[cgma-dev] buildbot failure in cgm-occ-par: failed test
    Jane Hu
    janejhu at gmail.com
    Wed Oct 17 10:24:36 CDT 2012
Thanks, Iulian, for explaining it. I am still working on cgm with cubit13.1
build, pretty stuck here, but will let you know if anything can be improved.
Jane
On Wed, Oct 17, 2012 at 9:52 AM, Iulian Grindeanu <iulian at mcs.anl.gov>wrote:
> Hi Jane,
> Buildbot is doing a make distclean every time. The problem with this and
> with one moab test and some meshkit tests was the local
> LD_LIBRARY_PATH.
> This should not be a problem, but cgma has some path issues.
> LD path was pointing to cubit 13.1, and it got mixed up. The buildbot main
> builds are now with cubit 12.2, cubit merge12.2 branch of cgm
> The trunk is tested only against occ 653, shared and static, serial.
> Tonight these should not be a problem, I removed the cubit path references
> from the .bashrc of fathom account.
> If we are going to support both (cubit 12 and cubit 13) for a while, it
> would be a good idea to remove it from .bashrc (PATH and LD_LIBRARY_PATH).
> Set it only when needed to the required version of cubit.
> Iulian
> Do a 'make distclean' may clear the problems.
> Jane
> On Wed, Oct 17, 2012 at 12:30 AM, <cgma-dev at mcs.anl.gov> wrote:
>> Fathom <http://gnep.mcs.anl.gov:8010/>: cgm-occ-par<http://gnep.mcs.anl.gov:8010/builders/cgm-occ-par>build
>> #38 <http://gnep.mcs.anl.gov:8010/builders/cgm-occ-par/builds/38> *
>> Results:*failed test *Buildslave:*gnep *Revision:*None *Reason:*The
>> Nightly scheduler named 'cgm-occ-par-nightly' triggered this build Log
>> Excerpt
>> Making check in OCC
>> make[3]: Entering directory `/disks/itaps-buildslave/cgm-occ-par/build/geom/OCC'
>> make[3]: Nothing to be done for `check'.
>>  ...Making check in init
>> make[2]: Entering directory `/disks/itaps-buildslave/cgm-occ-par/build/init'
>> make[2]: Nothing to be done for `check'.
>>  ...Making check in .
>> make[2]: Entering directory `/disks/itaps-buildslave/cgm-occ-par/build'
>> make[2]: Nothing to be done for `check-am'.
>>  ...Making check in itaps
>> make[2]: Entering directory `/disks/itaps-buildslave/cgm-occ-par/build/itaps'
>> make  check-recursive
>> make[3]: Entering directory `/disks/itaps-buildslave/cgm-occ-par/build/itaps'
>> Making check in .
>> make[4]: Entering directory `/disks/itaps-buildslave/cgm-occ-par/build/itaps'
>> make  chaman test_edge_orient   testgeom_occ copy_attrib partest
>> make[5]: Entering directory `/disks/itaps-buildslave/cgm-occ-par/build/itaps'
>> /homes/fathom/3rdparty/mpich2/mpich2-1.2.1/gcc/bin/mpicxx -DHAVE_CONFIG_H -I. -I.. -I../geom/parallel -I../geom   -DLITTLE_ENDIAN=BYTE_ORDER   -DTEMPLATE_DEFS_INCLUDED  -DHAVE_OCC -DHAVE_OCC_IGES -DHAVE_OCC_STEP -DHAVE_OCC_STL -DSRCDIR=. -I../util -I../geom -I../init -I../geom/parallel -DUSE_MPI  -DFORCE_OCC   -Wall -pipe -pedantic -O2 -DNDEBUG -MT partest-partest.o -MD -MP -MF .deps/partest-partest.Tpo -c -o partest-partest.o `test -f 'partest.cpp' || echo './'`partest.cpp
>> In file included from ../geom/parallel/CGMmpi.h:11,
>>                  from partest.cpp:15:
>> /home/fathom/3rdparty/mpich2/mpich2-1.2.1/gcc/include/mpi.h:373: warning: ISO C++ 1998 does not support ‘long long’
>> partest.cpp: In function ‘int main(int, char**)’:
>> partest.cpp:72: warning: ‘rss_before’ may be used uninitialized in this function
>> partest.cpp:72: warning: ‘size_before’ may be used uninitialized in this function
>> mv -f .deps/partest-partest.Tpo .deps/partest-partest.Po
>> /homes/fathom/3rdparty/mpich2/mpich2-1.2.1/gcc/bin/mpicxx -DHAVE_CONFIG_H -I. -I.. -I../geom/parallel -I../geom  -DLITTLE_ENDIAN=BYTE_ORDER   -DTEMPLATE_DEFS_INCLUDED  -DHAVE_OCC -DHAVE_OCC_IGES -DHAVE_OCC_STEP -DHAVE_OCC_STL -DSRCDIR=. -I../util -I../geom -I../init -I../geom/parallel -DUSE_MPI    -Wall -pipe -pedantic -O2 -DNDEBUG -MT chaman.o -MD -MP -MF .deps/chaman.Tpo -c -o chaman.o chaman.cc
>> /homes/fathom/3rdparty/mpich2/mpich2-1.2.1/gcc/bin/mpicxx -DHAVE_CONFIG_H -I. -I.. -I../geom/parallel -I../geom  -DLITTLE_ENDIAN=BYTE_ORDER   -DTEMPLATE_DEFS_INCLUDED  -DHAVE_OCC -DHAVE_OCC_IGES -DHAVE_OCC_STEP -DHAVE_OCC_STL -DSRCDIR=. -I../util -I../geom -I../init -I../geom/parallel -DUSE_MPI    -Wall -pipe -pedantic -O2 -DNDEBUG -MT test_edge_orient.o -MD -MP -MF .deps/test_edge_orient.Tpo -c -o test_edge_orient.o test_edge_orient.cc
>> /homes/fathom/3rdparty/mpich2/mpich2-1.2.1/gcc/bin/mpicxx -DHAVE_CONFIG_H -I. -I.. -I../geom/parallel -I../geom   -DLITTLE_ENDIAN=BYTE_ORDER   -DTEMPLATE_DEFS_INCLUDED  -DHAVE_OCC -DHAVE_OCC_IGES -DHAVE_OCC_STEP -DHAVE_OCC_STL -DSRCDIR=. -I../util -I../geom -I../init -I../geom/parallel -DUSE_MPI  -DFORCE_OCC   -Wall -pipe -pedantic -O2 -DNDEBUG -MT testgeom_occ-testgeom.o -MD -MP -MF .deps/testgeom_occ-testgeom.Tpo -c -o testgeom_occ-testgeom.o `test -f 'testgeom.cc' || echo './'`testgeom.cc
>> /homes/fathom/3rdparty/mpich2/mpich2-1.2.1/gcc/bin/mpicxx -DHAVE_CONFIG_H -I. -I.. -I../geom/parallel -I../geom  -DLITTLE_ENDIAN=BYTE_ORDER   -DTEMPLATE_DEFS_INCLUDED  -DHAVE_OCC -DHAVE_OCC_IGES -DHAVE_OCC_STEP -DHAVE_OCC_STL -DSRCDIR=. -I../util -I../geom -I../init -I../geom/parallel -DUSE_MPI    -Wall -pipe -pedantic -O2 -DNDEBUG -MT copy_attrib.o -MD -MP -MF .deps/copy_attrib.Tpo -c -o copy_attrib.o copy_attrib.cpp
>> mv -f .deps/chaman.Tpo .deps/chaman.Po
>> /bin/sh ../libtool  --tag=CXX   --mode=link /homes/fathom/3rdparty/mpich2/mpich2-1.2.1/gcc/bin/mpicxx  -Wall -pipe -pedantic -O2 -DNDEBUG  -L/homes/fathom/3rdparty/occ/OpenCASCADE6.5.3/gccGnep/lib  -o partest partest-partest.o libiGeom.la -lTKernel -lm
>> mv -f .deps/copy_attrib.Tpo .deps/copy_attrib.Po
>> /bin/sh ../libtool  --tag=CXX   --mode=link /homes/fathom/3rdparty/mpich2/mpich2-1.2.1/gcc/bin/mpicxx  -Wall -pipe -pedantic -O2 -DNDEBUG  -L/homes/fathom/3rdparty/occ/OpenCASCADE6.5.3/gccGnep/lib  -o chaman chaman.o libiGeom.la -lTKernel -lm
>> mv -f .deps/test_edge_orient.Tpo .deps/test_edge_orient.Po
>> /bin/sh ../libtool  --tag=CXX   --mode=link /homes/fathom/3rdparty/mpich2/mpich2-1.2.1/gcc/bin/mpicxx  -Wall -pipe -pedantic -O2 -DNDEBUG  -L/homes/fathom/3rdparty/occ/OpenCASCADE6.5.3/gccGnep/lib  -o copy_attrib copy_attrib.o libiGeom.la -lTKernel -lm
>> libtool: link: /homes/fathom/3rdparty/mpich2/mpich2-1.2.1/gcc/bin/mpicxx -Wall -pipe -pedantic -O2 -DNDEBUG -o .libs/partest partest-partest.o  -L/homes/fathom/3rdparty/occ/OpenCASCADE6.5.3/gccGnep/lib ./.libs/libiGeom.so /homes/fathom/3rdparty/occ/OpenCASCADE6.5.3/gccGnep/lib/libTKernel.so -lm -Wl,-rpath -Wl,/homes/fathom/install/occpar/cgm/lib -Wl,-rpath -Wl,/homes/fathom/3rdparty/occ/OpenCASCADE6.5.3/gccGnep/lib
>> libtool: link: /homes/fathom/3rdparty/mpich2/mpich2-1.2.1/gcc/bin/mpicxx -Wall -pipe -pedantic -O2 -DNDEBUG -o .libs/chaman chaman.o  -L/homes/fathom/3rdparty/occ/OpenCASCADE6.5.3/gccGnep/lib ./.libs/libiGeom.so /homes/fathom/3rdparty/occ/OpenCASCADE6.5.3/gccGnep/lib/libTKernel.so -lm -Wl,-rpath -Wl,/homes/fathom/install/occpar/cgm/lib -Wl,-rpath -Wl,/homes/fathom/3rdparty/occ/OpenCASCADE6.5.3/gccGnep/lib
>> libtool: link: /homes/fathom/3rdparty/mpich2/mpich2-1.2.1/gcc/bin/mpicxx -Wall -pipe -pedantic -O2 -DNDEBUG -o .libs/copy_attrib copy_attrib.o  -L/homes/fathom/3rdparty/occ/OpenCASCADE6.5.3/gccGnep/lib ./.libs/libiGeom.so /homes/fathom/3rdparty/occ/OpenCASCADE6.5.3/gccGnep/lib/libTKernel.so -lm -Wl,-rpath -Wl,/homes/fathom/install/occpar/cgm/lib -Wl,-rpath -Wl,/homes/fathom/3rdparty/occ/OpenCASCADE6.5.3/gccGnep/lib
>> mv -f .deps/testgeom_occ-testgeom.Tpo .deps/testgeom_occ-testgeom.Po
>> /bin/sh ../libtool  --tag=CXX   --mode=link /homes/fathom/3rdparty/mpich2/mpich2-1.2.1/gcc/bin/mpicxx  -Wall -pipe -pedantic -O2 -DNDEBUG  -L/homes/fathom/3rdparty/occ/OpenCASCADE6.5.3/gccGnep/lib  -o test_edge_orient test_edge_orient.o libiGeom.la -lTKernel -lm
>> /homes/fathom/install/occpar/cgm/lib/libcgm.so.0: undefined reference to `Standard_PI'
>> collect2: ld returned 1 exit status
>>  ...make[5]: *** Waiting for unfinished jobs....
>>  .../homes/fathom/install/occpar/cgm/lib/libcgm.so.0: undefined reference to `Standard_PI'
>>  ...libtool: link: /homes/fathom/3rdparty/mpich2/mpich2-1.2.1/gcc/bin/mpicxx -Wall -pipe -pedantic -O2 -DNDEBUG -o .libs/test_edge_orient test_edge_orient.o  -L/homes/fathom/3rdparty/occ/OpenCASCADE6.5.3/gccGnep/lib ./.libs/libiGeom.so /homes/fathom/3rdparty/occ/OpenCASCADE6.5.3/gccGnep/lib/libTKernel.so -lm -Wl,-rpath -Wl,/homes/fathom/install/occpar/cgm/lib -Wl,-rpath -Wl,/homes/fathom/3rdparty/occ/OpenCASCADE6.5.3/gccGnep/lib
> Jane Hu
> Asst. Researcher
> Dept. of Engineering Physics
> UW @ Madison
> "And we know that for those who love God, that is, for those who are
> called according to his purpose, all things are working together for good."
> (Romans 8:28)
Jane Hu
Asst. Researcher
UW @ Madison
"And we know that for those who love God, that is, for those who are called
(Romans 8:28)
URL: <http://lists.mcs.anl.gov/pipermail/cgma-dev/attachments/20121017/1d63ec0f/attachment.html>
More information about the cgma-dev
