[Nek5000-users] 2D to 3D
Wed Sep 24 08:07:55 CDT 2014
Dear SL,
It depends on what is in the user file and specifically in your user dat2 subroutine
(given that that appears to be the point of failure from the information in your email).
Did you upgrade this routine to reflect the fact that your simulation is 3D ?
Paul
From: nek5000-users-bounces at lists.mcs.anl.gov [nek5000-users-bounces at lists.mcs.anl.gov] on behalf of nek5000-users at lists.mcs.anl.gov [nek5000-users at lists.mcs.anl.gov]
Sent: Wednesday, September 24, 2014 8:01 AM
To: Nek5000 Users
Subject: [Nek5000-users] 2D to 3D
Hi Nek's
Following this post:
http://lists.mcs.anl.gov/pipermail/nek5000-users/2013-October/002333.html
I'm trying to extrude a 2D file to a 3D file.
First, I've run a 2D case. Then I've used n2to3 to generate the new 3D
.rea file, called: new3d.rea. I've launch a new simulation with
new3d.rea and everything works fine. However, when I include the
information about the 3D extrusion in the usrdat2 subroutine, I get the
following error message if I try to run the code. It seems something
related to the z_average_transpose subroutine. What is wrong? Thanks
  call usrdat
  done :: usrdat
  generate geometry data
  vol_t,vol_v:   1749.7930352474154        1749.7930352474154
  done :: generate geometry data
  call usrdat2
=   BAD TERMINATION OF ONE OF YOUR APPLICATION PROCESSES
=   EXIT CODE: 8
=   CLEANING UP REMAINING PROCESSES
=   YOU CAN IGNORE THE BELOW CLEANUP MESSAGES
APPLICATION TERMINATED WITH THE EXIT STRING: Floating point exception
(signal 8)
SL
Nek5000-users mailing list
Nek5000-users at lists.mcs.anl.gov
https://lists.mcs.anl.gov/mailman/listinfo/nek5000-users
