[MOAB-dev] commit/MOAB: tautges: Changing output formatting a bit.
commits-noreply at bitbucket.org
Sat Jul 27 22:02:04 CDT 2013
1 new commit in MOAB:
https://bitbucket.org/fathomteam/moab/commits/3f65886bbfef/
Changeset: 3f65886bbfef
Branch: master
User: tautges
Date: 2013-07-28 05:01:54
Summary: Changing output formatting a bit.
Affected #: 1 file
diff --git a/examples/HelloParMOAB.cpp b/examples/HelloParMOAB.cpp
index a4cf83e..75daeda 100644
--- a/examples/HelloParMOAB.cpp
+++ b/examples/HelloParMOAB.cpp
@@ -37,7 +37,7 @@ int main(int argc, char **argv)
MPI_Comm comm = pcomm->proc_config().proc_comm();
if (rank == 0)
- cout << "reading file " << test_file_name << "\n with options:" << options << endl
+ cout << "Reading file " << test_file_name << "\n with options: " << options << endl
<< " on " << nprocs << " processors\n";
ErrorCode rval = mb->load_file(test_file_name.c_str(), 0, options.c_str());
@@ -55,12 +55,12 @@ int main(int argc, char **argv)
unsigned int nums[4]={0}; // to store the owned entities per dimension
for (int i=0; i<4; i++) nums[i]=(int)owned_entities.num_of_dimension(i);
- std::vector<int> rbuf(nprocs*4, 0);
+ vector<int> rbuf(nprocs*4, 0);
MPI_Gather( nums, 4, MPI_INT, &rbuf[0], 4, MPI_INT, 0, MPI_COMM_WORLD);
// print the stats gathered:
if (rank == 0) {
for (int i=0; i<nprocs; i++)
- cout << " Shared, owned entities on proc " << i << " :" << rbuf[4*i] << " verts, " <<
+ cout << " Shared, owned entities on proc " << i << ": " << rbuf[4*i] << " verts, " <<
rbuf[4*i+1] << " edges, " << rbuf[4*i+2] << " faces, " << rbuf[4*i+3] << " elements" << endl;
@@ -92,7 +92,7 @@ int main(int argc, char **argv)
cout << " \n\n After exchanging one ghost layer: \n";
Repository URL: https://bitbucket.org/fathomteam/moab/
This is a commit notification from bitbucket.org. You are receiving
this because you have the service enabled, addressing the recipient of
this email.
