[petsc-users] When pull the petsc-dev for update:Connection timed out
Zhenglun (Alan) Wei zhenglun.wei at gmail.com
Sun Nov 25 16:16:43 CST 2012
Thank you Sean,
    I changed the
$ cd config/buildsystem
$ hg showconfig paths.default
   to
https://bitbucket.org/petsc/buildsystem
   It gives me 2 extra changes.
   Although, it always giev me the warning of 'certificate not verified', it updated lots of files. Should I just ignore this warning?
   BTW, the reason I used 'https' instead of 'http' is that 'https' is shown in the website you gave to me. :) It may needs to be changed.
thanks,
Alan
> On Sun, Nov 25, 2012 at 12:48 PM, Alan <zhenglun.wei at gmail.com> wrote:
>> Dear Sean,
>>> On Sun, Nov 25, 2012 at 12:30 PM, Alan <zhenglun.wei at gmail.com> wrote:
>>>> Thanks Sean,
>>>>        my /petsc-dev/.hg/hgrc shows:
>>>> [paths]
>>>> default = https://bitbucket.org/petsc/petsc-dev
>>>> [hostfingerprints]
>>>> bitbucket.org =
>>>> 24:9c:45:8b:9c:aa:ba:55:4e:01:6d:58:ff:e4:28:7d:2a:14:ae:3b
>>> Good.
>>>>        When pulling the petsc-dev, it shows:
>>>> abort: no certificate for bitbucket.org with configured hostfingerprint
>>> Weird. Are you behind a proxy?
>> It is. The server is behind a university net.
> Ok, that explains why you still get a warning. You could just try
> http:// (without the 's') but I think bitbucket redirects to https.
> You could try Atlassian's advice here, but your mileage may vary,
> https://answers.atlassian.com/questions/103526/proxy-fakes-certificate-for-mercurial-hg
>>>>        The same thing happens if it pull the BuildSystem with:
>>>> [paths]
>>>> default = https://bitbucket.org/petsc/buildsystem
>>> Something is being misconfigured because I'm guessing that buildsystem
>>> is trying to pull petsc-dev or vice-versa. Let's be sure, by
>>> $ cd $PETSC_DIR
>> It shows:
> Good.
>> It shows:
> This is the problem. Make sure that within the buildsystem directory,
> the .hg/hgrc file (different from the petsc-dev one) has the path for
> bitbucket's buildsystem. If all else fails, you could just reclone.
>>> And might as well send your mercurial version, too,
>>> $ hg version
>> Mercurial Distributed SCM (version 1.8.3)
>> (see http://mercurial.selenic.com for more information)
>> Copyright (C) 2005-2011 Matt Mackall and others
>> This is free software; see the source for copying conditions. There is NO
>> warranty; not even for MERCHANTABILITY or FITNESS FOR A PARTICULAR PURPOSE.
> You may want to upgrade to the latest mercurial which is currently 2.4
> but your version is fine for now.
