[MOAB-dev] commit/MOAB: tautges: Adding example implementation of Lloyd relaxation, in parallel.
commits-noreply at bitbucket.org
Sun Jul 28 22:54:42 CDT 2013
1 new commit in MOAB:
https://bitbucket.org/fathomteam/moab/commits/c36507e10554/
Changeset: c36507e10554
Branch: master
User: tautges
Date: 2013-07-29 05:54:30
Summary: Adding example implementation of Lloyd relaxation, in parallel.
Affected #: 2 files
diff --git a/examples/LloydRelaxation.cpp b/examples/LloydRelaxation.cpp
new file mode 100644
index 0000000..5c9321e
--- /dev/null
+++ b/examples/LloydRelaxation.cpp
@@ -0,0 +1,205 @@
+/** @example LloydRelaxation.cpp \n
+ * \brief Perform Lloyd relaxation on a mesh and its dual \n
+ * <b>To run</b>: mpiexec -np <np> LloydRelaxation [filename]\n
+ * Briefly, Lloyd relaxation is a technique to smooth out a mesh. The centroid of each cell is computed from its
+ * vertex positions, then vertices are placed at the average of their connected cells' centroids.
+ * In the parallel algorithm, an extra ghost layer of cells is exchanged. This allows us to compute the centroids
+ * for boundary cells on each processor where they appear; this eliminates the need for one round of data exchange
+ * (for those centroids) between processors. New vertex positions must be sent from owning processors to processors
+ * sharing those vertices. Convergence is measured as the maximum distance moved by any vertex.
+ * In this implementation, a fixed number of iterations is performed. The final mesh is output to 'lloydfinal.h5m'
+ * in the current directory (H5M format must be used since the file is written in parallel).
+#include "moab/ParallelComm.hpp"
+#include "MBParallelConventions.h"
+#include "moab/Core.hpp"
+#include "moab/Skinner.hpp"
+#include "moab/CN.hpp"
+#include "moab/CartVect.hpp"
+#include <iostream>
+#include <sstream>
+using namespace moab;
+using namespace std;
+string test_file_name = string(MESH_DIR) + string("/surfrandomtris.g");
+#define RC if (MB_SUCCESS != rval) return rval
+ErrorCode perform_lloyd_relaxation(ParallelComm *pc, Range &verts, Range &cells, Tag fixed, int num_its);
+int main(int argc, char **argv)
+ int num_its = 10;
+ MPI_Init(&argc, &argv);
+ // need option handling here for input filename
+ if (argc > 1){
+ //user has input a mesh file
+ test_file_name = argv[1];
+ // get MOAB and ParallelComm instances
+ Interface *mb = new Core;
+ if (NULL == mb) return 1;
+ // get the ParallelComm instance
+ ParallelComm* pcomm = new ParallelComm(mb, MPI_COMM_WORLD);
+ int nprocs = pcomm->size();
+ string options;
+ if (nprocs > 1) // if reading in parallel, need to tell it how
+ options = "PARALLEL=READ_PART;PARTITION=PARALLEL_PARTITION;PARALLEL_RESOLVE_SHARED_ENTS;PARALLEL_GHOSTS=2.0.1;DEBUG_IO=0;DEBUG_PIO=0";
+ // read the file
+ ErrorCode rval = mb->load_file(test_file_name.c_str(), 0, options.c_str()); RC;
+ // make tag to specify fixed vertices, since it's input to the algorithm; use a default value of non-fixed
+ // so we only need to set the fixed tag for skin vertices
+ Tag fixed;
+ int def_val = 0;
+ rval = mb->tag_get_handle("fixed", 1, MB_TYPE_INTEGER, fixed, MB_TAG_CREAT | MB_TAG_DENSE, &def_val); RC;
+ // get all vertices and faces
+ Range verts, faces, skin_verts;
+ rval = mb->get_entities_by_type(0, MBVERTEX, verts); RC;
+ rval = mb->get_entities_by_dimension(0, 2, faces); RC;
+ // get the skin vertices of those faces and mark them as fixed; we don't want to fix the vertices on a
+ // part boundary, but since we exchanged a layer of ghost faces, those vertices aren't on the skin locally
+ // ok to mark non-owned skin vertices too, I won't move those anyway
+ // use MOAB's skinner class to find the skin
+ Skinner skinner(mb);
+ rval = skinner.find_skin(faces, true, skin_verts); RC; // 'true' param indicates we want vertices back, not faces
+ std::vector<int> fix_tag(skin_verts.size(), 1); // initialized to 1 to indicate fixed
+ rval = mb->tag_set_data(fixed, skin_verts, &fix_tag[0]); RC;
+ // now perform the Lloyd relaxation
+ rval = perform_lloyd_relaxation(pcomm, verts, faces, fixed, num_its); RC;
+ // delete fixed tag, since we created it here
+ rval = mb->tag_delete(fixed); RC;
+ // output file, using parallel write
+ rval = mb->write_file("lloydfinal.h5m", NULL, "PARALLEL=WRITE_PART"); RC;
+ // delete MOAB instance
+ delete mb;
+ MPI_Finalize();
+ return 0;
+ErrorCode perform_lloyd_relaxation(ParallelComm *pcomm, Range &verts, Range &faces, Tag fixed, int num_its)
+ ErrorCode rval;
+ Interface *mb = pcomm->get_moab();
+ // perform Lloyd relaxation:
+ // 1. setup: set vertex centroids from vertex coords; filter to owned verts; get fixed tags
+ // get all verts coords into tag; don't need to worry about filtering out fixed verts,
+ // we'll just be setting to their fixed coords
+ std::vector<double> vcentroids(3*verts.size());
+ rval = mb->get_coords(verts, &vcentroids[0]); RC;
+ Tag centroid;
+ rval = mb->tag_get_handle("centroid", 3, MB_TYPE_DOUBLE, centroid, MB_TAG_CREAT | MB_TAG_DENSE); RC;
+ rval = mb->tag_set_data(centroid, verts, &vcentroids[0]); RC;
+ // filter verts down to owned ones and get fixed tag for them
+ Range owned_verts, shared_owned_verts;
+ if (nprocs > 1) {
+ rval = pcomm->filter_pstatus(verts, PSTATUS_NOT_OWNED, PSTATUS_NOT, -1, &owned_verts);
+ if (rval != MB_SUCCESS) return rval;
+ else
+ owned_verts = verts;
+ std::vector<int> fix_tag(owned_verts.size());
+ rval = mb->tag_get_data(fixed, owned_verts, &fix_tag[0]); RC;
+ // now fill vcentroids array with positions of just owned vertices, since those are the ones
+ // we're actually computing
+ vcentroids.resize(3*owned_verts.size());
+ rval = mb->tag_get_data(centroid, owned_verts, &vcentroids[0]); RC;
+ // get shared owned verts, for exchanging tags
+ rval = pcomm->get_shared_entities(-1, shared_owned_verts, 0, false, true); RC;
+ // workaround: if no shared owned verts, put a non-shared one in the list, to prevent exchanging tags
+ // for all shared entities
+ if (shared_owned_verts.empty()) shared_owned_verts.insert(*verts.begin());
+ // some declarations for later iterations
+ std::vector<double> fcentroids(3*faces.size()); // fcentroids for face centroids
+ std::vector<double> ctag(3*CN::MAX_NODES_PER_ELEMENT); // temporary coordinate storage for verts bounding a face
+ const EntityHandle *conn; // const ptr & size to face connectivity
+ int nconn;
+ Range::iterator fit, vit; // for iterating over faces, verts
+ int f, v; // for indexing into centroid vectors
+ std::vector<EntityHandle> adj_faces; // used in vertex iteration
+ // 2. for num_its iterations:
+ for (int nit = 0; nit < num_its; nit++) {
+ double mxdelta = 0.0;
+ // 2a. foreach face: centroid = sum(vertex centroids)/num_verts_in_cell
+ for (fit = faces.begin(), f = 0; fit != faces.end(); fit++, f++) {
+ // get verts for this face
+ rval = mb->get_connectivity(*fit, conn, nconn); RC;
+ // get centroid tags for those verts
+ rval = mb->tag_get_data(centroid, conn, nconn, &ctag[0]); RC;
+ fcentroids[3*f+0] = fcentroids[3*f+1] = fcentroids[3*f+2] = 0.0;
+ for (v = 0; v < nconn; v++) {
+ fcentroids[3*f+0] += ctag[3*v+0];
+ fcentroids[3*f+1] += ctag[3*v+1];
+ fcentroids[3*f+2] += ctag[3*v+2];
+ for (v = 0; v < 3; v++) fcentroids[3*f+v] /= nconn;
+ rval = mb->tag_set_data(centroid, faces, &fcentroids[0]); RC;
+ // 2b. foreach owned vertex:
+ for (vit = owned_verts.begin(), v = 0; vit != owned_verts.end(); vit++, v++) {
+ // if !fixed
+ if (fix_tag[v]) continue;
+ // vertex centroid = sum(cell centroids)/ncells
+ adj_faces.clear();
+ rval = mb->get_adjacencies(&(*vit), 1, 2, false, adj_faces); RC;
+ rval = mb->tag_get_data(centroid, &adj_faces[0], adj_faces.size(), &fcentroids[0]); RC;
+ double vnew[] = {0.0, 0.0, 0.0};
+ for (f = 0; f < (int)adj_faces.size(); f++) {
+ vnew[0] += fcentroids[3*f+0];
+ vnew[1] += fcentroids[3*f+1];
+ vnew[2] += fcentroids[3*f+2];
+ for (f = 0; f < 3; f++) vnew[f] /= adj_faces.size();
+ double delta = (CartVect(vnew)-CartVect(&vcentroids[3*v])).length();
+ mxdelta = std::max(delta, mxdelta);
+ for (f = 0; f < 3; f++) vcentroids[3*v+f] = vnew[f];
+ rval = mb->tag_set_data(centroid, owned_verts, &vcentroids[0]); RC;
+ cout << "Max delta = " << mxdelta << endl;
+ // 2c. exchange tags on owned verts
+ if (nprocs > 1) {
+ rval = pcomm->exchange_tags(centroid, shared_owned_verts); RC;
+ // write the tag back onto vertex coordinates
+ rval = mb->set_coords(owned_verts, &vcentroids[0]); RC;
+ // delete the centroid tag, since we don't need it anymore
+ rval = mb->tag_delete(centroid); RC;
+ return MB_SUCCESS;
diff --git a/examples/makefile b/examples/makefile
index d07b675..3b848d2 100644
--- a/examples/makefile
+++ b/examples/makefile
@@ -8,7 +8,7 @@ include ${MOAB_DIR}/lib/iMesh-Defs.inc
MESH_DIR="../MeshFiles/unittest"
EXAMPLES = HelloMOAB GetEntities SetsNTags StructuredMeshSimple DirectAccessWithHoles DirectAccessNoHoles
-PAREXAMPLES = HelloParMOAB ReduceExchangeTags
+PAREXAMPLES = HelloParMOAB ReduceExchangeTags LloydRelaxation
F90EXAMPLES = DirectAccessNoHolesF90
EXOIIEXAMPLES = TestExodusII
@@ -23,6 +23,9 @@ GetEntities: GetEntities.o
SetsNTags: SetsNTags.o
${MOAB_CXX} -o $@ $< ${MOAB_LIBS_LINK}
+LloydRelaxation: LloydRelaxation.o
+ ${MOAB_CXX} -o $@ $< ${MOAB_LIBS_LINK}
StructuredMeshSimple : StructuredMeshSimple.o
Repository URL: https://bitbucket.org/fathomteam/moab/
This is a commit notification from bitbucket.org. You are receiving
this because you have the service enabled, addressing the recipient of
this email.
