[MOAB-dev] errors in mbcoupler test
Sevag Doniguian szd03imail at gmail.com
Tue Jul 16 11:35:51 CDT 2013
The config.log file is attached.
- Sevag
On Tue, Jul 16, 2013 at 11:22 AM, Tim Tautges <tautges at mcs.anl.gov> wrote:
> We need the configure line you're using for MOAB and probably info about
> what MPI you're using.  Actually, sending config.log from your MOAB
> configure will have all that info.
> - tim
> On 07/16/2013 11:16 AM, Sevag Doniguian wrote:
>> Hello
>> I tried running mbcoupler test and got the following error, just
>> wandering if this happened to anyone before, and how it
>> can be fixed.
>> FAIL: mbcoupler_test (exit: 1)
>> Mesh files not entered; using default files ../../MeshFiles/unittest/**64bricks_1khex.h5m
>> and
>> ../../MeshFiles/unittest/**64bricks_12ktet.h5m
>> Interpolation field name not given, using default of vertex_field
>> No arguments given; using output file dum.h5m.
>> Fatal error in MPI_Info_dup: Invalid argument, error stack:
>> MPI_Info_dup(127): MPI_Info_dup(MPI_INFO_NULL, newinfo=0x7fff6402c568)
>> failed
>> MPI_Info_dup(66).: Null MPI_Info
>> HDF5: infinite loop closing library
>> D,T,AC,FD,P,FD,P,FD,P,FD,FD,**FD,FD,FD,FD,FD,FD,FD,FD,FD,FD,**
>> FD,FD,FD,FD,FD,FD,FD,FD,FD,FD,**FD,FD,FD,FD,FD,FD,FD,FD,FD,FD,**
>> FD,FD,FD,FD,FD
>> thank you for your time,
>> Best Regards,
>> Sevag Donikian
> "You will keep in perfect peace him whose mind is
>   steadfast, because he trusts in you."               Isaiah 26:3
>              Tim Tautges            Argonne National Laboratory
>          (tautges at mcs.anl.gov)      (telecommuting from UW-Madison)
>  phone (gvoice): (608) 354-1459      1500 Engineering Dr.
>             fax: (608) 263-4499      Madison, WI 53706
URL: <http://lists.mcs.anl.gov/pipermail/moab-dev/attachments/20130716/6c160d8d/attachment-0001.html>
Desc: not available
URL: <http://lists.mcs.anl.gov/pipermail/moab-dev/attachments/20130716/6c160d8d/attachment-0001.obj>
