[cgma-dev] r5802 - cgm/trunk/test
    janehu at mcs.anl.gov
    Wed Oct 17 13:32:12 CDT 2012
Author: janehu
Date: 2012-10-17 13:32:12 -0500 (Wed, 17 Oct 2012)
New Revision: 5802
Modified:
   cgm/trunk/test/Makefile.am
Log:
cgm on occ653 still fails on shared build on my machine, this is the fix for it.After this check in, I am going to double check for cubit build to see if it helps there.
Modified: cgm/trunk/test/Makefile.am
--- cgm/trunk/test/Makefile.am	2012-10-17 15:13:49 UTC (rev 5801)
+++ cgm/trunk/test/Makefile.am	2012-10-17 18:32:12 UTC (rev 5802)
@@ -27,7 +27,7 @@
 check_PROGRAMS = $(TESTS)
-LDADD = ../libcgm.la libcgm_test.la $(CGM_EXT_LIBS) $(CGM_EXT_LDFLAGS) $(CGM_EXT_LTFLAGS)
+LDADD = ../libcgm.la ../geom/libcubit_geom.la ../util/libcubit_util.la libcgm_test.la ../geom/virtual/libcubit_virtual.la ../geom/facet/libcubit_facet.la $(CGM_EXT_LIBS) $(CGM_EXT_LDFLAGS) $(CGM_EXT_LTFLAGS)
 noinst_LTLIBRARIES = libcgm_test.la
 libcgm_test_la_SOURCES = TestUtilities.hpp \
More information about the cgma-dev
