[AG-TECH] Using AGVCR with latest Video Producer
Andrew Ford
acf0659 at rit.edu
Tue Apr 7 11:22:40 CDT 2009
Ben,
The safest way to do it would probably be to configure AGVCR to playback to
localhost but launch vic and rat manually yourself (ie, go to your
VideoConsumerServiceH264 directory on the command line and do vic
127.0.0.1/50002, and similar for RAT on 127.0.0.1/50000), instead of doing
'launch stream apps' on AGVCR.
Just to clarify - are you doing just H264 or are you doing DVTS aka
ExtendedVideo as well?
Doug - I know ExtendedVideo streams are always on their own IPs, but don't
the H.264 services always point to the same IP and port as the normal vic
services? That's what I've always seen.
--Andrew
2009/4/7 Ben Green <ben.green at manchester.ac.uk>
> Just tried playing the recording back into a virtual venue (as opposed to
> localhost) with the default vic.exe and it plays back all streams, including
> the extended video services.
> So it may be something to do with the port numbers used with the AGVCR
> Local Playback configuration. They default as 50000 and 50002.
> If anyone has any more info on this, it'll be much appreciated. I need to
> demonstrate a recorded meeting tomorrow at a building with no internet
> connection, therefore need to play back locally.
> Cheers, Ben.
> -----Original Message-----
> From: ag-tech-bounces at lists.mcs.anl.gov [mailto:
> ag-tech-bounces at lists.mcs.anl.gov] On Behalf Of Douglas Kosovic
> Sent: 07 April 2009 11:59
> To: ben.green at manchester.ac.uk
> Cc: ag-tech at mcs.anl.gov
> Subject: Re: [AG-TECH] Using AGVCR with latest Video Producer
> Hi Ben,
> >>From what I can tell, the current AGVCR will not play back recorded video
> streams from an H264 or Extended Video service.
> > I'm guessing that it's because AGVCR uses an 'old' version of vic.exe
> > Has anyone tried 'upgrading' the vic.exe that AGVCR uses ?
> You didn't mention if you are using the AGVCR Launcher from the VenueClient
> or manually setting the host and port details for the audio and video
> streams within AGVCR.
> The H264 and Extended Video services are configured to use different ports
> than the standard H261 Video service, so I suspect that's the reason you
> aren't recording them.
> Doug
URL: <http://lists.mcs.anl.gov/pipermail/ag-tech/attachments/20090407/dba76a5e/attachment.htm>
