[Nek5000-users] Conjugate heat transfer with complex properties
Thu Aug 3 10:13:03 CDT 2017
Hi Paul,
Yep, there's some melting going on.  There's a porous structure that
does not melt and wax trapped in the porous structure.  The wax melts
and re-solidifies.  There really nothing complex happening with the
geometry.  A static mesh should do the job. The material properties are
the challenge.  I think I could model the material behavior as having a
non-linear specific heat capacity as a function of temperature.
Adam
On 08/03/2017 09:30 AM, nek5000-users at lists.mcs.anl.gov wrote:
> Hi Adam,
> Can you be more specific?  Is it melting?
> In principle, it should be possible as that was one of the original
> applications for Nek5000.  In practice, however, I would rate that as
> still a research area (at least from the Nek perspective).  I guess
> that melting is much easier than freezing, however.
> Paul
> *From:* Nek5000-users <nek5000-users-bounces at lists.mcs.anl.gov> on
> behalf of nek5000-users at lists.mcs.anl.gov
> <nek5000-users at lists.mcs.anl.gov>
> *Sent:* Thursday, August 3, 2017 8:29:09 AM
> *To:* nek5000-users at lists.mcs.anl.gov
> *Subject:* [Nek5000-users] Conjugate heat transfer with complex
> properties
> Hello,
> I have a conjugate heat transfer problem where the solid material is a
> composite that undergoes a phase transformation.  Is it possible to
> model a material like this in Nek5000?
> Thanks,
> Adam Lange
> Nek5000-users mailing list
URL: <http://lists.mcs.anl.gov/pipermail/nek5000-users/attachments/20170803/7ff7c332/attachment.html>
