[MOAB-dev] commit/MOAB: tautges: - Adding HelloParMOAB.cpp test, removing HelloMoabPar (for name consistency)
commits-noreply at bitbucket.org
Sat Jul 27 21:48:12 CDT 2013
1 new commit in MOAB:
https://bitbucket.org/fathomteam/moab/commits/b2faa312e571/
Changeset: b2faa312e571
Branch: master
User: tautges
Date: 2013-07-28 04:43:47
Summary: - Adding HelloParMOAB.cpp test, removing HelloMoabPar (for name consistency)
- Adding partitioned 64bricks file
Affected #: 3 files
diff --git a/MeshFiles/unittest/64bricks_512hex_256part.h5m b/MeshFiles/unittest/64bricks_512hex_256part.h5m
new file mode 100644
index 0000000..d7df13c
Binary files /dev/null and b/MeshFiles/unittest/64bricks_512hex_256part.h5m differ
diff --git a/examples/HelloParMOAB.cpp b/examples/HelloParMOAB.cpp
index 0000000..a4cf83e
--- /dev/null
+++ b/examples/HelloParMOAB.cpp
@@ -0,0 +1,103 @@
+/** @example HelloParMOAB.cpp \n
+ * \brief Read mesh into MOAB and resolve/exchange/report shared and ghosted entities \n
+ * <b>To run</b>: mpiexec -np 4 HelloMoabPar [filename]\n
+#include "moab/ParallelComm.hpp"
+#include "MBParallelConventions.h"
+#include "moab/Core.hpp"
+#include <iostream>
+using namespace moab;
+using namespace std;
+string test_file_name = string(MESH_DIR) + string("/64bricks_512hex_256part.h5m");
+int main(int argc, char **argv)
+ MPI_Init(&argc, &argv);
+ string options;
+ // need option handling here for input filename
+ if (argc > 1){
+ //user has input a mesh file
+ test_file_name = argv[1];
+ options = "PARALLEL=READ_PART;PARTITION=PARALLEL_PARTITION;PARALLEL_RESOLVE_SHARED_ENTS";
+ // get MOAB instance and read the file with the specified options
+ Interface *mb = new Core;
+ if (NULL == mb) return 1;
+ // get the ParallelComm instance
+ ParallelComm* pcomm = new ParallelComm(mb, MPI_COMM_WORLD);
+ int nprocs = pcomm->proc_config().proc_size(), rank = pcomm->proc_config().proc_rank();
+ MPI_Comm comm = pcomm->proc_config().proc_comm();
+ if (rank == 0)
+ cout << "reading file " << test_file_name << "\n with options:" << options << endl
+ << " on " << nprocs << " processors\n";
+ ErrorCode rval = mb->load_file(test_file_name.c_str(), 0, options.c_str());
+ if (rval != MB_SUCCESS) return 1;
+ Range shared_ents;
+ // get entities shared with all other processors
+ rval = pcomm->get_shared_entities(-1, shared_ents);
+ // filter shared entities with not not_owned, which means owned
+ Range owned_entities;
+ rval = pcomm->filter_pstatus(shared_ents, PSTATUS_NOT_OWNED, PSTATUS_NOT, -1, &owned_entities);
+ unsigned int nums[4]={0}; // to store the owned entities per dimension
+ for (int i=0; i<4; i++) nums[i]=(int)owned_entities.num_of_dimension(i);
+ std::vector<int> rbuf(nprocs*4, 0);
+ MPI_Gather( nums, 4, MPI_INT, &rbuf[0], 4, MPI_INT, 0, MPI_COMM_WORLD);
+ // print the stats gathered:
+ if (rank == 0) {
+ for (int i=0; i<nprocs; i++)
+ cout << " Shared, owned entities on proc " << i << " :" << rbuf[4*i] << " verts, " <<
+ rbuf[4*i+1] << " edges, " << rbuf[4*i+2] << " faces, " << rbuf[4*i+3] << " elements" << endl;
+ // Now exchange 1 layer of ghost elements, using vertices as bridge
+ // (we could have done this as part of reading process, using the PARALLEL_GHOSTS read option)
+ rval = pcomm->exchange_ghost_cells(3, // int ghost_dim,
+ 0, // int bridge_dim,
+ 1, //int num_layers,
+ 0, //int addl_ents,
+ true); // bool store_remote_handles);
+ // repeat the reports, after ghost exchange
+ shared_ents.clear();
+ owned_entities.clear();
+ // find out how many shared entities of each dimension are owned on this processor
+ nums[i]=(int)owned_entities.num_of_dimension(i);
+ // gather the statistics on processor 0
+ MPI_Gather( nums, 4, MPI_INT, &rbuf[0], 4, MPI_INT, 0, comm);
+ if (rank == 0)
+ cout << " \n\n After exchanging one ghost layer: \n";
+ MPI_Finalize();
+ return 0;
diff --git a/examples/makefile b/examples/makefile
index 34b8c3c..d07b675 100644
--- a/examples/makefile
+++ b/examples/makefile
@@ -38,7 +38,7 @@ DirectAccessNoHolesF90: DirectAccessNoHolesF90.o
ReduceExchangeTags : ReduceExchangeTags.o
${MOAB_CXX} -o $@ $< ${MOAB_LIBS_LINK}
-HelloMoabPar: HelloMoabPar.o
+HelloParMOAB: HelloParMOAB.o
TestExodusII: TestExodusII.o
Repository URL: https://bitbucket.org/fathomteam/moab/
This is a commit notification from bitbucket.org. You are receiving
this because you have the service enabled, addressing the recipient of
this email.
