[petsc-users] import a mesh.
obonnefon at paca.inra.fr obonnefon at paca.inra.fr
Wed Aug 21 04:28:34 CDT 2013
  Hello,
Ok, I did it:
    ierr =
DMPlexCreateFromCellList(comm,dim,8,9,3,0,obcells,2,obvertex,dm);CHKERRQ(ierr);
    for (i=0;i<obNbBound;i++){
      ierr =DMPlexSetLabelValue(*dm, "marker", obboundary[i],
1);CHKERRQ(ierr);
but, it is not efficient: The degree of freedom are still present in the
linear system.
In the source of  DMPlexCreateSquareBoundary, the label is set for the
edges and for the points.
Do I have to do something like this ?
Olivier B
Quoting Matthew Knepley <knepley at gmail.com>:
> On Tue, Aug 20, 2013 at 10:16 AM, Olivier Bonnefon
> <olivier.bonnefon at avignon.inra.fr> wrote:
>> Hello,
>> Thank-you, I'm using DMPlexCreateFromCellList(), and it works except
>> for the boundary conditions.
>> I'm using Dirichlet boundary conditions, and the corresponding degree
>> of freedom are not substituted (like when I use DMPlexCreateBoxMesh).
>> So, I do have missing a step to define the boundary ?
>      Yes. For the other formats, it translates boundary markers to
> DMLabels. With the CellList you will have to label your boundary.
>      If you want it to work exactly as in the example, for every point p
> on your boundary,
>        DMPlexSetLabelValue(dm, "marker", p, 1);
>      You can avoid the string lookup by using
>        DMPlexCreateLabel(dm, "marker");
>        DMPlexGetLabel(dm, "marker", &label);
>        DMLabelSetValue(label, p, 1);
>      Obviously, if you have multiple BC, you can use a label for each
> condition.
>        Thanks,
>           Matt
>> Olivier B
>> On 08/20/2013 03:08 PM, Matthew Knepley wrote:
>>> On Tue, Aug 20, 2013 at 7:50 AM, Olivier Bonnefon
>>>> Hello,
>>>> I have modify the ex12.c example for a like diffusive problem
>>>> (FEM+unstructured mesh+SNES).
>>>> The next step, is to replace the square mesh by my own mesh.
>>>> I want import my mesh from a simple file, and after distributed it
>>>> with DMPlexDistribute.
>>>> Is it the good way ?
>>>> Is it possible to import a mesh in petsc ? I didn't find the answer
>>>> in the documentation. Is there an example ?
>>>            There are a few formats supported:
>>>              1) Cell-vertex: DMPlexCreateFromCellList()
>>>              2) Exodus: DMPlexCreateExodus()
>>>              3) CGNS: DMPlexCreateCGNS()
>>>              Thanks,
>>>                 Matt
>>>> Thanks
>>>> Olivier Bonnefon
>>>> Olivier Bonnefon
>>>> INRA PACA-Avignon, Unité BioSP
>>>> Tel: +33 (0)4 32 72 21 58[1]
>>> What most experimenters take for granted before they begin their
>>> experiments is infinitely more interesting than any results to which
>>> their experiments lead.
>>> -- Norbert Wiener
>> --  Olivier Bonnefon INRA PACA-Avignon, Unité BioSP Tel: +33 (0)4 32 72
>> 21 58[1]
> -- Norbert Wiener
Links:
[1] tel:%2B33%20%280%294%2032%2072%2021%2058
URL: <http://lists.mcs.anl.gov/pipermail/petsc-users/attachments/20130821/1760bf8e/attachment.html>
