[MOAB-dev] Problems with MB Coupler
Sevag Doniguian
szd03imail at gmail.com
Thu Jul 11 12:34:30 CDT 2013
Dear MOAB dev team,
when running the configure command on moabcoupler, I see the following error
* MOAB has been configured with parallel and HDF5 support
* but the configured HDF5 library does not support parallel IO.
* Some parallel IO capabilities will be disabled.
what libraries do I need to install to fix this ?
also when I run the "make check" command, the mbcoupler_test fails with the
error:
Failure; message:
NULL file handle.
could this be due to the first problem?
Thank you for your time and support,
Best Regards,
Sevag Doniguian
URL: <http://lists.mcs.anl.gov/pipermail/moab-dev/attachments/20130711/d92b23aa/attachment.html>
