[ExM Users] Installing Swift/T on Raven
Scott Krieder
skrieder at iit.edu
Tue Apr 16 04:20:22 CDT 2013
Hi All,
I'm down to 1 error on the Turbine install on Raven:
p01684 at raven:~/exm/turbine/trunk/code> make test_results
SH tests/lib-turbine.result
make: *** [tests/lib-turbine.result] Error 1
p01684 at raven:~/exm/turbine/trunk/code> cat tests/lib-turbine.out
mpiexec: unexpected error - no non-PBS mpiexec in PATH
Has anyone seen this error on a Cray machine before?
Other than that error I have the Turbine stack installed on Raven. I'm
still working to install stc, which I still need ant to install. Here are
my notes:
I used the Cray notes from here:
https://sites.google.com/site/exmproject/development/turbine---build
On Raven use:
/opt/cray/mpt/default/gni/mpich2-gnu/46
For ADLB:
./configure --prefix=/home/users/p01684/Public/sfw/lb CC=gcc
CFLAGS=-I/opt/cray/mpt/default/gni/mpich2-gnu/46/include
LDFLAGS="-L/opt/cray/mpt/default/gni/mpich2-gnu/46/lib -lmpich"
--with-c-utils=/home/users/p01684/Public/sfw/c-utils --enable-mpi-2
I modified the Makefile and swapped gcc for two instances of mpicc.
I then installed SWIG from source with the configuration:
./configure --prefix=/home/users/p01684/Public/sfw/swig --without-pcre
I configure turbine with:
./configure --prefix=/home/users/p01684/Public/sfw/turbine
--with-mpi=/opt/cray/mpt/default/gni/mpich2-gnu/46
-Scott
On Tue, Apr 16, 2013 at 5:43 AM, Michael Wilde <wilde at mcs.anl.gov> wrote:
> Scott,
> Were you able to get Swift/T running on Raven?
> If so, which version, and do you have an install there that I can use for
> my own tests (and to help get a demo ready and tested for Cray?)
> Tim, Justin, can you point me to a suggested Swift/T toolset on Beagle?
> Thanks,
> - Mike
> > From: "Scott Krieder" <skrieder at iit.edu>
> > To: "Justin M Wozniak" <wozniak at mcs.anl.gov>
> > Cc: exm-user at lists.mcs.anl.gov
> > Sent: Friday, April 12, 2013 3:02:04 PM
> > Subject: Re: [ExM Users] Installing Swift/T on Raven
> > Hi Justin,
> > For ADLB it doesn't recognize --with-mpi or --with-mpi-dir in the
> > configure file. So I pointed both flags to use the default:
> > --without-pcre
> > However on "make package" there is an error with one of the blob
> > header files:
> > p01684 at raven:~/exm/turbine/trunk/code> make package SWIG
> > src/tcl/blob/SwiftBlob.i src/tcl/blob/blob.h:25: Warning 201: Unable
> > to find 'stdbool.h'
> > Do you know if there is a module I can load so swig can find the
> > stdbool.h?
> > Thank you,
> > Scott
> > On Fri, Apr 12, 2013 at 1:44 PM, Justin M Wozniak <
> > wozniak at mcs.anl.gov > wrote:
> > That configure line points --prefix= ... /c-utils
> > Also, CFLAGS=-I... should point to an include directory.
> > Try setting
> > and let me know what happens. I will try to get on Raven soon to test
> > this.
> > On 04/12/2013 12:57 PM, Scott Krieder wrote:
> > Hi Justin,
> > This is from a tarball from my machine where GeMTC and Swift are
> > working, I haven't updated past version 6770. Sorry to bounce around
> > with errors but I believe I had an earlier issue with the
> > c-utils/adlb install that lead to this turbine issue. When
> > configuring adlb I point it at the c-utils install and I get an
> > error regarding the MPI version.
> > I'm running:
> > ./configure --prefix=/home/users/p01684/Public/c-utils CC=gcc
> > I noticed that there are many folders in:
> > /opt/cray/mpt/
> > Is there a good way to identify which version I should use within
> > /opt/cray/mpt? Or am I wrong in assuming that this versioning is
> > what is causing the "Could not preprocess maint/mpi_version.cpp"
> > error?
> > Thanks,
> > Scott
> > ==error message==
> > checking for cp that supports -u... yes
> > using MPE: no
> > checking for
> > /home/users/p01684/Public/sfw/c-utils/include/c-utils.h... yes
> > using ExM c-utils in /home/users/p01684/Public/sfw/c-utils ...
> > checking MPI version... maint/mpi_version.cpp:23:17: error: mpi.h: No
> > such file or directory
> > configure: error: Could not preprocess maint/mpi_version.cpp
> > On Fri, Apr 12, 2013 at 11:28 AM, Justin M Wozniak <
> > Hi
> > Is this with trunk or with the release package?
> > --with-mpi-dir may have been replaced by --with-mpi
> > Justin
> > On 04/12/2013 11:05 AM, Scott Krieder wrote:
> > Hi All,
> > I'm trying to install Swift/T on Raven. I followed the notes about
> > Cray systems.
> > When I configure turbine with:
> > --enable-custom
> > --with-mpi-dir=/opt/cray/mpt/default/xt/gemini/mpich2-gnu/46
> > I get a long error about "could not find directory" in reference to
> > mpicc. Is there something I should do in addition to the --with-mpi
> > flag?
> > Thanks,
> > Scott
> > ==Error Message==
> > checking for
> > /ufs/home/users/p01684/Public/sfw/c-utils/include/c-utils.h... yes
> > which: no mpicc in
> (/opt/pbs/10.4.0.101257/bin:/opt/cray/atp/1.6.2/bin:/opt/cray/rca/1.0.0-2.0401.38656.2.2.gem/bin:/opt/cray/pmi/4.0.1-1.0000.9421.73.3.gem/bin:/opt/toolworks/totalview.8.11.0-1/bin:/opt/totalview-support/1.1.4/bin:/opt/cray/cce/8.1.4/cray-binutils/x86_64-unknown-linux-gnu/bin:/opt/cray/cce/8.1.4/craylibs/x86-64/bin:/opt/cray/cce/8.1.4/cftn/bin:/opt/cray/cce/8.1.4/CC/bin:/opt/cray/xt-asyncpe/5.20.11/bin:/opt/cray/llm/default/bin:/opt/cray/llm/default/etc:/opt/cray/xpmem/0.1-2.0401.36790.4.3.gem/bin:/opt/cray/dmapp/3.2.1-1.0401.5983.4.5.gem/bin:/opt/cray/ugni/4.0-1.0401.5928.9.5.gem/bin:/opt/cray/udreg/2.3.2-1.0401.5929.3.3.gem/bin:/opt/cray/lustre-cray_gem_s/1.8.6_2.6.32.59_0.7.1_1.0401.6845.9.1-1.0401.38658.11.3/sbin:/opt/cray/lustre-cray_gem_s/1.8.6_2.6.32.59_0.7.1_1.0401.6845.9.1-1.0401.38658.11.3/bin:/opt/cray/MySQL/5.0.64-1.0000.5053.22.1/sbin:/opt/cray/MySQL/5.0.64-1.0000.5053.22.1/bin:/opt/cray/sdb/1.0-1.0401.38148.4.27.gem/bin:/opt/cray/nodestat/2.
> > 2-1.0401. 37252.2.1.gem /bin:/opt /modules/
> 3.2.6.7/bin:/usr/local/bin:/usr/bin:/bin:/usr/bin/X11:/usr/X11R6/bin:/usr/games:/usr/lib64/jvm/jre/bin:/usr/lib/mit/bin:/usr/lib/mit/sbin:.:/usr/lib/qt3/bin:/opt/cray/bin
> > ./configure: line 4032: ((: ! : syntax error: operand expected (error
> > token is " ")
> > checking for 0... no
> > configure: error: Could not find directory
> > Scott J. Krieder
> > C: 419-685-0410
> > E: skrieder at iit.edu
> > http://datasys.cs.iit.edu/~skrieder/
> > _______________________________________________
> > ExM-user mailing list ExM-user at lists.mcs.anl.gov
> > https://lists.mcs.anl.gov/mailman/listinfo/exm-user
> > Justin M Wozniak
> > Scott J. Krieder
> > C: 419-685-0410
> > Justin M Wozniak
> > Scott J. Krieder
> > C: 419-685-0410
Scott J. Krieder
C: 419-685-0410
URL: <http://lists.mcs.anl.gov/pipermail/exm-user/attachments/20130416/32394700/attachment-0001.html>
More information about the ExM-user
