[MOAB-dev] r5933 - MOAB/trunk/test/parallel
iulian at mcs.anl.gov
Fri Jan 11 14:50:19 CST 2013
Author: iulian
Date: 2013-01-11 14:50:19 -0600 (Fri, 11 Jan 2013)
New Revision: 5933
Modified:
MOAB/trunk/test/parallel/par_intx_sph.cpp
Log:
test some epsilons:
default is 0.2
run fine with 0.0187 on one and two processors (everything was found)
Modified: MOAB/trunk/test/parallel/par_intx_sph.cpp
--- MOAB/trunk/test/parallel/par_intx_sph.cpp 2013-01-11 16:54:40 UTC (rev 5932)
+++ MOAB/trunk/test/parallel/par_intx_sph.cpp 2013-01-11 20:50:19 UTC (rev 5933)
@@ -57,6 +57,7 @@
EPS1=atof(argv[++index]);
+ index++;
result += RUN_TEST(test_intx_in_parallel);
