[petsc-users] configuration on hopper at nersc
George Pau gpau at lbl.gov
Mon Jul 1 19:05:52 CDT 2013
I was having trouble configuring petsc 3.4.1 on hopper.  The same
configuration that use for 3.3.6 failed due to "Mismatched single quotes in
C library string".  Attached (configure_without_additional_flag.log) is the
result of the configuration script.
I read in a previous thread (
http://lists.mcs.anl.gov/pipermail/petsc-users/2011-July/009310.html) that
I need to add  --with-clib-autodetect=0 --with-cxxlib-autodetect=0
--with-fortranlib-autodetect=0 for that error.  But it failed later with
the following error: "C++ error! mpi.h could not be located at: []".
 configure_with_additional_flag.log is the result of the configuration
script.
I am using the gnu compiler and it is of version 4.1.40, if that is
relevant.  Please let me know if you need other configuration information.
George
George Pau
Earth Sciences Division
Lawrence Berkeley National Laboratory
One Cyclotron, MS 74-120
Berkeley, CA 94720
(510) 486-7196
gpau at lbl.gov
http://esd.lbl.gov/about/staff/georgepau/
URL: <http://lists.mcs.anl.gov/pipermail/petsc-users/attachments/20130701/79cb1fcf/attachment.html>
