[petsc-dev] who did this?
Thu Jul 5 17:43:52 CDT 2012
On Thu, Jul 5, 2012 at 2:40 PM, Matthew Knepley <knepley at gmail.com> wrote:
> I just do regexp.
Okay, are you missing these sort and grep parts? (regexen are so fragile...)
>> I like the semantic information of having multiple tests using the same
>> base options and/or comparing to the same output (rather than normalizing
>> when you specify the tests).
> Shell is not the place for that. Years of putting crapy shell into
> makefiles before having to pull it out
> should have taught us something.
I agree, but if we can automatically parse those, we can replace them
wholesale with something better.
URL: <http://lists.mcs.anl.gov/pipermail/petsc-dev/attachments/20120705/db389bad/attachment.html>
