[MOAB-dev] Problems with MB Coupler
Iulian Grindeanu
iulian at mcs.anl.gov
Thu Jul 11 12:39:10 CDT 2013
----- Original Message -----
| Dear MOAB dev team,
| when running the configure command on moabcoupler, I see the
| following error
| * MOAB has been configured with parallel and HDF5 support
| * but the configured HDF5 library does not support parallel IO.
| * Some parallel IO capabilities will be disabled.
You need to build hdf5 with parallel enabled; use the same mpi library
| what libraries do I need to install to fix this ?
| also when I run the "make check" command, the mbcoupler_test fails
| with the error:
| Failure; message:
| NULL file handle.
| could this be due to the first problem?
probably
| Thank you for your time and support,
| Best Regards,
| Sevag Doniguian
URL: <http://lists.mcs.anl.gov/pipermail/moab-dev/attachments/20130711/43a544e8/attachment.html>
