[MOAB-dev] Exchanging tags with no name
    Tim Tautges
    tautges at mcs.anl.gov
    Thu Jan 17 16:32:52 CST 2013
Tags don't have to have names.  I wasn't aware that exchange_tags didn't work for nameless tags.  Can you send the test
program you wrote?
- tim
On 01/17/2013 04:10 PM, Milad Fatenejad wrote:
> Hello:
> I just tried calling exchange_tags on a tag with no name (when I created the tag I specified NULL as the first argument
> to tag_get_handle) and found that the tag exchange did not seem to work. After a lot of experimentation, I found that
> whether or not the tag had a name was the factor that determined whether the shared, not-owned entities successfully
> updated...
> Two questions:
> 1. Does exchange_tags require that the tag have a name specified?
> 2. Am I allowed to pass NULL as the name for tag_get_handle? Or must tags have names?
> Thank You
> Milad
   steadfast, because he trusts in you."               Isaiah 26:3
              Tim Tautges            Argonne National Laboratory
          (tautges at mcs.anl.gov)      (telecommuting from UW-Madison)
  phone (gvoice): (608) 354-1459      1500 Engineering Dr.
             fax: (608) 263-4499      Madison, WI 53706
