[MOAB-dev] r5932 - MOAB/trunk/tools/mbcslam
iulian at mcs.anl.gov iulian at mcs.anl.gov
Fri Jan 11 10:54:40 CST 2013
Author: iulian
Date: 2013-01-11 10:54:40 -0600 (Fri, 11 Jan 2013)
New Revision: 5932
Modified:
   MOAB/trunk/tools/mbcslam/Intx2Mesh.cpp
   MOAB/trunk/tools/mbcslam/Intx2Mesh.hpp
   MOAB/trunk/tools/mbcslam/Intx2MeshInPlane.hpp
Log:
revert to sending the index in the local entities range, from the target proc;
initially I was sending the ul (handle directly), which was wrong.
Modified: MOAB/trunk/tools/mbcslam/Intx2Mesh.cpp
--- MOAB/trunk/tools/mbcslam/Intx2Mesh.cpp	2013-01-11 16:26:50 UTC (rev 5931)
+++ MOAB/trunk/tools/mbcslam/Intx2Mesh.cpp	2013-01-11 16:54:40 UTC (rev 5932)
@@ -445,29 +445,29 @@
     return rval;
   // get the DP tag, and values for each node in the euler set
   // get first all entities in the set
-  Range local_ents;
-  rval = mb->get_entities_by_dimension(euler_set, 2, local_ents);
+  localEnts.clear(); // just to make sure :)
+  rval = mb->get_entities_by_dimension(euler_set, 2, localEnts);
   ERRORR(rval, "can't get ents by dimension");
   // get all the owned nodes on this euler set
   Range local_verts;
-  rval = mb->get_connectivity(local_ents, local_verts);
+  rval = mb->get_connectivity(localEnts, local_verts);
   if (parcomm)
     // get only those that are owned by this proc
     rval = parcomm->filter_pstatus(local_verts, PSTATUS_NOT_OWNED, PSTATUS_NOT);
     ERRORR(rval, "can't filter verts");
-    rval = parcomm->filter_pstatus(local_ents, PSTATUS_NOT_OWNED, PSTATUS_NOT);
+    rval = parcomm->filter_pstatus(localEnts, PSTATUS_NOT_OWNED, PSTATUS_NOT);
     ERRORR(rval, "can't filter elements");
-  rval = locate_departure_points(local_ents, local_verts);
+  rval = locate_departure_points(local_verts);
   ERRORR(rval, "can't locate departure points");
   return MB_SUCCESS;
 // store
-ErrorCode Intx2Mesh::locate_departure_points(Range & local_elements, Range & local_verts)
+ErrorCode Intx2Mesh::locate_departure_points(Range & local_verts)
   // get the DP tag , and get the departure points
   Tag tagh = 0;
@@ -500,7 +500,7 @@
   // store the remote handle (element) where the point is located in
   // we do not need another array like mappedPts or locs
-  source_pts.initialize(2, 0, 1, 0, target_pts.get_max());
+  source_pts.initialize(3, 0, 0, 0, target_pts.get_max());
   source_pts.enableWriteAccess();
   source_pts.set_n(0);
@@ -562,15 +562,15 @@
            my_rank, target_pts.get_n(), num_from_me);
