[MOAB-dev] Problems configuring MOAB with VTK
    Robert Maynard
    robert.maynard at kitware.com
    Wed Feb  6 09:37:09 CST 2013
I am away for the office today and tomorrow, but I can answer more VTK questions on Friday.
Sent from my iPhone
On Feb 6, 2013, at 7:13 AM, Tim Tautges <tautges at mcs.anl.gov> wrote:
> I'll take the blame for messing that up, I was playing fast and loose with the VTK configure (thinking that tools/vtkMOABReader[New] were the only tools relying on it.  More below...
> On 02/06/2013 07:58 AM, Roman Putanowicz wrote:
>>> Hi,
>>> This isn't a problem that MOAB is looking for a ParaView library. It has to
>>> do with MOAB is looking for VTK 6.0.
>> OK I see. Thank you for a quick answer.
>>> So to have MOAB configure against VTK 5.10 and lower I would replace
>>> vtkCommonCore with vtkCommon.
>> Well, I have tried this already but then I have problems with AC_HAVE_LIB
>> macro which apparently looks for function "main" in the library and the
>> check fails.
>> It looks like I will compile VTK 6.0 (it can look silly but will be
>> the fastest way).
>>  Just as a side note -- how you guys deal with tools
>> dependencies -- they just eat my time, especially when I switch to
>> a compiler different than gcc or go outside standard packages.
>> With the above I mean rather large development environment, where
>> tools are not just installed but managed -- tested (and test results
>> recorded), build with release and debug version, benchmarked, etc.
>> Is it only my impression that keeping tidy and reliable development
>> environment is a Sisyphus work.
> A very good point, and something I should be more sensitive about.  I'll think on this point the next day or two and start another thread on it, so stay tuned.
> - tim
>> Regards,
>> Roman
> "You will keep in perfect peace him whose mind is
>  steadfast, because he trusts in you."               Isaiah 26:3
>             Tim Tautges            Argonne National Laboratory
>         (tautges at mcs.anl.gov)      (telecommuting from UW-Madison)
> phone (gvoice): (608) 354-1459      1500 Engineering Dr.
>            fax: (608) 263-4499      Madison, WI 53706
