[MOAB-dev] Problems configuring MOAB with VTK
    Robert Maynard
    robert.maynard at kitware.com
    Wed Feb  6 07:33:02 CST 2013
This isn't a problem that MOAB is looking for a ParaView library. It has to
do with MOAB is looking for VTK 6.0.
VTK 6.0 includes a modularization of all the libraries. Previous to VTK6
vtkCommon would contain all
common components of VTK, now they are split into: vtkCommonCore,
vtkCommonDataModel, vtkCommonMath, etc
So to have MOAB configure against VTK 5.10 and lower I would replace
vtkCommonCore with vtkCommon. You will have to change any other link
line to VTK as I expect they also will look for VTK 6 libraries.
Side Note: The reason that you think vtkCommonCore is from ParaView is
because ParaView 3.98 was released using a developer version of VTK 6.0.
On Wed, Feb 6, 2013 at 7:37 AM, Roman Putanowicz <putanowr at l5.pk.edu.pl>wrote:
> Dear All,
> I'am trying to install MOAB from svn and I have problems
> with configuration of VTK dependencies.
> I have noticed that moab configuration script is checking
> for the library: -lvtkCommonCore
> However this library does not belong to VTK package. If I am
> correct it belongs to ParaView.
> I have searched with grep the moab trunk tree but haven't found
> references to vtkCommonCore except for configuration scripts.
> I haven't encountered this problem because I used to have both
> ParaView and VTK. This time however I have only VTK installed.
> With kind regards,
> Roman
> Roman Putanowicz, PhD  < putanowr at l5.pk.edu.pl  >
> Institute for Computational Civil Engng (L-5)
> Dept. of Civil Engng, Cracow Univ. of Technology
> www.l5.pk.edu.pl, tel. +48 12 628 2569, fax 2034
Robert Maynard
URL: <http://lists.mcs.anl.gov/pipermail/moab-dev/attachments/20130206/47ef84ff/attachment.html>
