[MOAB-dev] commit/MOAB: vijaysm: Various fixes to the CMake build system.
commits-noreply at bitbucket.org
Fri Jul 12 19:20:54 CDT 2013
1 new commit in MOAB:
https://bitbucket.org/fathomteam/moab/commits/66da1468f39a/
Changeset: 66da1468f39a
Branch: master
User: vijaysm
Date: 2013-07-13 02:20:23
Summary: Various fixes to the CMake build system.
1) Moving MPI check to root
2) Adding the CMakeLists file in itaps/imesh
3) Adding appropriate source, include, link commands for MOAB, MOABPar, iMesh, mhdf libraries
4) Adding and verifying the compilation/linkage of tools. Currently only MOABRefiner and MBCoupler are configured. Need to add configuration for all other tools.
5) List of files created in bin after full compilation:
bsp_tree_test* homxform_test* libMOABpar.a libiMesh.dylib* libmhdf.dylib* mbparallelcomm_test* moab_test* scdseq_test* ssn_test* test_mesh_refiner*
findpt_test* libMOAB.dylib* libMOABrefiner.dylib* libmbcoupler.dylib* mbcoupler_test* mhdf_parallel* parallel_unit_tests* seq_man_test* tag_test* tqdcfr*
Affected #: 7 files
diff --git a/CMakeLists.txt b/CMakeLists.txt
index 3774046..007d501 100644
--- a/CMakeLists.txt
+++ b/CMakeLists.txt
@@ -100,7 +100,30 @@ project( MOAB )
# iMesh
option ( MOAB_BUILD_IMESH "Build the iMesh interface?" ON )
+ # check for MPI package
+ if ( MOAB_USE_MPI )
+ find_package( MPI )
+ # CMake FindMPI script is sorely lacking:
+ if ( MPI_LIBRARY AND MPI_INCLUDE_PATH )
+ set( MPI_FOUND 1 )
+ endif ( MPI_LIBRARY AND MPI_INCLUDE_PATH )
+ if ( MPI_FOUND )
+ set ( MOAB_DEFINES "${MOAB_DEFINES} -DUSE_MPI" )
+ endif ( MPI_FOUND )
+ endif ( MOAB_USE_MPI )
+ if ( MOAB_USE_NETCDF )
+ find_package( NetCDF )
+ endif ( MOAB_USE_NETCDF )
+ if ( MOAB_USE_HDF )
+ # HDF5
+ find_package( HDF5 )
+ endif ( MOAB_USE_HDF )
add_subdirectory( src )
+ add_subdirectory( itaps/imesh )
add_subdirectory( tools )
add_subdirectory( test )
diff --git a/itaps/imesh/CMakeLists.txt b/itaps/imesh/CMakeLists.txt
index a258e9f..5bba3f0 100644
--- a/itaps/imesh/CMakeLists.txt
+++ b/itaps/imesh/CMakeLists.txt
@@ -1,60 +1,61 @@
# Generate Fortran name mangling headers
-ADD_CUSTOM_COMMAND(
+ADD_CUSTOM_COMMAND(
OUTPUT ${CMAKE_CURRENT_BINARY_DIR}/iMesh_protos.h
- COMMAND ${CMAKE_COMMAND}
- -Dinput_file:STRING=${CMAKE_CURRENT_SOURCE_DIR}/iMesh.h
- -Doutput_file:STRING=${CMAKE_CURRENT_BINARY_DIR}/iMesh_protos.h
- -Dprefix:STRING=iMesh
- -P ${CMAKE_SOURCE_DIR}/cmake/ITAPSFortranMangling.cmake
+ COMMAND ${CMAKE_COMMAND}
+ -Dinput_file:STRING=${CMAKE_CURRENT_SOURCE_DIR}/iMesh.h
+ -Doutput_file:STRING=${CMAKE_CURRENT_BINARY_DIR}/iMesh_protos.h
+ -Dprefix:STRING=iMesh
+ -P ${CMAKE_SOURCE_DIR}/config/ITAPSFortranMangling.cmake
DEPENDS ${CMAKE_CURRENT_SOURCE_DIR}/iMesh.h
OUTPUT ${CMAKE_CURRENT_BINARY_DIR}/iMesh_extensions_protos.h
- -Dinput_file:STRING=${CMAKE_CURRENT_SOURCE_DIR}/iMesh_extensions.h
- -Doutput_file:STRING=${CMAKE_CURRENT_BINARY_DIR}/iMesh_extensions_protos.h
+ -Dinput_file:STRING=${CMAKE_CURRENT_SOURCE_DIR}/iMesh_extensions.h
+ -Doutput_file:STRING=${CMAKE_CURRENT_BINARY_DIR}/iMesh_extensions_protos.h
DEPENDS ${CMAKE_CURRENT_SOURCE_DIR}/iMesh_extensions.h
OUTPUT ${CMAKE_CURRENT_BINARY_DIR}/iMeshP_protos.h
- -Dinput_file:STRING=${CMAKE_CURRENT_SOURCE_DIR}/iMeshP.h
- -Doutput_file:STRING=${CMAKE_CURRENT_BINARY_DIR}/iMeshP_protos.h
- -Dprefix:STRING=iMeshP
+ -Dinput_file:STRING=${CMAKE_CURRENT_SOURCE_DIR}/iMeshP.h
+ -Doutput_file:STRING=${CMAKE_CURRENT_BINARY_DIR}/iMeshP_protos.h
+ -Dprefix:STRING=iMeshP
DEPENDS ${CMAKE_CURRENT_SOURCE_DIR}/iMeshP.h
-set ( MOAB_IMESH_SRCS
+set ( MOAB_IMESH_SRCS
iMesh_MOAB.cpp
${CMAKE_CURRENT_BINARY_DIR}/iMeshP_protos.h )
+include_directories(
+ ${MOAB_SOURCE_DIR}/src
+ ${MOAB_SOURCE_DIR}/itaps
+ ${MOAB_SOURCE_DIR}/itaps/imesh
if ( MOAB_USE_MPI AND MPI_FOUND )
- LIST ( APPEND MOAB_IMESH_SRCS
+ LIST ( APPEND MOAB_IMESH_SRCS
iMeshP_MOAB.cpp
+ include_directories(
+ ${MOAB_SOURCE_DIR}/src/parallel
endif ( MOAB_USE_MPI AND MPI_FOUND )
-include_directories( ${CMAKE_SOURCE_DIR}
- ${CMAKE_BINARY_DIR}
- ${CMAKE_SOURCE_DIR}/parallel
- ${CMAKE_BINARY_DIR}/parallel
- ${CMAKE_CURRENT_SOURCE_DIR}
- ${CMAKE_CURRENT_BINARY_DIR}
-set_source_files_properties(
- ${MOAB_IMESH_SRCS}
+set_source_files_properties( ${MOAB_IMESH_SRCS}
COMPILE_FLAGS "${MOAB_DEFINES}"
add_library( iMesh
${MOAB_IMESH_SRCS}
+target_link_libraries( iMesh MOAB )
diff --git a/src/CMakeLists.txt b/src/CMakeLists.txt
index 65862a8..c5467e6 100644
--- a/src/CMakeLists.txt
+++ b/src/CMakeLists.txt
@@ -1,6 +1,6 @@
# MOAB Library
- set ( MOAB_LIB_SRCS
+ set ( MOABCORE_LIB_SRCS
AdaptiveKDTree.cpp
AEntityFactory.cpp
AffineXform.cpp
@@ -31,7 +31,6 @@
PolyElementSeq.cpp
Range.cpp
RangeSeqIntersectIter.cpp
- ReaderWriterSet.cpp
ReadUtil.cpp
ScdElementData.cpp
ScdInterface.cpp
@@ -57,6 +56,13 @@
WriteUtil.cpp
+ set ( MOABPTLOC_LIB_SRCS
+ lotte/findpt.c
+ lotte/errmem.c
+ lotte/poly.c
+ lotte/tensor.c
set ( MOABIO_LIB_SRCS
io/IODebugTrack.cpp
io/ExoIIUtil.cpp
@@ -64,6 +70,7 @@
io/GmshUtil.cpp
io/ReadABAQUS.cpp
io/ReadGmsh.cpp
+ io/ReadGCRM.cpp
io/ReadIDEAS.cpp
io/ReadMCNP5.cpp
io/ReadNASTRAN.cpp
@@ -84,87 +91,61 @@
io/WriteSmf.cpp
io/WriteTemplate.cpp
io/WriteVtk.cpp
+ ReaderWriterSet.cpp
${MOAB_SOURCE_DIR}/src/io
+ ${MOAB_SOURCE_DIR}/src/moab/point_locater/lotte
- if ( MOAB_USE_MPI )
- find_package( MPI )
- # CMake FindMPI script is sorely lacking:
- if ( MPI_LIBRARY AND MPI_INCLUDE_PATH )
- set( MPI_FOUND 1 )
- endif ( MPI_LIBRARY AND MPI_INCLUDE_PATH )
- if ( MPI_FOUND )
- set ( MOAB_DEFINES "${MOAB_DEFINES} -DUSE_MPI" )
- include_directories(
- ${MPI_INCLUDE_PATH}
- ${MOAB_SOURCE_DIR}/parallel
- endif ( MPI_FOUND )
- endif ( MOAB_USE_MPI )
+ if ( NetCDF_FOUND )
+ set ( MOAB_DEFINES "${MOAB_DEFINES} -DNETCDF_FILE" )
+ set ( MOABIO_LIB_SRCS
+ ${MOABIO_LIB_SRCS}
+ io/ReadNC.cpp
+ io/ReadNCDF.cpp
+ io/WriteNCDF.cpp
+ io/WriteSLAC.cpp
+ io/NCHelper.cpp
+ io/NCHelperEuler.cpp
+ io/NCHelperFV.cpp
+ io/NCHelperHOMME.cpp
+ SpectralMeshTool.cpp
+ ${NetCDF_INCLUDE_DIRECTORIES}
+ endif ( NetCDF_FOUND )
+ if ( HDF5_FOUND )
+ set ( MOAB_DEFINES "${MOAB_DEFINES} -DHDF5_FILE" )
+ check_function_exists( H5Pset_fapl_mpio MOAB_HDF_HAVE_PARALLEL )
+ io/HDF5Common.cpp
+ io/ReadHDF5.cpp
+ io/ReadHDF5Dataset.cpp
+ io/ReadHDF5VarLen.cpp
+ io/WriteHDF5.cpp
+ ${HDF5_INCLUDE_DIRECTORIES}
+ io/mhdf/include
+ add_subdirectory( io/mhdf )
+ endif ( HDF5_FOUND )
+ SET(MOAB_LIB_SRCS ${MOABCORE_LIB_SRCS} ${MOABPTLOC_LIB_SRCS} ${MOABIO_LIB_SRCS})
set_source_files_properties( ${MOAB_LIB_SRCS}
COMPILE_FLAGS "-DIS_BUILDING_MB ${MOAB_DEFINES}"
-# target_link_libraries( MOAB moabio )
- if ( MOAB_USE_NETCDF )
- find_package( NetCDF )
- if ( NetCDF_FOUND )
- set ( MOAB_DEFINES "${MOAB_DEFINES} -DNETCDF_FILE" )
- set ( MOABIO_LIB_SRCS
- ${MOABIO_LIB_SRCS}
- io/ReadNCDF.cpp
- io/WriteNCDF.cpp
- io/WriteSLAC.cpp
- ${NetCDF_INCLUDE_DIRECTORIES}
- endif ( NetCDF_FOUND )
- endif ( MOAB_USE_NETCDF )
- if ( MOAB_USE_HDF )
- # HDF5
- find_package( HDF5 )
- if ( HDF5_FOUND )
- set ( MOAB_DEFINES "${MOAB_DEFINES} -DHDF5_FILE" )
- check_function_exists( H5Pset_fapl_mpio MOAB_HDF_HAVE_PARALLEL )
- io/HDF5Common.cpp
- io/ReadHDF5.cpp
- io/ReadHDF5Dataset.cpp
- io/ReadHDF5VarLen.cpp
- io/WriteHDF5.cpp
-# if ( MOAB_USE_MPI AND MPI_FOUND )
-# set ( MOABIO_LIB_SRCS
-# ${MOABIO_LIB_SRCS}
-# src/parallel/WriteHDF5Parallel.cpp
-# endif (MOAB_USE_MPI AND MPI_FOUND)
- ${HDF5_INCLUDE_DIRECTORIES}
- io/mhdf/include
- add_subdirectory( io/mhdf )
- endif ( HDF5_FOUND )
- endif ( MOAB_USE_HDF )
- set_source_files_properties( ${MOABIO_LIB_SRCS}
- COMPILE_FLAGS "-DIS_BUILDING_MB ${MOAB_DEFINES}"
add_library( MOAB
${MOAB_LIB_SRCS}
if ( MOAB_USE_NETCDF AND NetCDF_FOUND )
diff --git a/test/CMakeLists.txt b/test/CMakeLists.txt
index 3b1d28d..e6c2d94 100644
--- a/test/CMakeLists.txt
+++ b/test/CMakeLists.txt
@@ -43,9 +43,9 @@
- add_executable ( mbparallelcomm_test mbparallelcomm_test.cpp )
+ add_executable ( mbparallelcomm_test parallel/mbparallelcomm_test.cpp )
target_link_libraries( mbparallelcomm_test MOAB )
- set_source_files_properties( mbparallelcomm_test.cpp
+ set_source_files_properties( parallel/mbparallelcomm_test.cpp
COMPILE_FLAGS "-DIS_BUILDING_MB ${MOAB_DEFINES}" )
add_test( TestParallelComm-BcastDelete
${MPIEXEC} ${MPIEXEC_NUMPROC_FLAG} 2 ${MPIEXEC_PREFLAGS}
@@ -61,19 +61,22 @@ if ( MOAB_USE_MPI AND MPI_FOUND )
${EXECUTABLE_OUTPUT_PATH}/mbparallelcomm_test ${MPIEXEC_POSTFLAGS} -3 ${MOAB_SOURCE_DIR}/parallel/ptest.cub )
if ( MOAB_USE_HDF )
- add_executable( mhdf_parallel mhdf_parallel.c )
+ add_executable( mhdf_parallel parallel/mhdf_parallel.c )
+ ${MOAB_SOURCE_DIR}/src/io/mhdf/include
target_link_libraries( mhdf_parallel MOAB MOABpar mhdf )
add_test( TestMHDFParallel ${EXECUTABLE_OUTPUT_PATH}/mhdf_parallel )
- set_source_files_properties( mhdf_parallel.c
+ set_source_files_properties( parallel/mhdf_parallel.c
- add_executable ( parallel_unit_tests parallel_unit_tests.cpp )
+ add_executable ( parallel_unit_tests parallel/parallel_unit_tests.cpp )
target_link_libraries( parallel_unit_tests MOAB )
${EXECUTABLE_OUTPUT_PATH}/parallel_unit_tests ${MPIEXEC_POSTFLAGS} ${MOAB_SOURCE_DIR}/parallel/ptest.cub )
- set_source_files_properties( parallel_unit_tests.cpp
+ set_source_files_properties( parallel/parallel_unit_tests.cpp
diff --git a/tools/CMakeLists.txt b/tools/CMakeLists.txt
index 1f30dcf..56e115c 100644
--- a/tools/CMakeLists.txt
+++ b/tools/CMakeLists.txt
@@ -1,4 +1,4 @@
# Documentation
# Optional tools
option ( MOAB_BUILD_MBCONVERT "Build the MOAB mesh converter tool?" ON )
@@ -17,8 +17,8 @@
add_subdirectory( refiner )
- include_directories( ${MOAB_SOURCE_DIR}/refiner )
- target_link_libraries( MOAB MOABrefiner )
+# include_directories( ${MOAB_SOURCE_DIR}/refiner )
+# target_link_libraries( MOAB MOABrefiner )
@@ -37,5 +37,6 @@
# MBCoupler
if ( MOAB_USE_MPI AND MPI_FOUND AND MOAB_BUILD_MBCOUPLER )
+# if ( MOAB_BUILD_MBCOUPLER )
add_subdirectory( mbcoupler )
endif ( MOAB_USE_MPI AND MPI_FOUND AND MOAB_BUILD_MBCOUPLER )
diff --git a/tools/mbcoupler/CMakeLists.txt b/tools/mbcoupler/CMakeLists.txt
index 93e97d1..9c4279d 100644
--- a/tools/mbcoupler/CMakeLists.txt
+++ b/tools/mbcoupler/CMakeLists.txt
@@ -1,26 +1,29 @@
- ${CMAKE_CURRENT_SOURCE_DIRECTORY}
+ ${MOAB_SOURCE_DIR}/tools/mbcoupler
set( MBCOUPLER_SRCS
Coupler.cpp
ElemUtil.cpp
- errmem.cpp
- findpt.c
- poly.c
- tensor.c
+set_source_files_properties( ${MBCOUPLER_SRCS}
+ COMPILE_FLAGS "${MOAB_DEFINES}"
add_library( mbcoupler
${MBCOUPLER_SRCS}
-target_link_libraries( mbcoupler MOAB )
+target_link_libraries( mbcoupler MOAB iMesh )
if ( MOAB_USE_MPI )
target_link_libraries( mbcoupler MOABpar )
-set_source_files_properties( ${MBCOUPLER_SRCS}
- COMPILE_FLAGS "${MOAB_DEFINES}"
enable_testing()
@@ -39,4 +42,10 @@ if ( MOAB_USE_MPI )
COMPILE_FLAGS "${MOAB_DEFINES}" )
target_link_libraries( mbcoupler_test mbcoupler MOAB MOABpar )
add_test( TestMBCoupler ${EXECUTABLE_OUTPUT_PATH}/mbcoupler_test )
+ add_executable( ssn_test ssn_test.cpp )
+ set_source_files_properties( ssn_test.cpp
+ COMPILE_FLAGS "${MOAB_DEFINES}" )
+ target_link_libraries( ssn_test mbcoupler MOAB MOABpar )
+ add_test( TestMBCoupler ${EXECUTABLE_OUTPUT_PATH}/ssn_test )
diff --git a/tools/refiner/CMakeLists.txt b/tools/refiner/CMakeLists.txt
index 5c41c27..230b34c 100644
--- a/tools/refiner/CMakeLists.txt
+++ b/tools/refiner/CMakeLists.txt
@@ -1,4 +1,4 @@
-set ( MOAB_REFINER_SRCS
+set ( MOAB_REFINER_SRCS
EdgeSizeEvaluator.cpp
EdgeSizeSimpleImplicit.cpp
EntityRefiner.cpp
@@ -11,6 +11,11 @@ set ( MOAB_REFINER_SRCS
SplitVertices.cpp
${MOAB_REFINER_SRCS}
@@ -19,6 +24,10 @@ set_source_files_properties(
add_library( MOABrefiner
+target_link_libraries( MOABrefiner MOAB )
+if ( MOAB_USE_MPI )
+ target_link_libraries( MOABrefiner MOABpar )
+endif ( MOAB_USE_MPI )
enable_testing()
@@ -26,6 +35,7 @@ add_executable( test_mesh_refiner test_mesh_refiner.cpp )
set_source_files_properties( test_mesh_refiner.cpp
COMPILE_FLAGS "-DTEST ${MOAB_DEFINES}" )
target_link_libraries( test_mesh_refiner MOAB MOABrefiner )
add_test( TestMeshRefiner
${MPIEXEC} ${MPIEXEC_NUMPROC_FLAG} 4 ${MPIEXEC_PREFLAGS}
${EXECUTABLE_OUTPUT_PATH}/test_mesh_refiner ${MPIEXEC_POSTFLAGS}
Repository URL: https://bitbucket.org/fathomteam/moab/
This is a commit notification from bitbucket.org. You are receiving
this because you have the service enabled, addressing the recipient of
this email.
