[AG-TECH] Using AGVCR with latest Video Producer
Ben Green
ben.green at manchester.ac.uk
Tue Apr 7 09:33:02 CDT 2009
Just tried playing the recording back into a virtual venue (as opposed to localhost) with the default vic.exe and it plays back all streams, including the extended video services.
So it may be something to do with the port numbers used with the AGVCR Local Playback configuration. They default as 50000 and 50002.
If anyone has any more info on this, it'll be much appreciated. I need to demonstrate a recorded meeting tomorrow at a building with no internet connection, therefore need to play back locally.
Cheers, Ben.
-----Original Message-----
From: ag-tech-bounces at lists.mcs.anl.gov [mailto:ag-tech-bounces at lists.mcs.anl.gov] On Behalf Of Douglas Kosovic
Sent: 07 April 2009 11:59
To: ben.green at manchester.ac.uk
Cc: ag-tech at mcs.anl.gov
Subject: Re: [AG-TECH] Using AGVCR with latest Video Producer
Hi Ben,
>>From what I can tell, the current AGVCR will not play back recorded video streams from an H264 or Extended Video service.
> I'm guessing that it's because AGVCR uses an 'old' version of vic.exe
> Has anyone tried 'upgrading' the vic.exe that AGVCR uses ?
You didn't mention if you are using the AGVCR Launcher from the VenueClient or manually setting the host and port details for the audio and video streams within AGVCR.
The H264 and Extended Video services are configured to use different ports than the standard H261 Video service, so I suspect that's the reason you aren't recording them.
Doug
