[petsc-users] configuration on hopper at nersc
George Pau gpau at lbl.gov
Mon Jul 1 19:11:36 CDT 2013
As usual, I forgot the attachments.  George
On Mon, Jul 1, 2013 at 5:05 PM, George Pau <gpau at lbl.gov> wrote:
> I was having trouble configuring petsc 3.4.1 on hopper.  The same
> configuration that use for 3.3.6 failed due to "Mismatched single quotes in
> C library string".  Attached (configure_without_additional_flag.log) is the
> result of the configuration script.
> I read in a previous thread (
> http://lists.mcs.anl.gov/pipermail/petsc-users/2011-July/009310.html)
> that I need to add  --with-clib-autodetect=0 --with-cxxlib-autodetect=0
> --with-fortranlib-autodetect=0 for that error.  But it failed later with
> the following error: "C++ error! mpi.h could not be located at: []".
>  configure_with_additional_flag.log is the result of the configuration
> script.
> I am using the gnu compiler and it is of version 4.1.40, if that is
> relevant.  Please let me know if you need other configuration information.
> Thanks,
> George
> George Pau
> Earth Sciences Division
> Lawrence Berkeley National Laboratory
> One Cyclotron, MS 74-120
> Berkeley, CA 94720
> (510) 486-7196
> gpau at lbl.gov
> http://esd.lbl.gov/about/staff/georgepau/
George Pau
Berkeley, CA 94720
(510) 486-7196
gpau at lbl.gov
URL: <http://lists.mcs.anl.gov/pipermail/petsc-users/attachments/20130701/be20e660/attachment-0001.html>
Desc: not available
URL: <http://lists.mcs.anl.gov/pipermail/petsc-users/attachments/20130701/be20e660/attachment-0002.obj>
Desc: not available
URL: <http://lists.mcs.anl.gov/pipermail/petsc-users/attachments/20130701/be20e660/attachment-0003.obj>
