[MOAB-dev] r5931 - in MOAB/trunk: test/parallel tools/mbcslam
iulian at mcs.anl.gov
Fri Jan 11 10:26:50 CST 2013
Author: iulian
Date: 2013-01-11 10:26:50 -0600 (Fri, 11 Jan 2013)
New Revision: 5931
Modified:
MOAB/trunk/test/parallel/par_intx_sph.cpp
MOAB/trunk/tools/mbcslam/CslamUtils.cpp
MOAB/trunk/tools/mbcslam/CslamUtils.hpp
MOAB/trunk/tools/mbcslam/Intx2Mesh.cpp
MOAB/trunk/tools/mbcslam/Intx2Mesh.hpp
MOAB/trunk/tools/mbcslam/Intx2MeshInPlane.cpp
MOAB/trunk/tools/mbcslam/Intx2MeshOnSphere.cpp
MOAB/trunk/tools/mbcslam/Intx2MeshOnSphere.hpp
Log:
locate the departure points in parallel, for spherical meshes
replicate some of the MBCoupler code
- build the local KD tree
- send departure points to target procs, based on their boxes (crystal router 1)
- find locally the elements, send the info back to source procs (crystal router 2)
need to use spherical utils for localization, and did not want to pollute regular MBCoupler with this
- set the LOC tag appropriately, with the processor and the index of the element for that processor
Modified: MOAB/trunk/test/parallel/par_intx_sph.cpp
--- MOAB/trunk/test/parallel/par_intx_sph.cpp 2012-12-18 22:47:35 UTC (rev 5930)
+++ MOAB/trunk/test/parallel/par_intx_sph.cpp 2013-01-11 16:26:50 UTC (rev 5931)
@@ -39,14 +39,26 @@
#endif
using namespace moab;
+double EPS1=0.2;
void test_intx_in_parallel();
int main(int argc, char **argv)
MPI_Init(&argc, &argv);
+ EPS1 = 0.2;
int result = 0;
+ if (argc>1)
+ int index=1;
+ while (index<argc)
+ if (!strcmp( argv[index], "-eps"))
+ EPS1=atof(argv[++index]);
result += RUN_TEST(test_intx_in_parallel);
MPI_Finalize();
@@ -151,7 +163,9 @@
Intx2MeshOnSphere worker(&mb);
- //worker.locate_departure_points(euler_set);
+ worker.SetRadius(3*sqrt(3.));
+ worker.set_box_error(EPS1);//
+ worker.locate_departure_points(euler_set);
std::string opts_write("PARALLEL=WRITE_PART");
rval = mb.write_file("manuf.h5m", 0, opts_write.c_str(), &euler_set, 1);
Modified: MOAB/trunk/tools/mbcslam/CslamUtils.cpp
--- MOAB/trunk/tools/mbcslam/CslamUtils.cpp 2012-12-18 22:47:35 UTC (rev 5930)
+++ MOAB/trunk/tools/mbcslam/CslamUtils.cpp 2013-01-11 16:26:50 UTC (rev 5931)
@@ -577,4 +577,27 @@
return MB_SUCCESS;
