[petsc-users] import a mesh.
Tue Aug 20 10:45:58 CDT 2013
On Tue, Aug 20, 2013 at 10:16 AM, Olivier Bonnefon <
olivier.bonnefon at avignon.inra.fr> wrote:
>  Hello,
> Thank-you, I'm using DMPlexCreateFromCellList(), and it works except for
> the boundary conditions.
> I'm using Dirichlet boundary conditions, and the corresponding degree of
> freedom are not substituted (like when I use DMPlexCreateBoxMesh).
> So, I do have missing a step to define the boundary ?
Yes. For the other formats, it translates boundary markers to DMLabels.
With the CellList you will have to label your boundary.
If you want it to work exactly as in the example, for every point p on your
boundary,
  DMPlexSetLabelValue(dm, "marker", p, 1);
You can avoid the string lookup by using
  DMPlexCreateLabel(dm, "marker");
  DMPlexGetLabel(dm, "marker", &label);
  DMLabelSetValue(label, p, 1);
Obviously, if you have multiple BC, you can use a label for each condition.
     Matt
> Olivier B
> On 08/20/2013 03:08 PM, Matthew Knepley wrote:
> On Tue, Aug 20, 2013 at 7:50 AM, Olivier Bonnefon <
>> Hello,
>> I have modify the ex12.c example for a like diffusive problem
>> (FEM+unstructured mesh+SNES).
>> The next step, is to replace the square mesh by my own mesh.
>> I want import my mesh from a simple file, and after distributed it with
>> DMPlexDistribute.
>> Is it the good way ?
>> Is it possible to import a mesh in petsc ? I didn't find the answer in
>> the documentation. Is there an example ?
>  There are a few formats supported:
>    1) Cell-vertex: DMPlexCreateFromCellList()
>    2) Exodus: DMPlexCreateExodus()
>    3) CGNS: DMPlexCreateCGNS()
>    Thanks,
>       Matt
>> Thanks
>> Olivier Bonnefon
>> Olivier Bonnefon
>> INRA PACA-Avignon, Unité BioSP
>> Tel: +33 (0)4 32 72 21 58 <%2B33%20%280%294%2032%2072%2021%2058>
> experiments lead.
> -- Norbert Wiener
> Olivier Bonnefon
experiments lead.
-- Norbert Wiener
URL: <http://lists.mcs.anl.gov/pipermail/petsc-users/attachments/20130820/8632bd4c/attachment-0001.html>
