[Nek5000-users] Conjugate heat transfer with complex properties
Thu Aug 3 11:19:09 CDT 2017
Yes - that should work.
Set ifuservp = .true. and then, in uservp()
      if (ifield.eq.1) then ! fluid properties
            udiff = param(2)
            utrans = param(1)
      else                            ! thermal properties
            udiff = your diffusivity
            utrans = your rhoCp
      endif
From: Nek5000-users <nek5000-users-bounces at lists.mcs.anl.gov> on behalf of nek5000-users at lists.mcs.anl.gov <nek5000-users at lists.mcs.anl.gov>
Sent: Thursday, August 3, 2017 10:13:03 AM
To: nek5000-users at lists.mcs.anl.gov
Subject: Re: [Nek5000-users] Conjugate heat transfer with complex properties
Hi Paul,
Yep, there's some melting going on.  There's a porous structure that does not melt and wax trapped in the porous structure.  The wax melts and re-solidifies.  There really nothing complex happening with the geometry.  A static mesh should do the job.  The material properties are the challenge.  I think I could model the material behavior as having a non-linear specific heat capacity as a function of temperature.
Adam
On 08/03/2017 09:30 AM, nek5000-users at lists.mcs.anl.gov<mailto:nek5000-users at lists.mcs.anl.gov> wrote:
Hi Adam,
Can you be more specific?  Is it melting?
In principle, it should be possible as that was one of the original applications for Nek5000.  In practice, however, I would rate that as still a research area (at least from the Nek perspective).  I guess that melting is much easier than freezing, however.
Paul
From: Nek5000-users <nek5000-users-bounces at lists.mcs.anl.gov><mailto:nek5000-users-bounces at lists.mcs.anl.gov> on behalf of nek5000-users at lists.mcs.anl.gov<mailto:nek5000-users at lists.mcs.anl.gov> <nek5000-users at lists.mcs.anl.gov><mailto:nek5000-users at lists.mcs.anl.gov>
Sent: Thursday, August 3, 2017 8:29:09 AM
To: nek5000-users at lists.mcs.anl.gov<mailto:nek5000-users at lists.mcs.anl.gov>
Subject: [Nek5000-users] Conjugate heat transfer with complex properties
Hello,
I have a conjugate heat transfer problem where the solid material is a
composite that undergoes a phase transformation.  Is it possible to
model a material like this in Nek5000?
Adam Lange
Nek5000-users mailing list
Nek5000-users at lists.mcs.anl.gov<mailto:Nek5000-users at lists.mcs.anl.gov>
https://lists.mcs.anl.gov/mailman/listinfo/nek5000-users
URL: <http://lists.mcs.anl.gov/pipermail/nek5000-users/attachments/20170803/4f8678e1/attachment.html>
