[MOAB-dev] MOAB and VTK configuration problems
Roman Putanowicz putanowr at l5.pk.edu.pl
Wed Feb 6 09:22:37 CST 2013
Dear All,
I reported problems with configuring MOAB with VTK.
Well, I have installed latest ParaView version with
vtkCommonCore library and all development files.
However I still cannot force MOAB to configure properly with VTK.
The first problem is with VTK_LIB_SUFFIX in configure.ac at line
768 -- it seems to be hard wired to some value and ignore command line
settings. Removing it I can start configuration but then get the following
errors:
checking for /home/femdk/install/include/vtk/vtkUnstructuredGrid.h... yes
checking for main in -lvtkCommonCore... no
./configure: line 36587: ac_cv_lib_vtkCommonCore=ac_cv_lib_vtkCommonCore:
command not found
checking for main in -lvtkCommonCore... (cached) no
command not found
command not found
command not found
command not found
configure: error: VTK libraries not found
My environment is :
autoconf (GNU Autoconf) 2.61
automake (GNU automake) 1.10.1
I have noticed that MOAB has also CMake configuration though I haven't tried
it yet. My question is is the autotools base compilation supposed to work?
BTW, without VTK MOAB compiles fine.
Roman
Roman Putanowicz, PhD  < putanowr at l5.pk.edu.pl  >
Institute for Computational Civil Engng (L-5)
Dept. of Civil Engng, Cracow Univ. of Technology
www.l5.pk.edu.pl, tel. +48 12 628 2569, fax 2034
