[MOAB-dev] errors in mbcoupler test
Tim Tautges tautges at mcs.anl.gov
Tue Jul 16 11:22:13 CDT 2013
We need the configure line you're using for MOAB and probably info about what MPI you're using.  Actually, sending
config.log from your MOAB configure will have all that info.
- tim
On 07/16/2013 11:16 AM, Sevag Doniguian wrote:
> Hello
> I tried running mbcoupler test and got the following error, just wandering if this happened to anyone before, and how it
> can be fixed.
> FAIL: mbcoupler_test (exit: 1)
> Mesh files not entered; using default files ../../MeshFiles/unittest/64bricks_1khex.h5m and
> ../../MeshFiles/unittest/64bricks_12ktet.h5m
> Interpolation field name not given, using default of vertex_field
> No arguments given; using output file dum.h5m.
> Fatal error in MPI_Info_dup: Invalid argument, error stack:
> MPI_Info_dup(127): MPI_Info_dup(MPI_INFO_NULL, newinfo=0x7fff6402c568) failed
> MPI_Info_dup(66).: Null MPI_Info
> HDF5: infinite loop closing library
> D,T,AC,FD,P,FD,P,FD,P,FD,FD,FD,FD,FD,FD,FD,FD,FD,FD,FD,FD,FD,FD,FD,FD,FD,FD,FD,FD,FD,FD,FD,FD,FD,FD,FD,FD,FD,FD,FD,FD,FD,FD,FD,FD,FD,FD,FD,FD,FD,FD,FD,FD,FD,FD,FD,FD,FD,FD,FD,FD,FD,FD,FD,FD,FD,FD,FD,FD,FD,FD,FD,FD,FD,FD,FD,FD,FD,FD,FD,FD,FD,FD,FD,FD,FD,FD,FD,FD,FD,FD,FD,FD,FD,FD,FD,FD,FD,FD,FD,FD,FD,FD,FD,FD,FD
> thank you for your time,
> Best Regards,
> Sevag Donikian
   steadfast, because he trusts in you."               Isaiah 26:3
              Tim Tautges            Argonne National Laboratory
          (tautges at mcs.anl.gov)      (telecommuting from UW-Madison)
  phone (gvoice): (608) 354-1459      1500 Engineering Dr.
             fax: (608) 263-4499      Madison, WI 53706
