[MOAB-dev] errors in mbcoupler test
    Tim Tautges
    tautges at mcs.anl.gov
    Tue Jul 16 12:34:22 CDT 2013
Hmm, config.log looks fine to me.  The one thing that looks strange in your output is:
 >         Mesh files not entered; using default files ../../MeshFiles/unittest/__64bricks_1khex.h5m and
 >         ../../MeshFiles/unittest/__64bricks_12ktet.h5m
 >         Interpolation field name not given, using default of vertex_field
In particular, the double-underscore at the front of the filename; my output looks like:
Mesh files not entered; using default files ../../../MOABclean/MeshFiles/unittest/64bricks_1khex.h5m and
../../../MOABclean/MeshFiles/unittest/64bricks_12ktet.h5m
Are there modifications in your source that added those underscores by mistake?
- tim
On 07/16/2013 11:35 AM, Sevag Doniguian wrote:
> The config.log file is attached.
> - Sevag
> On Tue, Jul 16, 2013 at 11:22 AM, Tim Tautges <tautges at mcs.anl.gov <mailto:tautges at mcs.anl.gov>> wrote:
>     We need the configure line you're using for MOAB and probably info about what MPI you're using.  Actually, sending
>     config.log from your MOAB configure will have all that info.
>     - tim
>     On 07/16/2013 11:16 AM, Sevag Doniguian wrote:
>         Hello
>         I tried running mbcoupler test and got the following error, just wandering if this happened to anyone before,
>         and how it
>         can be fixed.
>         FAIL: mbcoupler_test (exit: 1)
>         No arguments given; using output file dum.h5m.
>         Fatal error in MPI_Info_dup: Invalid argument, error stack:
>         MPI_Info_dup(127): MPI_Info_dup(MPI_INFO_NULL, newinfo=0x7fff6402c568) failed
>         MPI_Info_dup(66).: Null MPI_Info
>         HDF5: infinite loop closing library
>         D,T,AC,FD,P,FD,P,FD,P,FD,FD,__FD,FD,FD,FD,FD,FD,FD,FD,FD,FD,__FD,FD,FD,FD,FD,FD,FD,FD,FD,FD,__FD,FD,FD,FD,FD,FD,FD,FD,FD,FD,__FD,FD,FD,FD,FD,FD,FD,FD,FD,FD,__FD,FD,FD,FD,FD,FD,FD,FD,FD,FD,__FD,FD,FD,FD,FD,FD,FD,FD,FD,FD,__FD,FD,FD,FD,FD,FD,FD,FD,FD,FD,__FD,FD,FD,FD,FD,FD,FD,FD,FD,FD,__FD,FD,FD,FD,FD,FD,FD,FD,FD,FD,__FD,FD,FD,FD,FD
>         thank you for your time,
>         Best Regards,
>         Sevag Donikian
>     ==============================__==============================__====
>     "You will keep in perfect peace him whose mind is
>        steadfast, because he trusts in you."               Isaiah 26:3
>                   Tim Tautges            Argonne National Laboratory
>               (tautges at mcs.anl.gov <mailto:tautges at mcs.anl.gov>)      (telecommuting from UW-Madison)
>       phone (gvoice): (608) 354-1459 <tel:%28608%29%20354-1459>      1500 Engineering Dr.
>                  fax: (608) 263-4499 <tel:%28608%29%20263-4499>      Madison, WI 53706
          (tautges at mcs.anl.gov)      (telecommuting from UW-Madison)
  phone (gvoice): (608) 354-1459      1500 Engineering Dr.
             fax: (608) 263-4499      Madison, WI 53706
