(int)owned_entities.num_of_dimension(i);
- int * rbuf;
- if (rank==0)
- rbuf = (int *)malloc(nprocs*4*sizeof(int));
- MPI_Gather( nums, 4, MPI_INT, rbuf, 4, MPI_INT, 0, comm);
- // print the stats gathered:
- if (rank == 0)
- for (int i=0; i<nprocs; i++)
- std::cout << " shared, owned entities on proc " << i << " :" << rbuf[4*i] << " verts, " <<
- rbuf[4*i+1] << " edges, " << rbuf[4*i+2] << " faces\n";
- * Now exchange 1 layer of ghost elements, using vertices as bridge
- * we could have done this as part of reading process, by passing an extra read option
- * ";PARALLEL_GHOSTS=2.0.1.0"
- rval = pcomm->exchange_ghost_cells(2, // int ghost_dim,
- 0, // int bridge_dim,
- 1, //int num_layers,
- 0, //int addl_ents,
- true); // bool store_remote_handles);
- // repeat the reports, after ghost exchange
- shared_ents.clear();
- owned_entities.clear();
- shared_ents);
- PSTATUS_NOT,
- -1,
- &owned_entities);
- // find out how many shared entities of each dimension are owned on this processor
- // gather the statistics on processor 0
- if (rank == 0)
- std::cout << " \n\n After exchanging one ghost layer: \n";
- free(rbuf);
- MPI_Finalize();
- return 0;
Repository URL: https://bitbucket.org/fathomteam/moab/
This is a commit notification from bitbucket.org. You are receiving
this because you have the service enabled, addressing the recipient of
this email.
