[petsc-dev] who did this?
Thu Jul 5 17:27:07 CDT 2012
On Thu, Jul 5, 2012 at 2:22 PM, Matthew Knepley <knepley at gmail.com> wrote:
> Are you just running make targets from Python or are you trying to parse
>> all the make tests into a richer (and more compact) Python representation?
> The latter.
Right, so you need to interpret a little bit of shell, at least to the
extent of expanding some variables and determining which output file to
test against. Also, there are some examples that | sort or | grep -v, so
you may need to recognize that.
I like the semantic information of having multiple tests using the same
base options and/or comparing to the same output (rather than normalizing
when you specify the tests).
URL: <http://lists.mcs.anl.gov/pipermail/petsc-dev/attachments/20120705/639f05fe/attachment.html>
