[petsc-dev] who did this?
Thu Jul 5 17:40:48 CDT 2012
On Thu, Jul 5, 2012 at 4:27 PM, Jed Brown <jedbrown at mcs.anl.gov> wrote:
> On Thu, Jul 5, 2012 at 2:22 PM, Matthew Knepley <knepley at gmail.com> wrote:
>> Are you just running make targets from Python or are you trying to parse
>>> all the make tests into a richer (and more compact) Python representation?
>> The latter.
> Right, so you need to interpret a little bit of shell, at least to the
> extent of expanding some variables and determining which output file to
> test against. Also, there are some examples that | sort or | grep -v, so
> you may need to recognize that.
I just do regexp.
> I like the semantic information of having multiple tests using the same
> base options and/or comparing to the same output (rather than normalizing
> when you specify the tests).
Shell is not the place for that. Years of putting crapy shell into
makefiles before having to pull it out
should have taught us something.
   Matt
experiments lead.
-- Norbert Wiener
URL: <http://lists.mcs.anl.gov/pipermail/petsc-dev/attachments/20120705/90dc47c7/attachment.html>
