[MOAB-dev] errors in mbcoupler test
Tim Tautges tautges at mcs.anl.gov
Tue Jul 16 12:25:19 CDT 2013
Did you configure and install your own version of hdf5?  Usually, when I do that, I put it somewhere besides /usr/local,
e.g. /usr/local/hdf5serial or something (same with MOAB, by the way).  The configure option --with-hdf5 will just look
in system space for hdf5, and if you still have the system (serial) version of hdf5 that will fail.
Will keep looking at configure.log for other stuff, but the above I noticed right away...
- tim
On 07/16/2013 11:35 AM, Sevag Doniguian wrote:
> The config.log file is attached.
> - Sevag
> On Tue, Jul 16, 2013 at 11:22 AM, Tim Tautges <tautges at mcs.anl.gov <mailto:tautges at mcs.anl.gov>> wrote:
>     We need the configure line you're using for MOAB and probably info about what MPI you're using.  Actually, sending
>     config.log from your MOAB configure will have all that info.
>     - tim
>     On 07/16/2013 11:16 AM, Sevag Doniguian wrote:
>         Hello
>         I tried running mbcoupler test and got the following error, just wandering if this happened to anyone before,
>         and how it
>         can be fixed.
>         FAIL: mbcoupler_test (exit: 1)
>         Mesh files not entered; using default files ../../MeshFiles/unittest/__64bricks_1khex.h5m and
>         ../../MeshFiles/unittest/__64bricks_12ktet.h5m
>         Interpolation field name not given, using default of vertex_field
>         No arguments given; using output file dum.h5m.
>         Fatal error in MPI_Info_dup: Invalid argument, error stack:
>         MPI_Info_dup(127): MPI_Info_dup(MPI_INFO_NULL, newinfo=0x7fff6402c568) failed
>         MPI_Info_dup(66).: Null MPI_Info
>         HDF5: infinite loop closing library
>         D,T,AC,FD,P,FD,P,FD,P,FD,FD,__FD,FD,FD,FD,FD,FD,FD,FD,FD,FD,__FD,FD,FD,FD,FD,FD,FD,FD,FD,FD,__FD,FD,FD,FD,FD,FD,FD,FD,FD,FD,__FD,FD,FD,FD,FD,FD,FD,FD,FD,FD,__FD,FD,FD,FD,FD,FD,FD,FD,FD,FD,__FD,FD,FD,FD,FD,FD,FD,FD,FD,FD,__FD,FD,FD,FD,FD,FD,FD,FD,FD,FD,__FD,FD,FD,FD,FD,FD,FD,FD,FD,FD,__FD,FD,FD,FD,FD,FD,FD,FD,FD,FD,__FD,FD,FD,FD,FD
>         thank you for your time,
>         Best Regards,
>         Sevag Donikian
>     ==============================__==============================__====
>     "You will keep in perfect peace him whose mind is
>        steadfast, because he trusts in you."               Isaiah 26:3
>                   Tim Tautges            Argonne National Laboratory
>               (tautges at mcs.anl.gov <mailto:tautges at mcs.anl.gov>)      (telecommuting from UW-Madison)
>       phone (gvoice): (608) 354-1459 <tel:%28608%29%20354-1459>      1500 Engineering Dr.
>                  fax: (608) 263-4499 <tel:%28608%29%20263-4499>      Madison, WI 53706
          (tautges at mcs.anl.gov)      (telecommuting from UW-Madison)
  phone (gvoice): (608) 354-1459      1500 Engineering Dr.
             fax: (608) 263-4499      Madison, WI 53706
