[Nek5000-users] Extruding 2D .fld file to 3D
Thu Oct 24 06:40:16 CDT 2013
Hi Paul,
This works perfectly! Thanks for your help!
Holly JOHNSON
PhD Student ONERA - DAFE
Département d'Aérodynamique Fondamentale et Expérimentale
8, Rue des Vertugadins
92190 - Meudon - France
Le 24.10.2013 02:52, nek5000-users at lists.mcs.anl.gov a écrit :
> Hi Holly,
> I would likely do this in usrdat2().
> Suppose my 2D problem had 70 elements. The the following
> should work:
> In SIZE, set lelx=70,lely=1, and lelz=# of levels in your extruded
> geometry.
> In usrdat2() in the .usr file, set nelx=lelx,nely=lely,nelz=lelz.
> Then:
>       parameter (l2d=lx1*ly1*lelx) ! Number of points in 2D field
>       common /mystuff/ u2d(l2d),v2d(l2d)
>       if (nid.eq.0) then
>          open(33,file='my2dfile.dat')
>          do i=1,l2d
>             read(33,*) u2d(i),v2d(i)
>          enddo
>          close(33)
>       endif
>       nbytes = 8*l2d
>       call bcast(u2d,nbytes)
>       call bcast(v2d,nbytes)
> Once you load your 2D data you can use
>       call z_average_transpose(vx,u2d)
>       call z_average_transpose(vy,v2d)
> to map this to 3D.
> After that, I would just dump the 3D results and exit:
>       call outpost(vx,vy,vz,pr,t,'   ')
>       call exitti('Quit in usrdat2.$',nelgt)
> This _should_ work, but probably needs a couple iterations
> to get everything correct.
> To generate myfile2d.dat, I would do the following:
> 1) Run the 2D code and dump an ascii .fld file by setting
>    param(66)=0 in usrdat2 or userchk prior to output the fld file.
> 2) Edit the resultant .fld file and get rid of the first few
>    line at the top of that file so that your u,v data is all
>    that it holds.  (Look both at the top and bottom of the file
>    when you're ready -- they should have the same column format.)
> Hope this helps.
> Paul
> On Wed, 23 Oct 2013, nek5000-users at lists.mcs.anl.gov wrote:
>> Hello Neks !
>> In order to reduce runtime, it would be useful to be able to run a 2D
>> simulation and extrude the results to a 3D domain when using a 2D
>> model (for example the Rankine vortex). Is it possible to extrude a 2D
>> .fld file to a 3D one ? I was thinking of loading a 2D .fld file into
>> a 3D simulation using something similar to load_fld() and then using
>> loops to impose the same velocity to all the points in the domain.
>> However load_fld() doesn't seem to like loading a 2D .fld in a 3D
>> simulation. Has anyone else had this problem ?
>> Holly JOHNSON
>> Nek5000-users mailing list
>> Nek5000-users at lists.mcs.anl.gov
>> https://lists.mcs.anl.gov/mailman/listinfo/nek5000-users
> uuuu
> c-----------------------------------------------------------------------
>       subroutine q_filter(wght)
> c
> c     filter vx,vy,vz, and p by simple interpolation
> c
>       include 'SIZE'
>       include 'TOTAL'
> c
> c
> c     These are the dimensions that we interpolate onto for v and p:
>       parameter(lxv=lx1-1)
>       parameter(lxp=lx2-1)
> c
>       real intdv(lx1,lx1)
>       real intuv(lx1,lx1)
>       real intdp(lx1,lx1)
>       real intup(lx1,lx1)
>       real intv(lx1,lx1)
>       real intp(lx1,lx1)
> c
>       save intdv
>       save intuv
>       save intdp
>       save intup
>       save intv
>       save intp
>       common /ctmp0/ intw,intt
>      $             , wk1,wk2
>      $             , zgmv,wgtv,zgmp,wgtp,tmax(100),omax(103)
>       real intw(lx1,lx1)
>       real intt(lx1,lx1)
>       real wk1  (lx1,lx1,lx1,lelt)
>       real wk2  (lx1,lx1,lx1)
>       real zgmv(lx1),wgtv(lx1),zgmp(lx1),wgtp(lx1)
> c
> c     outpost arrays
>       parameter (lt=lx1*ly1*lz1*lelv)
>       common /scruz/ w1(lt),w2(lt),w3(lt),wt(lt)
>       character*18 sfmt
>       integer icalld
>       save    icalld
>       data    icalld /0/
>       imax = nid
>       imax = iglmax(imax,1)
>       jmax = iglmax(imax,1)
>       if (icalld.eq.0) then
>          icalld = 1
>          ncut = param(101)+1
>          call build_new_filter(intv,zgm1,nx1,ncut,wght,nid)
>       elseif (icalld.lt.0) then   ! old (std.) filter
>          icalld = 1
>          call zwgll(zgmv,wgtv,lxv)
>          call igllm(intuv,intw,zgmv,zgm1,lxv,nx1,lxv,nx1)
>          call igllm(intdv,intw,zgm1,zgmv,nx1,lxv,nx1,lxv)
> c
>          call zwgl (zgmp,wgtp,lxp)
>          call iglm (intup,intw,zgmp,zgm2,lxp,nx2,lxp,nx2)
>          call iglm (intdp,intw,zgm2,zgmp,nx2,lxp,nx2,lxp)
> c
> c        Multiply up and down interpolation into single operator
> c
>          call mxm(intup,nx2,intdp,lxp,intp,nx2)
>          call mxm(intuv,nx1,intdv,lxv,intv,nx1)
> c
> c        Weight the filter to make it a smooth (as opposed to
> truncated)
> c        decay in wave space
> c
>          w0 = 1.-wght
>          call ident(intup,nx2)
>          call add2sxy(intp,wght,intup,w0,nx2*nx2)
> c
>          call ident   (intuv,nx1)
>          call add2sxy (intv ,wght,intuv,w0,nx1*nx1)
> c
> c        if (nid.eq.0) call outmatx(intp,nx2,nx2,21,'flt2')
> c        if (nid.eq.0) call outmatx(zgm2 ,nx2,1  ,22,'zgm2')
> c        if (nid.eq.0) call outmatx(intv,nx1,nx1,11,'flt1')
> c        if (nid.eq.0) call outmatx(zgm1 ,nx1,1  ,12,'zgm1')
> c
>       endif
>       ifldt  = ifield
> c     ifield = 1
>       if ( (ifflow.and. .not. ifmhd)  .or.
>      $     (ifield.eq.1 .and. ifmhd)      ) then
>          call filterq(vx,intv,nx1,nz1,wk1,wk2,intt,if3d,umax)
>          call filterq(vy,intv,nx1,nz1,wk1,wk2,intt,if3d,vmax)
>          if (if3d)
>      $      call filterq(vz,intv,nx1,nz1,wk1,wk2,intt,if3d,wmax)
>          if (ifsplit.and..not.iflomach)
>      $      call filterq(pr,intv,nx1,nz1,wk1,wk2,intt,if3d,pmax)
>       endif
> c
>       if (ifmhd.and.ifield.eq.ifldmhd) then
>          call filterq(bx,intv,nx1,nz1,wk1,wk2,intt,if3d,umax)
>          call filterq(by,intv,nx1,nz1,wk1,wk2,intt,if3d,vmax)
>          if (if3d)
>      $   call filterq(bz,intv,nx1,nz1,wk1,wk2,intt,if3d,wmax)
>       endif
> c
>       if (ifpert) then
>         do j=1,npert
>          ifield = 1
>          call filterq(vxp(1,j),intv,nx1,nz1,wk1,wk2,intt,if3d,umax)
>          call filterq(vyp(1,j),intv,nx1,nz1,wk1,wk2,intt,if3d,vmax)
>          if (if3d)
>      $   call filterq(vzp(1,j),intv,nx1,nz1,wk1,wk2,intt,if3d,wmax)
>          ifield = 2
>          if (ifheat .and. .not.ifcvode)
>      $   call filterq(tp(1,j,1),intv,nx1,nz1,wk1,wk2,intt,if3d,wmax)
>         enddo
>       endif
> c
>       mmax = 0
>       if (ifflow) then
> c        pmax    = glmax(pmax,1)
>          omax(1) = glmax(umax,1)
>          omax(2) = glmax(vmax,1)
>          omax(3) = glmax(wmax,1)
>          mmax = ndim
>       endif
> c
>       nfldt = 1+npscal
>       if (ifheat .and. .not.ifcvode) then
>          do ifld=1,nfldt
>             ifield = ifld + 1
>             call filterq(t(1,1,1,1,ifld),intv
>      $                  ,nx1,nz1,wk1,wk2,intt,if3d,tmax(ifld))
>             mmax = mmax+1
>             omax(mmax) = glmax(tmax(ifld),1)
>          enddo
>       endif
>       if (nid.eq.0) then
>          if (npscal.eq.0) then
> c           write(6,101) mmax
> c           write(sfmt,101) mmax
> c 101       format('''(i8,1p',i1,'e12.4,a6)''')
> c           write(6,sfmt) istep,(omax(k),k=1,mmax),' qfilt'
> c         write(6,'(i8,1p4e12.4,a6)') istep,(omax(k),k=1,mmax),' qfilt'
>          else
>             if (if3d) then
>                write(6,1) istep,ifield,umax,vmax,wmax
>             else
>             endif
>     1       format(4x,i7,i3,' qfilt:',1p3e12.4)
>             if(ifheat .and. .not.ifcvode)
>      &            write(6,'(1p50e12.4)') (tmax(k),k=1,nfldt)
>          endif
>       endif
>       ifield = ifldt   ! RESTORE ifield
>       return
>       end
>       subroutine filterq(v,f,nx,nz,w1,w2,ft,if3d,dmax)
> c
>       include 'SIZE'
>       include 'TSTEP'
>       real v(nx*nx*nz,nelt),w1(1),w2(1)
>       logical if3d
> c
>       real f(nx,nx),ft(nx,nx)
> c
>       integer e
> c
>       call transpose(ft,nx,f,nx)
> c
>       nxyz=nx*nx*nz
>       dmax = 0.
>       nel = nelfld(ifield)
>       if (if3d) then
>          do e=1,nel
> c           Filter
>             call copy(w2,v(1,e),nxyz)
>             call mxm(f,nx,w2,nx,w1,nx*nx)
>             i=1
>             j=1
>             do k=1,nx
>                call mxm(w1(i),nx,ft,nx,w2(j),nx)
>                i = i+nx*nx
>                j = j+nx*nx
>             enddo
>             call mxm (w2,nx*nx,ft,nx,w1,nx)
>             call sub3(w2,v(1,e),w1,nxyz)
>             call copy(v(1,e),w1,nxyz)
>             smax = vlamax(w2,nxyz)
>             dmax = max(dmax,abs(smax))
>          enddo
> c
>       else
>          do e=1,nel
> c           Filter
>             call copy(w1,v(1,e),nxyz)
>             call mxm(f ,nx,w1,nx,w2,nx)
>             call mxm(w2,nx,ft,nx,w1,nx)
> c
>          enddo
>       endif
> c
>       return
>       end
>       subroutine outmatx(a,m,n,io,name)
>       real a(m*n)
>       character*4 name
> c
>       open(unit=io,file=name)
>       do i=1,m*n
>          write(io,1) a(i)
>       enddo
>     1 format(1p1e22.13)
>       close(unit=io)
> c
>       return
>       end
>       subroutine drag_calc(scale)
> c
>       INCLUDE 'SIZE'
>       INCLUDE 'TOTAL' c
>       common /scrns/         pm1(lx1,ly1,lz1,lelv)
> $,vxx(lx1,ly1,lz1,lelv),vxy(lx1,ly1,lz1,lelv),vxz(lx1,ly1,lz1,lelv)
> $,vyx(lx1,ly1,lz1,lelv),vyy(lx1,ly1,lz1,lelv),vyz(lx1,ly1,lz1,lelv)
>       common /scruz/
> vzx(lx1,ly1,lz1,lelv),vzy(lx1,ly1,lz1,lelv),vzz(lx1,ly1,lz1,lelv)
>      $,one(lx1,ly1,lz1,lelv)
>        real work(1)
>        equivalence (work,one)
> c
>       common /cdrag/ dragx(0:maxobj),dragy(0:maxobj),dragz(0:maxobj)
>      $             ,  momx(0:maxobj), momy(0:maxobj), momz(0:maxobj)
>      $             ,  dpdx_mean,dpdy_mean,dpdz_mean
>       real momx ,momy ,momz
> c
>       common /tdrag/ drag(11)
>       real dragpx,dragpy,dragpz,dragvx,dragvy,dragvz
>       real momvx ,momvy ,momvz
>       real check1,check2
> c
>       equivalence (dragpx,drag(1)),(dragpy,drag(2)),(dragpz,drag(3))
>       equivalence (dragvx,drag(4)),(dragvy,drag(5)),(dragvz,drag(6))
>       equivalence (momvx ,drag(7)),(momvy ,drag(8)),(momvz ,drag(9))
>       equivalence (check1,drag(10)),(check2,drag(11))
>       common /cvflow_r/ flow_rate,base_flow,domain_length,xsec
>      $                , scale_vf(3)
>       ntot1  = nx1*ny1*nz1*nelv
> c    Map pressure onto mesh 1   (vxx and vyy are used as work arrays)
>       call mappr(pm1,pr,vxx,vyy)
>       call rone (one,ntot1)
> c
> c    Add mean_pressure_gradient.X to p:
>       if (param(55).ne.0) then
>          dpdx_mean = -scale_vf(1)
>          dpdy_mean = -scale_vf(2)
>          dpdz_mean = -scale_vf(3)
>       endif
>       call add2s2(pm1,xm1,dpdx_mean,ntot1)  ! Doesn't work if object is
> cut by
>       call add2s2(pm1,ym1,dpdy_mean,ntot1)  ! periodicboundary.  In
> this case,
>       call add2s2(pm1,zm1,dpdz_mean,ntot1)  ! set ._mean=0 and
> compensate in
> c                                           ! usrchk()  [ pff 10/21/04
> c    Compute du/dn
>                 CALL DUDXYZ (vxx,vx,RXM1,SXM1,TXM1,JACM1,1,1)
>                 CALL DUDXYZ (vxy,vx,RYM1,SYM1,TYM1,JACM1,1,1)
>       if (if3d) CALL DUDXYZ (vxz,vx,RZM1,SZM1,TZM1,JACM1,1,1)
> c
>                 CALL DUDXYZ (vyx,vy,RXM1,SXM1,TXM1,JACM1,1,1)
>                 CALL DUDXYZ (vyy,vy,RYM1,SYM1,TYM1,JACM1,1,1)
>       if (if3d) CALL DUDXYZ (vyz,vy,RZM1,SZM1,TZM1,JACM1,1,1)
> c
>       if (if3d) then
>                 CALL DUDXYZ (vzx,vz,RXM1,SXM1,TXM1,JACM1,1,1)
>                 CALL DUDXYZ (vzy,vz,RYM1,SYM1,TYM1,JACM1,1,1)
>                 CALL DUDXYZ (vzz,vz,RZM1,SZM1,TZM1,JACM1,1,1)
>       endif
> c
> c     Fill up viscous array w/ default
> c
>       if (istep.lt.1) call cfill(vdiff,param(2),ntot1)
> c
>       call col2(vxx,vdiff,ntot1)
>       call col2(vxy,vdiff,ntot1)
>       call col2(vxz,vdiff,ntot1)
>       call col2(vyx,vdiff,ntot1)
>       call col2(vyy,vdiff,ntot1)
>       call col2(vyz,vdiff,ntot1)
>       call col2(vzx,vdiff,ntot1)
>       call col2(vzy,vdiff,ntot1)
>       call col2(vzz,vdiff,ntot1)
> c
>       dragxt=0.0
>       dragyt=0.0
>       dragzt=0.0
> c
>       DO 100 II=1,NHIS
>          IF (HCODE(10,II).NE.'I') GOTO 100
>          IOBJ   = LOCHIS(1,II)
>          MEMTOT = NMEMBER(IOBJ)
> C
> c
>          IF (HCODE(1,II).NE.' ' .OR. HCODE(2,II).NE.' ' .OR.
>      $       HCODE(3,II).NE.' ' ) THEN
>             IFIELD = 1
> c
> c---------------------------------------------------------------------------
> c           Compute drag for this object
> c
>             dragvx=0.0
>             dragvy=0.0
>             dragvz=0.0
>             dragpx=0.0
>             dragpy=0.0
>             dragpz=0.0
> c
>             momvx=0.0
>             momvy=0.0
>             momvz=0.0
> c
>             check1=0.0
>             check2=0.0
>             DO 50 MEM=1,MEMTOT
>                ISK   = 0
>                IEG   = OBJECT(IOBJ,MEM,1)
>                IFC   = OBJECT(IOBJ,MEM,2)
>                IF (GLLNID(IEG).EQ.NID) THEN
> C                 This processor has a contribution
>                   IE = GLLEL(IEG)
> c
> c                 Pressure drag
>                   check1=check1+facint(one,one,area,ifc,ie)
>                   check2=check2+facint(one,uny,area,ifc,ie)
> c
>                   dragpx=dragpx+facint(pm1,unx,area,ifc,ie)
>                   dragpy=dragpy+facint(pm1,uny,area,ifc,ie)
>                   if (if3d) dragpz=dragpz+facint(pm1,unz,area,ifc,ie)
> c
> c                 Viscous drag
>                   if (if3d) then
>                      dragvx=dragvx+facint(vxx,unx,area,ifc,ie)
>      $                            +facint(vxy,uny,area,ifc,ie)
>      $                            +facint(vxz,unz,area,ifc,ie)
>      $                            +facint(vxx,unx,area,ifc,ie)
>      $                            +facint(vyx,uny,area,ifc,ie)
>      $                            +facint(vzx,unz,area,ifc,ie)
>                      dragvy=dragvy+facint(vyx,unx,area,ifc,ie)
>      $                            +facint(vyy,uny,area,ifc,ie)
>      $                            +facint(vyz,unz,area,ifc,ie)
>      $                            +facint(vxy,unx,area,ifc,ie)
>      $                            +facint(vzy,unz,area,ifc,ie)
>                      dragvz=dragvz+facint(vzx,unx,area,ifc,ie)
>      $                            +facint(vzy,uny,area,ifc,ie)
>      $                            +facint(vzz,unz,area,ifc,ie)
>      $                            +facint(vxz,unx,area,ifc,ie)
>      $                            +facint(vyz,uny,area,ifc,ie)
> c
>                      momvx=momvx-facint2(vxy,unx,unz,area,ifc,ie)
>      $                        -facint2(vyx,unx,unz,area,ifc,ie)
>      $                        -facint2(vyy,uny,unz,area,ifc,ie)
>      $                        -facint2(vzy,unz,unz,area,ifc,ie)
>      $                        -facint2(vyz,unz,unz,area,ifc,ie)
>      $                        +facint2(vxz,unx,uny,area,ifc,ie)
>      $                        +facint2(vzx,unx,uny,area,ifc,ie)
>      $                        +facint2(vyz,uny,uny,area,ifc,ie)
>      $                        +facint2(vzy,uny,uny,area,ifc,ie)
>      $                        +facint2(vzz,unz,uny,area,ifc,ie)
>                      momvy=momvy+facint2(vxx,unx,unz,area,ifc,ie)
>      $                        +facint2(vxx,unx,unz,area,ifc,ie)
>      $                        +facint2(vyx,uny,unz,area,ifc,ie)
>      $                        +facint2(vxy,uny,unz,area,ifc,ie)
>      $                        +facint2(vzx,unz,unz,area,ifc,ie)
>      $                        +facint2(vxz,unz,unz,area,ifc,ie)
>      $                        -facint2(vxz,unx,unx,area,ifc,ie)
>      $                        -facint2(vzx,unx,unx,area,ifc,ie)
>      $                        -facint2(vyz,uny,unx,area,ifc,ie)
>      $                        -facint2(vzy,uny,unx,area,ifc,ie)
>      $                        -facint2(vzz,unz,unx,area,ifc,ie)
>                      momvz=momvz-facint2(vxx,unx,uny,area,ifc,ie)
>      $                        -facint2(vxx,unx,uny,area,ifc,ie)
>      $                        -facint2(vyx,uny,uny,area,ifc,ie)
>      $                        -facint2(vxy,uny,uny,area,ifc,ie)
>      $                        -facint2(vzx,unz,uny,area,ifc,ie)
>      $                        -facint2(vxz,unz,uny,area,ifc,ie)
>      $                        +facint2(vxy,unx,unx,area,ifc,ie)
>      $                        +facint2(vyx,unx,unx,area,ifc,ie)
>      $                        +facint2(vyy,uny,unx,area,ifc,ie)
>      $                        +facint2(vzy,unz,unx,area,ifc,ie)
>      $                        +facint2(vyz,unz,unx,area,ifc,ie) c
>                   else
>                   endif
>                ENDIF
>    50       CONTINUE
> c
> c          Sum contributions from all processors
>             call gop(drag,work,'+  ',11)
>             dragvx = -dragvx
>             dragvy = -dragvy
>             dragvz = -dragvz
>          ENDIF
> c
> c        Scale by user specified scale factor (for convenience)
> c
>          dragvx = scale*dragvx
>          dragvy = scale*dragvy
>          dragvz = scale*dragvz
> c
>          dragpx = scale*dragpx
>          dragpy = scale*dragpy
>          dragpz = scale*dragpz
> c
>          dragx(iobj) = dragvx+dragpx
>          dragy(iobj) = dragvy+dragpy
>          dragz(iobj) = dragvz+dragpz
> c
> c
>          momx(iobj)  = 0.5*momvx
>          momy(iobj)  = 0.5*momvy
>          momz(iobj)  = 0.5*momvz
> c
>          dragxt = dragxt + dragx(iobj)
>          dragyt = dragyt + dragy(iobj)
>          dragzt = dragzt + dragz(iobj)
> c
>          if (nid.eq.0.and.istep.eq.1)
>      $      write(6,*) 'drag_calc: scale=',scale
>          if (nid.eq.0) then
>             write(6,6)
> istep,time,dragx(iobj),dragpx,dragvx,'dragx',iobj
>             write(6,6)
> istep,time,dragy(iobj),dragpy,dragvy,'dragy',iobj
>             if (if3d)
>      $      write(6,6)
> istep,time,dragz(iobj),dragpz,dragvz,'dragz',iobj
> c
> c done by zly (3/17/03)
> c          if(if3d) then
> c             write(6,113) istep,time,momx,momy,momz
> c          else
> c             write(6,112) istep,time,momx,momy
> c          endif
> c
>          endif
>     6    format(i8,1p4e15.7,2x,a5,i5)
>   112    format(i6,1p3e15.7,'  momx')
>   113    format(i6,1p4e15.7,'  momx')
>          if (istep.lt.10.and.nid.eq.0)
>      $      write(6,9) 'check:',check1,check2,dpdx_mean,istep
>     9    format(a6,1p3e16.8,i9)
> c        if (time.gt.1.0.and.dragx.gt.10.) call emerxit
>   100 continue
> c
>       if (nid.eq.0) then
>          write(6,6) istep,time,dragxt,dragpx,dragvx,'drgxt',iobj
>          write(6,6) istep,time,dragyt,dragpy,dragvy,'drgyt',iobj
>          if (if3d)
>      $   write(6,6) istep,time,dragzt,dragpz,dragvz,'drgzt',iobj
>       endif
> c
>       dragx(0) = dragxt
>       dragy(0) = dragyt
>       dragz(0) = dragzt
> c
>       return
>       end
>       subroutine mappr(pm1,pm2,pa,pb)
> c
>       INCLUDE 'SIZE'
>       INCLUDE 'TOTAL'
>       real pm1(lx1,ly1,lz1,lelv),pm2(lx2,ly2,lz2,lelv)
>      $    ,pa (lx1,ly2,lz2)     ,pb (lx1,ly1,lz2)
> c
> C     Map the pressure onto the velocity mesh
> C
>       NGLOB1 = NX1*NY1*NZ1*NELV
>       NYZ2   = NY2*NZ2
>       NXY1   = NX1*NY1
>       NXYZ   = NX1*NY1*NZ1
> C
>       IF (IFSPLIT) THEN
>          CALL COPY(PM1,PM2,NGLOB1)
>       ELSE
>          DO 1000 IEL=1,NELV
>             CALL MXM (IXM21,NX1,PM2(1,1,1,IEL),NX2,pa (1,1,1),NYZ2)
>             DO 100 IZ=1,NZ2
>                CALL MXM (PA(1,1,IZ),NX1,IYTM21,NY2,PB(1,1,IZ),NY1)
>  100        CONTINUE
>             CALL MXM (PB(1,1,1),NXY1,IZTM21,NZ2,PM1(1,1,1,IEL),NZ1)
>  1000    CONTINUE
> C     Average the pressure on elemental boundaries
>        IFIELD=1
>        CALL DSSUM (PM1,NX1,NY1,NZ1)
>        CALL COL2  (PM1,VMULT,NGLOB1)
>       ENDIF
> C
> C
>       return
>       end
> c
>       function facint_a(a,area,f,e)
> c     Integrate areal array a() on face f of element e.  27 June, 2012
> pff
> c     f  is in the preprocessor notation
>       include 'SIZE'
>       include 'TOPOL'
>       real a(lx1,lz1,6,lelt),area(lx1,lz1,6,lelt)
>       integer e,f
>       sum=0.0
>       do i=1,lx1*lz1
>          sum = sum + a(i,1,f,e)*area(i,1,f,e)
>       enddo
>       facint_a = sum
>       return
>       end
>       function facint_v(a,area,f,e)
> c     Integrate volumetric array a() on face f of element e
> c        fd  is the dssum notation.
> c        27 June, 2012            PFF
>       include 'SIZE'
>       include 'TOPOL'
>       real a(lx1,ly1,lz1,lelt),area(lx1,lz1,6,lelt)
>       integer e,f,fd
>       call dsset(nx1,ny1,nz1) ! set counters
>       fd     = eface1(f)
>       js1    = skpdat(1,fd)
>       jf1    = skpdat(2,fd)
>       jskip1 = skpdat(3,fd)
>       js2    = skpdat(4,fd)
>       jf2    = skpdat(5,fd)
>       jskip2 = skpdat(6,fd)
>       sum=0.0
>       i = 0
>       do 100 j2=js2,jf2,jskip2
>       do 100 j1=js1,jf1,jskip1
>          i = i+1
>          sum = sum + a(j1,j2,1,e)*area(i,1,f,e)
>   100 continue
>       facint_v = sum
>       return
>       end
>       function facint(a,b,area,ifc,ie)
> c
> C
> C     Take the dot product of A and B on the surface IFACE1 of element
> IE.
> C
> C         IFACE1 is in the preprocessor notation
> C         IFACE  is the dssum notation.
> C         5 Jan 1989 15:12:22      PFF
> C
>       INCLUDE 'SIZE'
>       INCLUDE 'TOPOL'
>       DIMENSION A    (LX1,LY1,LZ1,lelv)
>      $         ,B    (lx1,lz1,6,lelv)
>      $         ,area (lx1,lz1,6,lelv)
> C
> C     Set up counters
> C
>       CALL DSSET(NX1,NY1,NZ1)
>       IFACE  = EFACE1(IFC)
>       JS1    = SKPDAT(1,IFACE)
>       JF1    = SKPDAT(2,IFACE)
>       JSKIP1 = SKPDAT(3,IFACE)
>       JS2    = SKPDAT(4,IFACE)
>       JF2    = SKPDAT(5,IFACE)
>       JSKIP2 = SKPDAT(6,IFACE)
> C
>       SUM=0.0
>       I = 0
>       DO 100 J2=JS2,JF2,JSKIP2
>       DO 100 J1=JS1,JF1,JSKIP1
>          I = I+1
>          SUM = SUM + A(J1,J2,1,ie)*B(I,1,ifc,ie)*area(I,1,ifc,ie)
> c        SUM = SUM + A(J1,J2,1,ie)*B(J1,J2,1,ie)*area(I,1,ifc,ie)
>   100 CONTINUE
> C
>       facint = SUM
> c
>       return
>       end
>       function facint2(a,b,c,area,ifc,ie)
>       include 'SIZE'
>       include 'TOPOL'
>       dimension a    (lx1,ly1,lz1,lelv)
>      $        , b    (lx1,lz1,6,lelv)
>      $        , c    (lx1,lz1,6,lelv)
>      $        , area (lx1,lz1,6,lelv)
>       iface  = eface1(ifc)
>       js1    = skpdat(1,iface)
>       jf1    = skpdat(2,iface)
>       jskip1 = skpdat(3,iface)
>       js2    = skpdat(4,iface)
>       jf2    = skpdat(5,iface)
>       jskip2 = skpdat(6,iface)
>       sum=0.0
>       i=0
>       do j2=js2,jf2,jskip2
>       do j1=js1,jf1,jskip1
>          i=i+1
>          sum=sum+a(j1,j2,1,ie)*b(i,1,ifc,ie)*c(i,1,ifc,ie)
>      $          *area(i,1,ifc,ie)
>       end do
>       end do
>       facint2=sum
>       return
>       end
>       subroutine out_csrmats(acsr,ia,ja,n,name9)
>       real    acsr(1)
>       integer ia(1),ja(1)
> c
>       character*9 name9
>       character*9 s(16)
> c
>       nnz = ia(n+1)-ia(1)
> c
>       write(6,1) name9,n,nnz
>     1 format(/,'CSR Mat:',a9,3x,'n =',i5,3x,'nnz =',i5,/)
> c
>       n16 = min(n,16)
>       n29 = min(n,29)
>       do i=1,n29
>          call blank(s,9*16)
>          n1 = ia(i)
>          n2 = ia(i+1)-1
>          do jj=n1,n2
>             j = ja  (jj)
>             a = acsr(jj)
>             if (a.ne.0..and.j.le.n16) write(s(j),9) a
>          enddo
>          write(6,16) (s(k),k=1,n16)
>       enddo
>     9 format(f9.4)
>    16 format(16a9)
> c
>       return
>       end
>       subroutine local_grad3(ur,us,ut,u,N,e,D,Dt)
> c     Output: ur,us,ut         Input:u,N,e,D,Dt
>       real ur(0:N,0:N,0:N),us(0:N,0:N,0:N),ut(0:N,0:N,0:N)
>       real u (0:N,0:N,0:N,1)
>       real D (0:N,0:N),Dt(0:N,0:N)
>       integer e
> c
>       m1 = N+1
>       m2 = m1*m1
> c
>       call mxm(D ,m1,u(0,0,0,e),m1,ur,m2)
>       do k=0,N
>          call mxm(u(0,0,k,e),m1,Dt,m1,us(0,0,k),m1)
>       enddo
>       call mxm(u(0,0,0,e),m2,Dt,m1,ut,m1)
> c
>       return
>       end
>       subroutine local_grad2(ur,us,u,N,e,D,Dt)
> c     Output: ur,us         Input:u,N,e,D,Dt
>       real ur(0:N,0:N),us(0:N,0:N)
>       real u (0:N,0:N,1)
>       integer e
> c
>       m1 = N+1
> c
>       call mxm(D ,m1,u(0,0,e),m1,ur,m1)
>       call mxm(u(0,0,e),m1,Dt,m1,us,m1)
> c
>       return
>       end
>       subroutine gradm1(ux,uy,uz,u)
> c
> c     Compute gradient of T -- mesh 1 to mesh 1 (vel. to vel.)
> c
>       include 'SIZE'
>       include 'DXYZ'
>       include 'GEOM'
>       include 'INPUT'
>       include 'TSTEP'
> c
>       parameter (lxyz=lx1*ly1*lz1)
>       real ux(lxyz,1),uy(lxyz,1),uz(lxyz,1),u(lxyz,1)
>       common /ctmp1/ ur(lxyz),us(lxyz),ut(lxyz)
>       integer e
>       nxyz = nx1*ny1*nz1
>       ntot = nxyz*nelt
>       N = nx1-1
>       do e=1,nelt
>          if (if3d) then
>             call local_grad3(ur,us,ut,u,N,e,dxm1,dxtm1)
>             do i=1,lxyz
>                ux(i,e) = jacmi(i,e)*(ur(i)*rxm1(i,1,1,e)
>      $                             + us(i)*sxm1(i,1,1,e)
>      $                             + ut(i)*txm1(i,1,1,e) )
>                uy(i,e) = jacmi(i,e)*(ur(i)*rym1(i,1,1,e)
>      $                             + us(i)*sym1(i,1,1,e)
>      $                             + ut(i)*tym1(i,1,1,e) )
>                uz(i,e) = jacmi(i,e)*(ur(i)*rzm1(i,1,1,e)
>      $                             + us(i)*szm1(i,1,1,e)
>      $                             + ut(i)*tzm1(i,1,1,e) )
>             enddo
>          else
>             if (ifaxis) call setaxdy (ifrzer(e))
>             call local_grad2(ur,us,u,N,e,dxm1,dytm1)
>             do i=1,lxyz
>                ux(i,e) =jacmi(i,e)*(ur(i)*rxm1(i,1,1,e)
>      $                            + us(i)*sxm1(i,1,1,e) )
>                uy(i,e) =jacmi(i,e)*(ur(i)*rym1(i,1,1,e)
>      $                            + us(i)*sym1(i,1,1,e) )
>             enddo
>          endif
>       enddo
> c
>       return
>       end
>       subroutine comp_vort3(vort,work1,work2,u,v,w)
> c
>       include 'SIZE'
>       include 'TOTAL'
> c
>       parameter(lt=lx1*ly1*lz1*lelv)
>       real vort(lt,3),work1(1),work2(1),u(1),v(1),w(1)
> c
>       ntot  = nx1*ny1*nz1*nelv
>       if (if3d) then
> c        work1=dw/dy ; work2=dv/dz
>            call dudxyz(work1,w,rym1,sym1,tym1,jacm1,1,2)
>            call dudxyz(work2,v,rzm1,szm1,tzm1,jacm1,1,3)
>            call sub3(vort(1,1),work1,work2,ntot)
> c        work1=du/dz ; work2=dw/dx
>            call dudxyz(work1,u,rzm1,szm1,tzm1,jacm1,1,3)
>            call dudxyz(work2,w,rxm1,sxm1,txm1,jacm1,1,1)
>            call sub3(vort(1,2),work1,work2,ntot)
> c        work1=dv/dx ; work2=du/dy
>            call dudxyz(work1,v,rxm1,sxm1,txm1,jacm1,1,1)
>            call dudxyz(work2,u,rym1,sym1,tym1,jacm1,1,2)
>            call sub3(vort(1,3),work1,work2,ntot)
>       else
>            call sub3(vort,work1,work2,ntot)
>       endif
> c
> c    Avg at bndry
> c
>       ifielt = ifield
>       ifield = 1
>       if (if3d) then
>          do idim=1,ndim
>             call col2  (vort(1,idim),bm1,ntot)
>             call dssum (vort(1,idim),nx1,ny1,nz1)
>             call col2  (vort(1,idim),binvm1,ntot)
>          enddo
>       else
>          call col2  (vort,bm1,ntot)
>          call dssum (vort,nx1,ny1,nz1)
>          call col2  (vort,binvm1,ntot)
>       endif
>       ifield = ifielt
> c
>       return
>       end
>       subroutine surface_int(sint,sarea,a,ie,iface1)
> C
>       include 'SIZE'
>       include 'GEOM'
>       include 'PARALLEL'
>       include 'TOPOL'
>       real a(lx1,ly1,lz1,1)
> c
>       integer icalld
>       save    icalld
>       data    icalld/0/
>       logical ifpf
>       save    ifpf
> c
>          icalld=icalld+1
>          if (skpdat(1,2).eq.nx1) then
> c           write(6,*) 'In surface_int, using pf version of skpdat.'
>             ifpf = .true.
>          else
> c           write(6,*) 'In surface_int, using std version of skpdat.'
>             ifpf = .false.
>          endif
>       endif
> C
>       sarea = 0.
>       sint  = 0.
> C
>       iface  = eface1(iface1)
> c
> c     Check skpdat (because of difference in pf vs. commercial
> version...arrghh)
> c
>       if (ifpf) then
> c        pf version
>       else
> c        std version
>          js1    = skpdat(iface,1)
>          jf1    = skpdat(iface,2)
>          jskip1 = skpdat(iface,3)
>          js2    = skpdat(iface,4)
>          jf2    = skpdat(iface,5)
>          jskip2 = skpdat(iface,6)
>       endif
> C
>       I = 0
>          I = I+1
>          sarea = sarea+area(i,1,iface1,ie)
>          sint  = sint +area(i,1,iface1,ie)*a(j1,j2,1,ie)
>   100 continue
> C
>       return
>       end
>       subroutine surface_flux(dq,qx,qy,qz,ie,iface,w)
> C
>       include 'SIZE'
>       include 'GEOM'
>       include 'INPUT'
>       include 'PARALLEL'
>       include 'TOPOL'
>       parameter (l=lx1*ly1*lz1)
>       real w(lx1,ly1,lz1),qx(l,1),qy(l,1),qz(l,1)
> c
>       integer icalld
>       save    icalld
>       data    icalld/0/
>       logical ifpf
>       save    ifpf
> c
>          icalld=icalld+1
> c           write(6,*) 'In surface_flux, using pf version of skpdat.'
>             ifpf = .true.
>          else
> c           write(6,*) 'In surface_flux, using std version of skpdat.'
>             ifpf = .false.
>          endif
>       endif
> C
>       ifacepf  = eface1(iface)
> c
> version...arrghh)
> c
>       if (ifpf) then
> c        pf version
>          js1    = skpdat(1,ifacepf)
>          jf1    = skpdat(2,ifacepf)
>          jskip1 = skpdat(3,ifacepf)
>          js2    = skpdat(4,ifacepf)
>          jf2    = skpdat(5,ifacepf)
>          jskip2 = skpdat(6,ifacepf)
>       else
> c        std version
>          js1    = skpdat(ifacepf,1)
>          jf1    = skpdat(ifacepf,2)
>          jskip1 = skpdat(ifacepf,3)
>          js2    = skpdat(ifacepf,4)
>          jf2    = skpdat(ifacepf,5)
>          jskip2 = skpdat(ifacepf,6)
>       endif
> C
>       call faccl3 (w,qx(1,ie),unx(1,1,iface,ie),iface)
>       call faddcl3(w,qy(1,ie),uny(1,1,iface,ie),iface)
>       if (if3d)
>      $call faddcl3(w,qz(1,ie),unz(1,1,iface,ie),iface)
> c
>       dq = 0
>       i  = 0
>          i = i+1
>          dq    = dq   +area(i,1,iface,ie)*w(j1,j2,1)
>   100 continue
> C
>       return
>       end
>       subroutine gaujordf(a,m,n,indr,indc,ipiv,ierr,rmult)
> C
> C     Gauss-Jordan matrix inversion with full pivoting
> c
> c     Num. Rec. p. 30, 2nd Ed., Fortran
> c
> C
> C     a     is an m x n matrix
> C     rmult is a  work array of dimension m
> C
> c
>       real a(m,n),rmult(m)
>       integer indr(m),indc(n),ipiv(n)
> c     call outmat(a,m,n,'ab4',n)
> c     do i=1,m
> c        write(6,1) (a(i,j),j=1,n)
> c     enddo
> c 1   format('mat: ',1p6e12.4)
>       ierr = 0
>       eps = 1.e-9
>       call izero(ipiv,m)
>       do k=1,m
>          amx=0.
>          do i=1,m                    ! Pivot search
>             if (ipiv(i).ne.1) then
>                do j=1,m
>                   if (ipiv(j).eq.0) then
>                     if (abs(a(i,j)).ge.amx) then
>                        amx = abs(a(i,j))
>                        ir  = i
>                        jc  = j
>                     endif
>                  elseif (ipiv(j).gt.1) then
>                     ierr = -ipiv(j)
>                     return
>                  endif
>               enddo
>            endif
>         enddo
>         ipiv(jc) = ipiv(jc) + 1
> c
> c       Swap rows
>         if (ir.ne.jc) then
>            do j=1,n
>               tmp     = a(ir,j)
>               a(ir,j) = a(jc,j)
>               a(jc,j) = tmp
>            enddo
>         endif
>         indr(k)=ir
>         indc(k)=jc
> c       write(6 ,*) k,' Piv:',jc,a(jc,jc)
> c       write(28,*) k,' Piv:',jc,a(jc,jc)
>         if (abs(a(jc,jc)).lt.eps) then
>            write(6 ,*) 'small Gauss Jordan Piv:',jc,a(jc,jc)
>            write(28,*) 'small Gauss Jordan Piv:',jc,a(jc,jc)
>            ierr = jc
>            call exitt
>            return
>         endif
>         piv = 1./a(jc,jc)
>         a(jc,jc)=1.
>         do j=1,n
>            a(jc,j) = a(jc,j)*piv
>         enddo
> c
>         do j=1,n
>            work    = a(jc,j)
>            a(jc,j) = a(1 ,j)
>            a(1 ,j) = work
>         enddo
>         do i=2,m
>            rmult(i) = a(i,jc)
>            a(i,jc)  = 0.
>         enddo
> c
>         do j=1,n
>         do i=2,m
>            a(i,j) = a(i,j) - rmult(i)*a(1,j)
>         enddo
>         enddo
> c
>         do j=1,n
>            work    = a(jc,j)
>            a(jc,j) = a(1 ,j)
>            a(1 ,j) = work
>         enddo
> c
> c       do i=1,m
> c          if (i.ne.jc) then
> c             rmult   = a(i,jc)
> c             a(i,jc) = 0.
> c             do j=1,n
> c                a(i,j) = a(i,j) - rmult*a(jc,j)
> c             enddo
> c          endif
> c       enddo
> c
>       enddo
> c
> c     Unscramble matrix
>       do j=m,1,-1
>          if (indr(j).ne.indc(j)) then
>             do i=1,m
>                tmp=a(i,indr(j))
>                a(i,indr(j))=a(i,indc(j))
>                a(i,indc(j))=tmp
>             enddo
>          endif
>       enddo
> c
>       return
>       end
>       subroutine legendre_poly(L,x,N)
> c
> c     Evaluate Legendre polynomials of degrees 0-N at point x
> c
>       real L(0:N)
> c
>       L(0) = 1.
>       L(1) = x
> c
>       do j=2,N
>          L(j) = ( (2*j-1) * x * L(j-1) - (j-1) * L(j-2) ) / j
>       enddo
> c
>       return
>       end
>       subroutine build_new_filter(intv,zpts,nx,kut,wght,nid)
> c
> c     This routing builds a 1D filter with a transfer function that
> c     looks like:
> c
> c
> c        ^
> c    d_k |
> c        |                 |
> c     1  |__________      _v_
> c        |          -_ c        |            \  wght
> c        |             \  ___
> c        |             |   ^
> c     0  |-------------|---|>
> c
> c        0         c   N   k-->
> c
> c        Where c := N-kut is the point below which d_k = 1.
> c
> c
> c
> c      Here, nx = number of points
> c
>       real intv(nx,nx),zpts(nx)
> c
>       parameter (lm=40)
>       parameter (lm2=lm*lm)
>       real      phi(lm2),pht(lm2),diag(lm2),rmult(lm),Lj(lm)
>       integer   indr(lm),indc(lm),ipiv(lm)
> c
>       if (nx.gt.lm) then
>          write(6,*) 'ABORT in build_new_filter:',nx,lm
>          call exitt
>       endif
> c
>       kj = 0
>       n  = nx-1
>       do j=1,nx
>          z = zpts(j)
>          call legendre_poly(Lj,z,n)
>          kj = kj+1
>          pht(kj) = Lj(1)
>          kj = kj+1
>          pht(kj) = Lj(2)
>          do k=3,nx
>             kj = kj+1
>             pht(kj) = Lj(k)-Lj(k-2)
>          enddo
>       enddo
>       call transpose (phi,nx,pht,nx)
>       call copy      (pht,phi,nx*nx)
>       call gaujordf  (pht,nx,nx,indr,indc,ipiv,ierr,rmult)
> c
> c     Set up transfer function
> c
>       call ident   (diag,nx)
> c
>       k0 = nx-kut
>       do k=k0+1,nx
>          kk = k+nx*(k-1)
>          amp = wght*(k-k0)*(k-k0)/(kut*kut)   ! quadratic growth
>          diag(kk) = 1.-amp
>       enddo
> c
>       call mxm  (diag,nx,pht,nx,intv,nx)      !          -1
>       call mxm  (phi ,nx,intv,nx,pht,nx)      !     V D V
>       call copy (intv,pht,nx*nx)
> c
>       do k=1,nx*nx
>          pht(k) = 1.-diag(k)
>       enddo
>       np1 = nx+1
>       if (nid.eq.0) then
>          write(6,6) 'filt amp',(pht (k),k=1,nx*nx,np1)
>          write(6,6) 'filt trn',(diag(k),k=1,nx*nx,np1)
>    6     format(a8,16f7.4,6(/,8x,16f7.4))
>       endif
> c
>       return
>       end
>       subroutine avg_all
> c
> c     This routine computes running averages E(X),E(X^2),E(X*Y)
> c     and outputs to avg*.fld*, rms*.fld*, and rm2*.fld* for all
> c     fields.
> c
> c     E denotes the expected value operator and X,Y two
> c     real valued random variables.
> c
> c     variances and covariances can be computed in a post-processing
> step:
> c
> c        var(X)   := E(X^X) - E(X)*E(X) c        cov(X,Y) := E(X*Y) -
> E(X)*E(Y) c
> c     Note: The E-operator is linear, in the sense that the expected
> c           value is given by E(X) = 1/N * sum[ E(X)_i ], where E(X)_i
> c           is the expected value of the sub-ensemble i (i=1...N).
> c
>       include 'SIZE'
>       include 'TOTAL'
>       include 'AVG'
>       logical ifverbose
>       integer icalld
>       save    icalld
>       data    icalld  /0/
>       if (ax1.ne.lx1 .or. ay1.ne.ly1 .or. az1.ne.lz1) then
>          if(nid.eq.0) write(6,*)
>      $     'ABORT: wrong size of ax1,ay1,az1 in avg_all(), check SIZE!'
>          call exitt
>       endif
>       if (ax2.ne.lx2 .or. ay2.ne.ay2 .or. az2.ne.lz2) then
>      $     'ABORT: wrong size of ax2,ay2,az2 in avg_all(), check SIZE!'
>          call exitt
>       endif
>       ntott = nx1*ny1*nz1*nelt
>       nto2  = nx2*ny2*nz2*nelv
>       ! initialization
>          icalld = icalld + 1
>          atime  = 0.
>          timel  = time
>          call rzero(uavg,ntot)
>          call rzero(vavg,ntot)
>          call rzero(wavg,ntot)
>          call rzero(pavg,nto2)
>          do i = 1,ldimt
>             call rzero(tavg(1,1,1,1,i),ntott)
>          enddo
>          call rzero(urms,ntot)
>          call rzero(vrms,ntot)
>          call rzero(wrms,ntot)
>          call rzero(prms,nto2)
>          do i = 1,ldimt
>             call rzero(trms(1,1,1,1,i),ntott)
>          enddo
>          call rzero(vwms,ntot)
>          call rzero(wums,ntot)
>          call rzero(uvms,ntot)
>       endif
>       dtime = time  - timel
>       atime = atime + dtime
>       ! dump freq
>       iastep = param(68)
>       if  (iastep.eq.0) iastep=param(15)   ! same as iostep
>       if  (iastep.eq.0) iastep=500
>       ifverbose=.false.
>       if (istep.le.10) ifverbose=.true.
>       if  (mod(istep,iastep).eq.0) ifverbose=.true.
>       if (atime.ne.0..and.dtime.ne.0.) then
>          if(nid.eq.0) write(6,*) 'Compute statistics ...'
>          beta  = dtime/atime
>          alpha = 1.-beta
>          ! compute averages E(X)
>          call avg1    (uavg,vx,alpha,beta,ntot ,'um  ',ifverbose)
>          call avg1    (vavg,vy,alpha,beta,ntot ,'vm  ',ifverbose)
>          call avg1    (wavg,vz,alpha,beta,ntot ,'wm  ',ifverbose)
>          call avg1    (pavg,pr,alpha,beta,nto2 ,'prm ',ifverbose)
>          call avg1    (tavg,t ,alpha,beta,ntott,'tm  ',ifverbose)
>          do i = 2,ldimt
>             call avg1 (tavg(1,1,1,1,i),t(1,1,1,1,i),alpha,beta,
>      &                 ntott,'psav',ifverbose)
>          enddo
>          ! compute averages E(X^2)
>          call avg2    (urms,vx,alpha,beta,ntot ,'ums ',ifverbose)
>          call avg2    (vrms,vy,alpha,beta,ntot ,'vms ',ifverbose)
>          call avg2    (wrms,vz,alpha,beta,ntot ,'wms ',ifverbose)
>          call avg2    (prms,pr,alpha,beta,nto2 ,'prms',ifverbose)
>          call avg2    (trms,t ,alpha,beta,ntott,'tms ',ifverbose)
>          do i = 2,ldimt
>             call avg2 (trms(1,1,1,1,i),t(1,1,1,1,i),alpha,beta,
>      &                 ntott,'psms',ifverbose)
>          enddo
>          ! compute averages E(X*Y) (for now just for the velocities)
>          call avg3    (uvms,vx,vy,alpha,beta,ntot,'uvm ',ifverbose)
>          call avg3    (vwms,vy,vz,alpha,beta,ntot,'vwm ',ifverbose)
>          call avg3    (wums,vz,vx,alpha,beta,ntot,'wum ',ifverbose)
>       endif
> c
>       if ( (mod(istep,iastep).eq.0.and.istep.gt.1) .or.lastep.eq.1)
> then
>          time_temp = time
>          time      = atime   ! Output the duration of this avg
>          call outpost2(uavg,vavg,wavg,pavg,tavg,ldimt,'avg')
>          call outpost2(urms,vrms,wrms,prms,trms,ldimt,'rms')
>          call outpost (uvms,vwms,wums,prms,trms,      'rm2')
>          atime = 0.
>          time  = time_temp  ! Restore clock
>       endif
> c
>       timel = time
> c
>       return
>       end
>       subroutine avg1(avg,f,alpha,beta,n,name,ifverbose)
>       include 'SIZE'
>       include 'TSTEP'
> c
>       real avg(n),f(n)
>       character*4 name
>       logical ifverbose
> c
>       do k=1,n
>          avg(k) = alpha*avg(k) + beta*f(k)
>       enddo
> c
>       if (ifverbose) then
>          avgmax = glmax(avg,n)
>          avgmin = glmin(avg,n)
>          if (nid.eq.0) write(6,1) istep,time,avgmin,avgmax
>      $                           ,alpha,beta,name
>     1    format(i9,1p5e13.5,1x,a4,' av1mnx')
>       endif
> c
>       return
>       end
>       subroutine avg2(avg,f,alpha,beta,n,name,ifverbose)
>       include 'SIZE'
>       include 'TSTEP'
> c
>       real avg(n),f(n)
>       character*4 name
>       logical ifverbose
> c
>       do k=1,n
>          avg(k) = alpha*avg(k) + beta*f(k)*f(k)
>       enddo
> c
>       if (ifverbose) then
>      $                           ,alpha,beta,name
>     1    format(i9,1p5e13.5,1x,a4,' av2mnx')
>       endif
> c
>       return
>       end
>       subroutine avg3(avg,f,g,alpha,beta,n,name,ifverbose)
>       include 'SIZE'
>       include 'TSTEP'
> c
>       real avg(n),f(n),g(n)
>       character*4 name
>       logical ifverbose
> c
>       do k=1,n
>          avg(k) = alpha*avg(k) + beta*f(k)*g(k)
>       enddo
> c
>       if (ifverbose) then
>      $                           ,alpha,beta,name
>     1    format(i9,1p5e13.5,1x,a4,' av3mnx')
>       endif
> c
>       return
>       end
>       subroutine build_legend_transform(Lj,Ljt,zpts,nx)
> c
>       real Lj(nx*nx),Ljt(nx*nx),zpts(nx)
> c
>       parameter (lm=90)
> c
>       if (nx.gt.lm) then
>          write(6,*) 'ABORT in build_legend_transform:',nx,lm
>          call exitt
>       endif
> c
>       j = 1
>       n = nx-1
>       do i=1,nx
>          z = zpts(i)
>          call legendre_poly(Lj(j),z,n)  ! Return Lk(z), k=0,...,n
>          j = j+nx
>       enddo
>       call transpose1(Lj,nx)
> c     call outmat(Lj,nx,nx,'Lj ',n)
> c     call exitt
>       call gaujordf  (Lj,nx,nx,indr,indc,ipiv,ierr,rmult)
>       call transpose (Ljt,nx,Lj,nx)
> c
>       return
>       end
>       subroutine local_err_est(err,u,nx,Lj,Ljt,uh,w,if3d)
> c
> c     Local error estimates for u_e
> c
>       include 'SIZE'
>       real err(5,2),u(1),uh(nx,nx,nx),w(1),Lj(1),Ljt(1)
>       logical if3d
> c
>       call rzero(err,10)
> c
>       nxyz = nx**ndim
>       utot = vlsc2(u,u,nxyz)
>       if (utot.eq.0) return
> c
>       call tensr3(uh,nx,u,nx,Lj,Ljt,Ljt,w)    !  Go to Legendre space
> c
> c
> c     Get energy in low modes
> c
>       m = nx-2
> c
>       if (if3d) then
>          amp2_l = 0.
>          do k=1,m
>          do j=1,m
>          do i=1,m
>             amp2_l = amp2_l + uh(i,j,k)**2
>          enddo
>          enddo
>          enddo
> c
> c        Energy in each spatial direction
> c
>          amp2_t = 0
>          do k=m+1,nx
>          do j=1,m
>          do i=1,m
>             amp2_t = amp2_t + uh(i,j,k)**2
>          enddo
>          enddo
>          enddo
> c
>          amp2_s = 0
>          do k=1,m
>          do j=m+1,nx
>          do i=1,m
>             amp2_s = amp2_s + uh(i,j,k)**2
>          enddo
>          enddo
>          enddo
> c
>          amp2_r = 0
>          do k=1,m
>          do j=1,m
>          do i=m+1,nx
>             amp2_r = amp2_r + uh(i,j,k)**2
>          enddo
>          enddo
>          enddo
> c
>          amp2_h = 0
>          do k=m+1,nx
>          do j=m+1,nx
>          do i=m+1,nx
>             amp2_h = amp2_h + uh(i,j,k)**2
>          enddo
>          enddo
>          enddo
> c
>          etot = amp2_l + amp2_r + amp2_s + amp2_t + amp2_h
> c
>          relr = amp2_r / (amp2_r + amp2_l)
>          rels = amp2_s / (amp2_s + amp2_l)
>          relt = amp2_t / (amp2_t + amp2_l)
>          relh = (amp2_r + amp2_s + amp2_t + amp2_h) / etot
> c
>       else
>          k = 1
>          amp2_l = 0.
>          do j=1,m
>          do i=1,m
>          enddo
>          enddo
>          if (amp2_l.eq.0) return
> c
> c
>          amp2_t = 0
> c
>          amp2_s = 0
>          do j=m+1,nx
>          do i=1,m
>          enddo
>          enddo
> c
>          amp2_r = 0
>          do j=1,m
>          do i=m+1,nx
>          enddo
>          enddo
> c
>          amp2_h = 0
>          do j=m+1,nx
>          do i=m+1,nx
>          enddo
>          enddo
> c
>          etot = amp2_l + amp2_r + amp2_s + amp2_h
> c
>          relt = 0
>          relh = (amp2_r + amp2_s + amp2_h) / etot
> c
>       endif
> c
>       err (1,1) = sqrt(relr)
>       err (2,1) = sqrt(rels)
>       if (if3d) err (3,1) = sqrt(relt)
>       err (4,1) = sqrt(relh)
>       err (5,1) = sqrt(etot)
> c
>       err (1,2) = sqrt(amp2_r)
>       err (2,2) = sqrt(amp2_s)
>       if (if3d) err (3,2) = sqrt(amp2_t)
>       err (4,2) = sqrt(amp2_h)
>       err (5,2) = sqrt(utot)
> c
>       return
>       end
>       subroutine transpose1(a,n)
>       real a(n,n)
> c
>       do j=1,n
>       do i=j+1,n
>          ta     = a(i,j)
>          a(i,j) = a(j,i)
>          a(j,i) = ta
>       enddo
>       enddo
>       return
>       end
>       subroutine get_exyz(ex,ey,ez,eg,nelx,nely,nelz)
>       integer ex,ey,ez,eg
> c
>       nelxy = nelx*nely
> c
>       ez = 1 +  (eg-1)/nelxy
>       ey = mod1 (eg,nelxy)
>       ey = 1 +  (ey-1)/nelx
>       ex = mod1 (eg,nelx)
> c
>       return
>       end
>       subroutine dump_header2d(excode,nx,ny,nlx,nly,ierr)
>       include 'SIZE'
>       include 'TOTAL'
>       character*2 excode(15)
>       real*4         test_pattern
>       character*1 fhdfle1(132)
>       character*132 fhdfle
>       equivalence (fhdfle,fhdfle1)
>       jstep = istep
>       if (jstep.gt.10000) jstep = jstep / 10
>       nlxy = nlx*nly
>       nzz  = 1
> c     write(6,'(4i4,1PE14.7,i5,1x,15a2,1x,a12)')
> c    $  nlxy,nx,ny,nzz,TIME,jstep,(excode(i),i=1,15),
> c    $  'NELT,NX,NY,N'
> c
>       p66 = 0.
>       ierr= 0
>       IF (p66.EQ.1.0) THEN
> C       unformatted i/o
>         WRITE(24)
>       ELSEIF (p66.EQ.3.0) THEN
> C       formatted i/o to header file
>         WRITE(27,'(4I4,1pe14.7,I5,1X,15A2,1X,A12)')
>      $  'NELT,NX,NY,N'
>       ELSEIF (p66.eq.4.0) THEN
>         WRITE(fhdfle,'(4I4,1pe14.7,I5,1X,15A2,1X,A12)')
>      $  ' 4 NELT,NX,NY,N'
>         call byte_write(fhdfle,20,ierr)
>       ELSEIF (p66.eq.5.0) THEN
>      $  ' 8 NELT,NX,NY,N'
>       ELSE
> C       formatted i/o
>         WRITE(24,'(4I4,1pe14.7,I5,1X,15A2,1X,A12)')
>      $  'NELT,NX,NY,N'
>       ENDIF
> C     cdrror is a dummy cerror value for now.
>       CDRROR=0.0
> C       unformatted i/o
>         WRITE(24)(CDRROR,I=1,nlxy)
>       ELSEIF (p66.eq.3. .or. p66.eq.4.0) then
> C       write byte-ordering test pattern to byte file...
>         test_pattern = 6.54321
>         call byte_write(test_pattern,1,ierr)
>       ELSEIF (p66.eq.5.) then
>         test_pattern8 = 6.54321
>         call byte_write(test_pattern8,2,ierr)
>       ELSE
> C       formatted i/o
>         WRITE(24,'(6G11.4)')(CDRROR,I=1,nlxy)
>       ENDIF
>       return
>       end
>       subroutine outfld2d_p(u,v,w,nx,ny,nlx,nly,name,ifld,jid,npido,ir)
>       include 'SIZE'
>       include 'TOTAL'
>       integer icalld
>       save    icalld
>       data    icalld /0/
>       real u(nx*ny*nlx*nly)
>       real v(nx*ny*nlx*nly)
>       real w(nx*ny*nlx*nly)
>       character*4 name
>       character*12 fm
>       character*20 outfile
>       character*1 slash,dot
>       save        slash,dot
>       data        slash,dot  / '/' , '.' /
>       icalld = icalld+1
>       call blank(excode,30)
>       excode(4) = 'U '
>       excode(5) = '  '
>       excode(6) = 'T '
>       nthings   =  3
>       ir = 0 !error code for dump_header2d
>       call blank(outfile,20)
>       if (npido.lt.100) then
>          if (ifld.lt.100) then
>             write(outfile,22) jid,slash,name,ifld
>    22       format('B',i2.2,a1,a4,'.fld',i2.2)
>          elseif (ifld.lt.1000) then
>             write(outfile,23) jid,slash,name,ifld
>    23       format('B',i2.2,a1,a4,'.fld',i3)
>          elseif (ifld.lt.10000) then
>             write(outfile,24) jid,slash,name,ifld
>    24       format('B',i2.2,a1,a4,'.fld',i4)
>          elseif (ifld.lt.100000) then
>             write(outfile,25) jid,slash,name,ifld
>    25       format('B',i2.2,a1,a4,'.fld',i5)
>          elseif (ifld.lt.1000000) then
>             write(outfile,26) jid,slash,name,ifld
>    26       format('B',i2.2,a1,a4,'.fld',i6)
>          endif
>       else
>             write(outfile,32) jid,slash,name,ifld
>    32       format('B',i3.3,a1,a4,'.fld',i2.2)
>             write(outfile,33) jid,slash,name,ifld
>    33       format('B',i3.3,a1,a4,'.fld',i3)
>             write(outfile,34) jid,slash,name,ifld
>    34       format('B',i3.3,a1,a4,'.fld',i4)
>             write(outfile,35) jid,slash,name,ifld
>    35       format('B',i3.3,a1,a4,'.fld',i5)
>             write(outfile,36) jid,slash,name,ifld
>    36       format('B',i3.3,a1,a4,'.fld',i6)
>          endif
>       endif
>       if (icalld.le.4) write(6,*) nid,outfile,' OPEN',nlx,nly
>       open(unit=24,file=outfile,status='unknown')
>       call dump_header2d(excode,nx,ny,nlx,nly,ir)
>       n = nx*ny*nlx*nly
>       write(fm,10) nthings
>       write(24,fm) (u(i),v(i),w(i),i=1,n)
>    10 format('(1p',i1,'e14.6)')
>       close(24)
>       return
>       end
>       subroutine outfld2d(u,v,w,nx,ny,nlx,nly,name,ifld)
>       include 'SIZE'
>       include 'TOTAL'
>       character*3 name
>       character*12 fm
> c     if (istep.le.10) write(6,*) nid,' in out2d:',iz
> c
> c     excode(1) = 'X '
> c     excode(2) = 'Y '
> c     excode(3) = 'U '
> c     excode(4) = 'V '
> c     excode(5) = 'P '
> c     excode(6) = 'T '
> c
>       excode(4) = 'U '
>       excode(5) = '  '
>       excode(6) = 'T '
>       nthings   =  3
>       ierr = 0
>       if (nid.eq.0) then
>             write(outfile,2) name,ifld
>     2       format(a3,'2d.fld',i2.2)
>             write(outfile,3) name,ifld
>     3       format(a3,'2d.fld',i3)
>             write(outfile,4) name,ifld
>     4       format(a3,'2d.fld',i4)
>             write(outfile,5) name,ifld
>     5       format(a3,'2d.fld',i5)
>             write(outfile,6) name,ifld
>     6       format(a3,'2d.fld',i6)
>          endif
>          call dump_header2d(excode,nx,ny,nlx,nly,ierr)
>          n = nx*ny*nlx*nly
> c        write(6,*) fm
> c        call exitt
> c  10    format('''(1p',i1,'e15.7)''')
> c  10    format(1p7e15.7)
> c
>          close(24)
>       endif
>       call err_chk(ierr,'Error using byte_write,outfld2d. Abort.$')
>       return
>       end
>       subroutine planar_average_z(ua,u,w1,w2)
> c
> c     Compute r-s planar average of quantity u()
> c
>       include 'SIZE'
>       include 'GEOM'
>       include 'PARALLEL'
>       include 'WZ'
>       include 'ZPER'
> c
>       real ua(nz1,nelz),u(nx1*ny1,nz1,nelv),w1(nz1,nelz),w2(nz1,nelz)
>       integer e,eg,ez
> c
>       melxy = nelx*nely
> c
>       nz = nz1*nelz
>       call rzero(ua,nz)
>       call rzero(w1,nz)
> c
>       do e=1,nelt
> c
>          eg = lglel(e)
>          ez = 1 + (eg-1)/melxy
> c
>          do k=1,nz1
>          do i=1,nx1*ny1
>             zz = (1.-zgm1(k,3))/2.  ! = 1 for k=1, = 0 for k=nz1
>             aa = zz*area(i,1,5,e) + (1-zz)*area(i,1,6,e)  ! wgtd
> jacobian
>             w1(k,ez) = w1(k,ez) + aa
>             ua(k,ez) = ua(k,ez) + aa*u(i,k,e)
>          enddo
>          enddo
>       enddo
> c
>       call gop(ua,w2,'+  ',nz)
>       call gop(w1,w2,'+  ',nz)
> c
>       do i=1,nz
>          ua(i,1) = ua(i,1) / w1(i,1)   ! Normalize
>       enddo
> c
>       return
>       end
>       subroutine drgtrq(dgtq,xm0,ym0,zm0,sij,pm1,visc,f,e)
> c
>       INCLUDE 'SIZE'
>       INCLUDE 'GEOM'
>       INCLUDE 'INPUT'
>       INCLUDE 'TOPOL'
>       INCLUDE 'TSTEP'
> c
>       real dgtq(3,4)
>       real xm0 (lx1,ly1,lz1,lelt)
>       real ym0 (lx1,ly1,lz1,lelt)
>       real zm0 (lx1,ly1,lz1,lelt)
>       real sij (lx1,ly1,lz1,3*ldim-3,lelv)
>       real pm1 (lx1,ly1,lz1,lelv)
>       real visc(lx1,ly1,lz1,lelv)
> c
>       real dg(3,2)
> c
>       integer f,e,pf
>       real    n1,n2,n3
> c
>       call dsset(nx1,ny1,nz1)    ! set up counters
>       pf     = eface1(f)         ! convert from preproc. notation
>       js1    = skpdat(1,pf)
>       jf1    = skpdat(2,pf)
>       jskip1 = skpdat(3,pf)
>       js2    = skpdat(4,pf)
>       jf2    = skpdat(5,pf)
>       jskip2 = skpdat(6,pf)
> C
>       call rzero(dgtq,12)
> c
>       if (if3d.or.ifaxis) then
>        i = 0
>        a = 0
>          i = i+1
>          n1 = unx(i,1,f,e)*area(i,1,f,e)
>          n2 = uny(i,1,f,e)*area(i,1,f,e)
>          n3 = unz(i,1,f,e)*area(i,1,f,e)
>          a  = a +          area(i,1,f,e)
> c
>          v  = visc(j1,j2,1,e)
> c
>          s11 = sij(j1,j2,1,1,e)
>          s21 = sij(j1,j2,1,4,e)
>          s31 = sij(j1,j2,1,6,e)
> c
>          s12 = sij(j1,j2,1,4,e)
>          s22 = sij(j1,j2,1,2,e)
>          s32 = sij(j1,j2,1,5,e)
> c
>          s13 = sij(j1,j2,1,6,e)
>          s23 = sij(j1,j2,1,5,e)
>          s33 = sij(j1,j2,1,3,e)
> c
>          dg(1,1) = pm1(j1,j2,1,e)*n1     ! pressure drag
>          dg(2,1) = pm1(j1,j2,1,e)*n2
>          dg(3,1) = pm1(j1,j2,1,e)*n3
> c
>          dg(1,2) = -v*(s11*n1 + s12*n2 + s13*n3) ! viscous drag
>          dg(2,2) = -v*(s21*n1 + s22*n2 + s23*n3)
>          dg(3,2) = -v*(s31*n1 + s32*n2 + s33*n3)
> c
>          r1 = xm0(j1,j2,1,e)
>          r2 = ym0(j1,j2,1,e)
>          r3 = zm0(j1,j2,1,e)
> c
>          do l=1,2
>          do k=1,3
>             dgtq(k,l) = dgtq(k,l) + dg(k,l)
>          enddo
>          enddo
> c
>          dgtq(1,3) = dgtq(1,3) + (r2*dg(3,1)-r3*dg(2,1)) ! pressure
>          dgtq(2,3) = dgtq(2,3) + (r3*dg(1,1)-r1*dg(3,1)) ! torque
>          dgtq(3,3) = dgtq(3,3) + (r1*dg(2,1)-r2*dg(1,1))
> c
>          dgtq(1,4) = dgtq(1,4) + (r2*dg(3,2)-r3*dg(2,2)) ! viscous
>          dgtq(2,4) = dgtq(2,4) + (r3*dg(1,2)-r1*dg(3,2)) ! torque
>          dgtq(3,4) = dgtq(3,4) + (r1*dg(2,2)-r2*dg(1,2))
>        enddo
>        enddo
>       else ! 2D
>        i = 0
>        a = 0
>          i = i+1
>          v  = visc(j1,j2,1,e)
>          s12 = sij(j1,j2,1,3,e)
>          s21 = sij(j1,j2,1,3,e)
>          dg(3,1) = 0
>          dg(1,2) = -v*(s11*n1 + s12*n2) ! viscous drag
>          dg(2,2) = -v*(s21*n1 + s22*n2)
>          dg(3,2) = 0.
>          r1 = xm0(j1,j2,1,e)
>          r2 = ym0(j1,j2,1,e)
>          r3 = 0.
>          do l=1,2
>          do k=1,3
>          enddo
>          enddo
>          dgtq(1,3) = 0! dgtq(1,3) + (r2*dg(3,1)-r3*dg(2,1)) ! pressure
>          dgtq(2,3) = 0! dgtq(2,3) + (r3*dg(1,1)-r1*dg(3,1)) ! torque
>          dgtq(1,4) = 0! dgtq(1,4) + (r2*dg(3,2)-r3*dg(2,2)) ! viscous
>          dgtq(2,4) = 0! dgtq(2,4) + (r3*dg(1,2)-r1*dg(3,2)) ! torque
>        enddo
>        enddo
>       endif
>       return
>       end
>       subroutine torque_calc(scale,x0,ifdout,iftout)
> c
> c     Compute torque about point x0
> c
> c     Scale is a user-supplied multiplier so that results may be
> c     scaled to any convenient non-dimensionalization.
> c
> c
>       INCLUDE 'SIZE'
>       INCLUDE 'TOTAL'
>      $                , scale_vf(3)
> c
>       real x0(3),w1(0:maxobj)
>       logical ifdout,iftout
> c
>       common /scrns/         sij (lx1*ly1*lz1*6*lelv)
>       common /scrcg/         pm1 (lx1,ly1,lz1,lelv)
>       common /scrsf/         xm0(lx1,ly1,lz1,lelt)
>      $,                      ym0(lx1,ly1,lz1,lelt)
>      $,                      zm0(lx1,ly1,lz1,lelt)
> c
>       parameter (lr=lx1*ly1*lz1)
>       common /scruz/         ur(lr),us(lr),ut(lr)
>      $                     , vr(lr),vs(lr),vt(lr)
>      $                     , wr(lr),ws(lr),wt(lr)
> c
>       common /ctorq/ dragx(0:maxobj),dragpx(0:maxobj),dragvx(0:maxobj)
>      $             , dragy(0:maxobj),dragpy(0:maxobj),dragvy(0:maxobj)
>      $             , dragz(0:maxobj),dragpz(0:maxobj),dragvz(0:maxobj)
> c
>      $             , torqx(0:maxobj),torqpx(0:maxobj),torqvx(0:maxobj)
>      $             , torqy(0:maxobj),torqpy(0:maxobj),torqvy(0:maxobj)
>      $             , torqz(0:maxobj),torqpz(0:maxobj),torqvz(0:maxobj)
> c
>      $             , dgtq(3,4)
> c
> c
>       n = nx1*ny1*nz1*nelv
> c
>       call mappr(pm1,pr,xm0,ym0) ! map pressure onto Mesh 1
> c
>       endif
>       call add2s2(pm1,xm1,dpdx_mean,n)  ! Doesn't work if object is cut
> by
>       call add2s2(pm1,ym1,dpdy_mean,n)  ! periodicboundary.  In this
> case,
>       call add2s2(pm1,zm1,dpdz_mean,n)  ! set ._mean=0 and compensate
> in
> c
> c    Compute sij
> c
>       nij = 3
>       if (if3d.or.ifaxis) nij=6
>       call comp_sij(sij,nij,vx,vy,vz,ur,us,ut,vr,vs,vt,wr,ws,wt)
> c
> c
> c
>       if (istep.lt.1) call cfill(vdiff,param(2),n)
> c
>       call cadd2(xm0,xm1,-x0(1),n)
>       call cadd2(ym0,ym1,-x0(2),n)
>       call cadd2(zm0,zm1,-x0(3),n)
> c
>       x1min=glmin(xm0(1,1,1,1),n)
>       x2min=glmin(ym0(1,1,1,1),n)
>       x3min=glmin(zm0(1,1,1,1),n)
> c
>       x1max=glmax(xm0(1,1,1,1),n)
>       x2max=glmax(ym0(1,1,1,1),n)
>       x3max=glmax(zm0(1,1,1,1),n)
> c
>       do i=0,maxobj
>          dragpx(i) = 0   ! BIG CODE  :}
>          dragvx(i) = 0
>          dragx (i) = 0
>          dragpy(i) = 0
>          dragvy(i) = 0
>          dragy (i) = 0
>          dragpz(i) = 0
>          dragvz(i) = 0
>          dragz (i) = 0
>          torqpx(i) = 0
>          torqvx(i) = 0
>          torqx (i) = 0
>          torqpy(i) = 0
>          torqvy(i) = 0
>          torqy (i) = 0
>          torqpz(i) = 0
>          torqvz(i) = 0
>          torqz (i) = 0
>       enddo
> c
> c
>       nobj = 0
>       do ii=1,nhis
>         if (hcode(10,ii).EQ.'I') then
>           iobj   = lochis(1,ii)
>           memtot = nmember(iobj)
>           nobj   = max(iobj,nobj)
> c
>           if (hcode(1,ii).ne.' ' .or. hcode(2,ii).ne.' ' .or.
>      $      hcode(3,ii).ne.' ' ) then
>             ifield = 1
> c
> c
>             do mem=1,memtot
>                ieg   = object(iobj,mem,1)
>                ifc   = object(iobj,mem,2)
>                if (gllnid(ieg).eq.nid) then ! this processor has a
> contribution
>                   ie = gllel(ieg)
>                   call drgtrq(dgtq,xm0,ym0,zm0,sij,pm1,vdiff,ifc,ie)
> c
>                   call cmult(dgtq,scale,12)
> c
>                   dragpx(iobj) = dragpx(iobj) + dgtq(1,1)  ! pressure
>                   dragpy(iobj) = dragpy(iobj) + dgtq(2,1)
>                   dragpz(iobj) = dragpz(iobj) + dgtq(3,1)
> c
>                   dragvx(iobj) = dragvx(iobj) + dgtq(1,2)  ! viscous
>                   dragvy(iobj) = dragvy(iobj) + dgtq(2,2)
>                   dragvz(iobj) = dragvz(iobj) + dgtq(3,2)
> c
>                   torqpx(iobj) = torqpx(iobj) + dgtq(1,3)  ! pressure
>                   torqpy(iobj) = torqpy(iobj) + dgtq(2,3)
>                   torqpz(iobj) = torqpz(iobj) + dgtq(3,3)
> c
>                   torqvx(iobj) = torqvx(iobj) + dgtq(1,4)  ! viscous
>                   torqvy(iobj) = torqvy(iobj) + dgtq(2,4)
>                   torqvz(iobj) = torqvz(iobj) + dgtq(3,4)
> c
>                endif
>             enddo
>           endif
>         endif
>       enddo
> c
> c
>       call gop(dragpx,w1,'+  ',maxobj+1)
>       call gop(dragpy,w1,'+  ',maxobj+1)
>       call gop(dragpz,w1,'+  ',maxobj+1)
>       call gop(dragvx,w1,'+  ',maxobj+1)
>       call gop(dragvy,w1,'+  ',maxobj+1)
>       call gop(dragvz,w1,'+  ',maxobj+1)
> c
>       call gop(torqpx,w1,'+  ',maxobj+1)
>       call gop(torqpy,w1,'+  ',maxobj+1)
>       call gop(torqpz,w1,'+  ',maxobj+1)
>       call gop(torqvx,w1,'+  ',maxobj+1)
>       call gop(torqvy,w1,'+  ',maxobj+1)
>       call gop(torqvz,w1,'+  ',maxobj+1)
> c
>       nobj = iglmax(nobj,1)
> c
>       do i=1,nobj
>          dragx(i) = dragpx(i) + dragvx(i)
>          dragy(i) = dragpy(i) + dragvy(i)
>          dragz(i) = dragpz(i) + dragvz(i)
> c
>          torqx(i) = torqpx(i) + torqvx(i)
>          torqy(i) = torqpy(i) + torqvy(i)
>          torqz(i) = torqpz(i) + torqvz(i)
> c
>          dragpx(0) = dragpx (0) + dragpx (i)
>          dragvx(0) = dragvx (0) + dragvx (i)
>          dragx (0) = dragx  (0) + dragx  (i)
> c
>          dragpy(0) = dragpy (0) + dragpy (i)
>          dragvy(0) = dragvy (0) + dragvy (i)
>          dragy (0) = dragy  (0) + dragy  (i)
> c
>          dragpz(0) = dragpz (0) + dragpz (i)
>          dragvz(0) = dragvz (0) + dragvz (i)
>          dragz (0) = dragz  (0) + dragz  (i)
> c
>          torqpx(0) = torqpx (0) + torqpx (i)
>          torqvx(0) = torqvx (0) + torqvx (i)
>          torqx (0) = torqx  (0) + torqx  (i)
> c
>          torqpy(0) = torqpy (0) + torqpy (i)
>          torqvy(0) = torqvy (0) + torqvy (i)
>          torqy (0) = torqy  (0) + torqy  (i)
> c
>          torqpz(0) = torqpz (0) + torqpz (i)
>          torqvz(0) = torqvz (0) + torqvz (i)
>          torqz (0) = torqz  (0) + torqz  (i)
> c
>       enddo
> c
>       i0 = 0
>       if (nobj.le.1) i0 = 1  ! one output for single-object case
> c
>       do i=i0,nobj
>         if (nid.eq.0) then
>            if (ifdout) then
>             write(6,6)
> istep,time,dragx(i),dragpx(i),dragvx(i),i,'dragx'
>             write(6,6)
> istep,time,dragy(i),dragpy(i),dragvy(i),i,'dragy'
>             write(6,6)
> istep,time,dragz(i),dragpz(i),dragvz(i),i,'dragz'
>            endif
>            if (iftout) then
>             write(6,6)
> istep,time,torqx(i),torqpx(i),torqvx(i),i,'torqx'
>             write(6,6)
> istep,time,torqy(i),torqpy(i),torqvy(i),i,'torqy'
>             write(6,6)
> istep,time,torqz(i),torqpz(i),torqvz(i),i,'torqz'
>            endif
>           else
>            if (ifdout) then
>             write(6,6)
>             write(6,6)
>            endif
>            if (iftout) then
>             write(6,6)
>            endif
>           endif
>         endif
>     6   format(i8,1p4e19.11,2x,i5,a5)
>       enddo
> c
>       return
>       end
>       subroutine comp_sij(sij,nij,u,v,w,ur,us,ut,vr,vs,vt,wr,ws,wt)
> c                                       du_i       du_j
> c     Compute the stress tensor S_ij := ----   +   ----
> c                                       du_j       du_i
> c
>       include 'SIZE'
>       include 'TOTAL'
> c
>       integer e
> c
>       real sij(lx1*ly1*lz1,nij,lelv)
>       real u  (lx1*ly1*lz1,lelv)
>       real v  (lx1*ly1*lz1,lelv)
>       real w  (lx1*ly1*lz1,lelv)
>       real ur (1) , us (1) , ut (1)
>      $   , vr (1) , vs (1) , vt (1)
>      $   , wr (1) , ws (1) , wt (1)
>       real j ! Inverse Jacobian
>       n    = nx1-1      ! Polynomial degree
>       nxyz = nx1*ny1*nz1
>       if (if3d) then     ! 3D CASE
>        do e=1,nelv
>         call local_grad3(vr,vs,vt,v,N,e,dxm1,dxtm1)
>         call local_grad3(wr,ws,wt,w,N,e,dxm1,dxtm1)
>         do i=1,nxyz
>          j = jacmi(i,e)
>          sij(i,1,e) = j*  ! du/dx + du/dx
> 2*(ur(i)*rxm1(i,1,1,e)+us(i)*sxm1(i,1,1,e)+ut(i)*txm1(i,1,1,e))
>          sij(i,2,e) = j*  ! dv/dy + dv/dy
> 2*(vr(i)*rym1(i,1,1,e)+vs(i)*sym1(i,1,1,e)+vt(i)*tym1(i,1,1,e))
>          sij(i,3,e) = j*  ! dw/dz + dw/dz
> 2*(wr(i)*rzm1(i,1,1,e)+ws(i)*szm1(i,1,1,e)+wt(i)*tzm1(i,1,1,e))
>          sij(i,4,e) = j*  ! du/dy + dv/dx
>      $   (ur(i)*rym1(i,1,1,e)+us(i)*sym1(i,1,1,e)+ut(i)*tym1(i,1,1,e) +
>      $    vr(i)*rxm1(i,1,1,e)+vs(i)*sxm1(i,1,1,e)+vt(i)*txm1(i,1,1,e) )
>          sij(i,5,e) = j*  ! dv/dz + dw/dy
>      $   (wr(i)*rym1(i,1,1,e)+ws(i)*sym1(i,1,1,e)+wt(i)*tym1(i,1,1,e) +
>      $    vr(i)*rzm1(i,1,1,e)+vs(i)*szm1(i,1,1,e)+vt(i)*tzm1(i,1,1,e) )
>          sij(i,6,e) = j*  ! du/dz + dw/dx
>      $   (ur(i)*rzm1(i,1,1,e)+us(i)*szm1(i,1,1,e)+ut(i)*tzm1(i,1,1,e) +
>      $    wr(i)*rxm1(i,1,1,e)+ws(i)*sxm1(i,1,1,e)+wt(i)*txm1(i,1,1,e) )
>         enddo
>        enddo
>       elseif (ifaxis) then  ! AXISYMMETRIC CASE
> c
> c        Notation:                       ( 2  x  Acheson, p. 353)
> c                     Cylindrical
> c            Nek5k    Coordinates
> c
> c              x          z
> c              y          r
> c              z          theta
> c
>          do e=1,nelv
>             call setaxdy ( ifrzer(e) )  ! change dytm1 if on-axis
>             call local_grad2(vr,vs,v,N,e,dxm1,dytm1)
>             call local_grad2(wr,ws,w,N,e,dxm1,dytm1)
>             do i=1,nxyz
>                j = jacmi(i,e)
>                r = ym1(i,1,1,e)                              ! Cyl.
> Coord:
>                sij(i,1,e) = j*  ! du/dx + du/dx              ! e_zz
>      $           2*(ur(i)*rxm1(i,1,1,e)+us(i)*sxm1(i,1,1,e))
>                sij(i,2,e) = j*  ! dv/dy + dv/dy              ! e_rr
>      $           2*(vr(i)*rym1(i,1,1,e)+vs(i)*sym1(i,1,1,e))
>                if (r.gt.0) then                              ! e_@@
>                   sij(i,3,e) = v(i,e)/r  ! v / r
>                else
>                   sij(i,3,e) = j*  ! L'Hopital's rule: e_@@ = dv/dr
>                endif
>                sij(i,4,e) = j*  ! du/dy + dv/dx             ! e_zr
>      $            ( ur(i)*rym1(i,1,1,e)+us(i)*sym1(i,1,1,e) +
>      $              vr(i)*rxm1(i,1,1,e)+vs(i)*sxm1(i,1,1,e) )
>                if (yyyr.gt.0) then                             ! e_r@
>                   sij(i,5,e) = j*  ! dw/dy
>      $              ( wr(i)*rym1(i,1,1,e)+ws(i)*sym1(i,1,1,e) )
>      $              - w(i,e) / r
>                else
>                   sij(i,5,e) = 0
>                endif
>                sij(i,6,e) = j*  ! dw/dx                     ! e_ at z
>      $            ( wr(i)*rxm1(i,1,1,e)+ws(i)*sxm1(i,1,1,e) )
>             enddo
>          enddo
>       else              ! 2D CASE
>          do e=1,nelv
>             call local_grad2(ur,us,u,N,e,dxm1,dxtm1)
>             call local_grad2(vr,vs,v,N,e,dxm1,dxtm1)
>             do i=1,nxyz
>                j = jacmi(i,e)
>                sij(i,3,e) = j*  ! du/dy + dv/dx
>      $           (ur(i)*rym1(i,1,1,e)+us(i)*sym1(i,1,1,e) +
>             enddo
>          enddo
>       endif
>       return
>       end
>       subroutine y_slice (ua,u,w1,w2)
> c
> c     Extract a y slice of quantity u() - assumes global tens.prod.
> c
>       include 'SIZE'
>       include 'GEOM'
>       include 'PARALLEL'
>       include 'WZ'
>       include 'ZPER'
> c
>       real ua(nx1,nz1,nelx,nelz),u (nx1,ny1,nz1,nelv)
>      $    ,w1(nx1,nz1,nelx,nelz),w2(nx1,nz1,nelx,nelz)
>       integer e,eg,ex,ey,ez
>       real dy2
> c
>       mxz = nelx*nelz*nx1*nz1
>       call rzero(ua,mxz)
> c
>       do e=1,nelt
> c
>          eg = lglel(e)
>          call get_exyz(ex,ey,ez,eg,nelx,nely,nelz)
>          j = 1
>          if (ey.eq.1) then
>             do k=1,nz1
>             do i=1,nx1
>                ua(i,k,ex,ez) = u(i,j,k,e)
>             enddo
>             enddo
>          endif
>       enddo
>       call gop(ua,w2,'+  ',mxz)
>       return
>       end
>       subroutine z_slice_g (uz,u,w1,kz,ezi,nx,ny,nz,nlxy)
> c
> c     Extract a z slice of quantity u() c
> c     ASSUMES data is in a global tensor-product structure, nlxy x
> nelz,
> c             as would be produced by n2to3 or genbox.
> c
> c     Arguments:
> c
> c     uz(nx1,ny1,nlxy):       extracted z-slice data
> c     u (nx1,ny1,nz1,nelt):   input data
> c     w1(nx1,ny1,nlxy):       work array
> c     kz:                     z-plane within element ezi to be
> extracted
> c     ezi:                    elemental z-slab to be extracted
> c     nx,ny,nz:               dimensions for 3D spectral element input
> c     nlxy:                   global number of elements in x-y plane.
>       include 'SIZE'
>       include 'GEOM'
>       include 'PARALLEL'
>       include 'WZ'
>       real uz(nx,ny,nlxy),u (nx,ny,nz,nelv),w1(nx,ny,nlxy)
>       integer e,eg,ex,ey,ez,ezi
>       real dy2
>       nxy = nx*ny
>       mxy = nxy*nlxy
>       call rzero(uz,mxy) ! zero out the entire plane
>       do e=1,nelt
>          eg = lglel(e)
>          call get_exyz(ex,ey,ez,eg,nlxy,1,1)
>          if (ez.eq.ezi)
>      $      call copy(uz(1,1,ex),u(1,1,kz,e),nxy) ! u(zlice) --> uz()
>       enddo
>       call gop(uz,w1,'+  ',mxy) ! Collect partial contributions from
> all procs
>       return
>       end
>       subroutine z_slice (ua,u,w1,w2)
> c
> c     Extract a z slice of quantity u() - assumes global tens.prod.
> c
>       include 'SIZE'
>       include 'GEOM'
>       include 'PARALLEL'
>       include 'WZ'
>       include 'ZPER'
> c
>       real ua(nx1,ny1,nelx,nely),u (nx1,ny1,nz1,nelv)
>      $    ,w1(nx1,ny1,nelx,nely),w2(nx1,ny1,nelx,nely)
>       real dy2
> c
>       mxy = nelx*nely*nx1*ny1
>       call rzero(ua,mxy)
> c
>       do e=1,nelt
> c
>          eg = lglel(e)
>          k = 1
>          if (ez.eq.1) then
>             do j=1,ny1
>             do i=1,nx1
>                ua(i,j,ex,ey) = u(i,j,k,e)
>             enddo
>             enddo
>          endif
>       enddo
>       call gop(ua,w2,'+  ',mxy)
>       return
>       end
>       subroutine y_average(ua,u,w1,w2)
> c
> c     Compute the y average of quantity u() - assumes global tens.prod.
> c
>       include 'SIZE'
>       include 'GEOM'
>       include 'PARALLEL'
>       include 'WZ'
>       include 'ZPER'
> c
>       real dy2
> c
>       call rzero(ua,mxz)
>       call rzero(w1,mxz)
> c
>       do e=1,nelt
> c
>          eg = lglel(e)
> c
>          do k=1,nz1
>          do i=1,nx1
> c           dy2 = .5*( ym1(i,ny1,k,e) - ym1(i,1,k,e) )
>             dy2 = 1.0  !  Assuming uniform in "y" direction
>             do j=1,ny1
>                ua(i,k,ex,ez) = ua(i,k,ex,ez)+dy2*wym1(j)*u(i,j,k,e)
>                w1(i,k,ex,ez) = w1(i,k,ex,ez)+dy2*wym1(j) ! redundant
> but clear
>             enddo
>          enddo
>          enddo
>       enddo
> c
>       call gop(w1,w2,'+  ',mxz)
> c
>       do i=1,mxz
>          ua(i,1,1,1) = ua(i,1,1,1) / w1(i,1,1,1)   ! Normalize
>       enddo
> c
>       return
>       end
>       subroutine y_avg_buff(ux,uy,uz,c2,name,icount)
> c
> c
>       include 'SIZE'
>       include 'TOTAL'
>       include 'ZPER'
>       real ux(1),uy(1),uz(1)
>       character*2 c2,name
>       parameter (lyavg = lx1*lz1*lelx*lelz)
>       common /scravg/ u (lyavg)
>      $              , v (lyavg)
>      $              , w (lyavg)
>      $              , w1(lyavg)
>      $              , w2(lyavg)
>       call y_average(u,ux,w1,w2)
>       call y_average(v,uy,w1,w2)
>       call y_average(w,uz,w1,w2)
>       call buff_2d_out(u,v,w,nx1,nz1,nelx,nelz,c2,name,icount)
>       return
>       end
>       subroutine z_avg_buff(ux,uy,uz,c2,name,icount)
> c
> c     Compute the z average of quantity u() - assumes global tens.prod.
> c
>       include 'SIZE'
>       include 'TOTAL'
>       include 'ZPER'
> c
>       character*2 c2,name
> c
>       parameter (lyavg = lx1*ly1*lelx*lely)
>      $              , v (lyavg)
>      $              , w (lyavg)
>      $              , w1(lyavg)
>      $              , w2(lyavg)
> c
>       call z_average(u,ux,w1,w2)
>       call z_average(v,uy,w1,w2)
>       call z_average(w,uz,w1,w2)
>       call buff_2d_out(u,v,w,nx1,ny1,nelx,nely,c2,name,icount)
>       return
>       end
>       subroutine y_ins_buff(ux,uy,uz,c2,name,icount)
> c
> c
>       include 'SIZE'
>       include 'TOTAL'
>       include 'ZPER'
> c
>       character*2 c2,name
> c
>      $              , v (lyavg)
>      $              , w (lyavg)
>      $              , w1(lyavg)
>      $              , w2(lyavg)
> c
>       call y_slice  (u,ux,w1,w2)
>       call y_slice  (v,uy,w1,w2)
>       call y_slice  (w,uz,w1,w2)
> c
> c
>       return
>       end
>       subroutine z_ins_buff(ux,uy,uz,c2,name,icount)
> c
> c
>       include 'SIZE'
>       include 'TOTAL'
>       include 'ZPER'
> c
>       character*2 c2,name
> c
>      $              , v (lyavg)
>      $              , w (lyavg)
>      $              , w1(lyavg)
>      $              , w2(lyavg)
> c
>       call z_slice  (u,ux,w1,w2)
>       call z_slice  (v,uy,w1,w2)
>       call z_slice  (w,uz,w1,w2)
> c
> c
>       return
>       end
>       subroutine buff_2d_out(u,v,w,nx,ny,nex,ney,c2,name,ifld)
> c
>       include 'SIZE'
>       include 'TOTAL'
>       real u(1),v(1),w(1)
>       character*2 c2,name
>       character*4  bname
>       save         bname
>       parameter (lyzm = lelx*max(lely,lelz))
>       common /scrav2/
> ub(lx1,lz1,lyzm),vb(lx1,lz1,lyzm),wb(lx1,lz1,lyzm)
>       integer ibfld,icalld,nxf,nyf,nexf,neyf
>       save    ibfld,icalld,nxf,nyf,nexf,neyf
>       data    ibfld,icalld,nxf,nyf,nexf,neyf  / 6*0 /
> c     npido = 64             !  64 files buffered
>       npido = 128            !  64 files buffered
>       npido =  min(npido,np) !  P  files buffered
>       mpido = np/npido     ! stride between processors (e.g., 128/64 =
> 2)
>       jcalld = mod(icalld,npido)       ! call # 0,1,...,63,0,1,...
>       if (mod(nid,mpido) .eq. 0) then  ! this is a buffering/writing
> proc
>          jid = nid/mpido
>          if (jid.eq.jcalld) then       ! save this buffer on this proc
> c           write(6,1) nid,jid,istep,icalld,jcalld,c2,name,nex,ney,ifld
> c   1       format(5i7,' buffering: ',2a2,3i7)
>             write(bname,4) c2,name
>     4       format(2a2)
>             n = nx*ny*nex*ney
>             ibfld = ifld
>             call copy(ub,u,n)
>             call copy(vb,v,n)
>             call copy(wb,w,n)
>             nxf  = nx
>             nyf  = ny
>             nexf = nex
>             neyf = ney
>          endif
>          if (jcalld .eq. npido-1) call  ! output buffer
>      $  outfld2d_p(ub,vb,wb,nxf,nyf,nexf,neyf,bname,ibfld,jid,npido,ir)
>       endif
>       call err_chk(ir,'Error with byte_write, buff_2d_out $')
>       icalld = icalld+1
>       return
>       end
>       subroutine y2d(u,v,w,p,c1,icount)
> c
> c
>       include 'SIZE'
>       include 'TOTAL'
>       real u(1),v(1),w(1),p(1)
>       character*1 c1,c2(2)
>       common /scrns/ ur(lx1*ly1*lz1*lelv)
>      $             , ut(lx1*ly1*lz1*lelv)
>      $             , wr(lx1*ly1*lz1*lelv)
>      $             , wt(lx1*ly1*lz1*lelv)
>      $             , wp(lx1*ly1*lz1*lelv)
> c
> c     Convert velocities to poloidal-toroidal
> c
>       do i=1,n
>          rr = xm1(i,1,1,1)*xm1(i,1,1,1)+ym1(i,1,1,1)*ym1(i,1,1,1)
>          rr = sqrt(rr)
>          ct = xm1(i,1,1,1)/rr
>          st = ym1(i,1,1,1)/rr
>          ur(i) = ct*u(i)+st*v(i)
>          ut(i) = ct*v(i)-st*u(i)
>          wr(i) = ur(i)**2
>          wt(i) = ut(i)**2
>          wp(i) = w (i)**2
>       enddo
>       c2(1) = c1
>       c2(2) = 'y'
>       call y_avg_buff(ur,w ,ut,c2,'ub',icount)
>       call y_avg_buff(wr,wp,wt,c2,'u2',icount)
>       do i=1,n
>          wr(i) = ur(i)*ut(i)
>          wt(i) = ut(i)*w (i)
>          wp(i) = w (i)*ur(i)
>       enddo
>       call y_avg_buff(wr,wt,wp,c2,'uv',icount)
>       call y_ins_buff(ur,w ,ut,c2,'ui',icount)
>       return
>       end
>       subroutine z2d(u,v,w,p,c1,icount)
> c
> c
>       include 'SIZE'
>       include 'TOTAL'
> c
> c
> c
>       do i=1,n
>          wr(i) = u (i)**2
>          wt(i) = v (i)**2
>          wp(i) = w (i)**2
>       enddo
>       c2(1) = c1
>       c2(2) = 'z'
>       call z_avg_buff(u ,v ,w ,c2,'ub',icount)
>       call z_avg_buff(wr,wt,wp,c2,'u2',icount)
>       do i=1,n
>          wr(i) = u(i)*v(i)
>          wt(i) = v(i)*w(i)
>          wp(i) = w(i)*u(i)
>       enddo
>       call z_avg_buff(wr,wt,wp,c2,'uv',icount)
>       call z_ins_buff(u ,v ,w ,c2,'ui',icount)
>       return
>       end
>       subroutine anal_2d
>       include 'SIZE'
>       include 'TOTAL'
>       include 'ZPER'
>       integer icount
>       save    icount
>       if (nelx.gt.lelx .or.
>      $    nely.gt.lely .or.
>      $    nelz.gt.lelz ) then
>          if (nid.eq.0) write(6,1) nelx,nely,nelz,lelx,lely,lelz
>     1    format('anal_2d fail:',6i6)
>          return
>       endif
>       if (istep.eq.0) then   ! dump four times, just to keep phase
>          icount = 0
>          call z2d(xm1,ym1,zm1,pr,'u',icount)
>          if (ifmhd) call z2d(xm1,ym1,zm1,pm,'b',icount)
>          call y2d(xm1,ym1,zm1,pr,'u',icount)
>          if (ifmhd) call y2d(xm1,ym1,zm1,pm,'b',icount)
>       endif
>       icount = icount + 1
>       call z2d(vx,vy,vz,pr,'u',icount)
>       if (ifmhd) call z2d(bx,by,bz,pm,'b',icount)
>       call y2d(vx,vy,vz,pr,'u',icount)
>       if (ifmhd) call y2d(bx,by,bz,pm,'b',icount)
>       return
>       end
>       subroutine chkit(u,name4,n)
>       include 'SIZE'
>       include 'TOTAL'
>       character*4 name4
>       real u(1)
>       integer icalld
>       save    icalld
>       data    icalld /0/
>       icalld = icalld + 1
>       u2   = vlsc2(u,u,n)
>       umin = vlmin(u,n)
>       umax = vlmax(u,n)
>       ulst = u(n)
>       if (nid.eq.0)
>      $write(6,1) nid,icalld,istep,n,umin,umax,ulst,name4,' chkit',nid
>     1 format(4i7,1p3e12.4,a4,a6,i1)
>       return
>       end
>       subroutine outmesh
>       include 'SIZE'
>       include 'TOTAL'
>       integer e,eg
>       common /cmesh/ xt(2**ldim,ldim)
>       len = wdsize*ndim*(2**ndim)
>       if (nid.eq.0) open(unit=29,file='rea.new')
>       do eg=1,nelgt
>          mtype = eg
>          call nekgsync()          !  belt
>          jnid = gllnid(eg)
>          e    = gllel (eg)
>          if (jnid.eq.0 .and. nid.eq.0) then
>             call get_el(xt,xm1(1,1,1,e),ym1(1,1,1,e),zm1(1,1,1,e))
>             call out_el(xt,eg)
>          elseif (nid.eq.0) then
>             call crecv(mtype,xt,len)
>             call out_el(xt,eg)
>          elseif (jnid.eq.nid) then
>             call csend(mtype,xt,len,0,0)
>          endif
>          call nekgsync()          !  suspenders
>       enddo
>       if (nid.eq.0) close(29)
>       call nekgsync()
>       call exitt
>       return
>       end
>       subroutine out_el(xt,e)
>       include 'SIZE'
>       include 'TOTAL'
>       real xt(2**ldim,ldim)
>       integer e
>       integer ed(8)
>       save    ed
>       data    ed  / 1,2,4,3 , 5,6,8,7 /
>       write(29,1) e
>       write(29,2) ((xt(ed(k),j),k=1,4),j=1,ndim)
>       write(29,2) ((xt(ed(k),j),k=5,8),j=1,ndim)
>     1 format(12x,'ELEMENT',i6,' [    1 ]    GROUP     0')
>     2 format(1p4e18.10)
>       return
>       end
>       subroutine get_el(xt,x,y,z)
>       include 'SIZE'
>       include 'TOTAL'
>       real x(nx1,ny1,nz1),y(nx1,ny1,nz1),z(nx1,ny1,nz1)
>       l = 0
>       do k=1,nz1,nz1-1
>       do j=1,ny1,ny1-1
>       do i=1,nx1,nx1-1
>          l = l+1
>          xt(l,1) = x(i,j,k)
>          xt(l,2) = y(i,j,k)
>          xt(l,3) = z(i,j,k)
>       enddo
>       enddo
>       enddo
>       return
>       end
>       subroutine shear_calc_max(strsmx,scale,x0,ifdout,iftout)
> c
> c     Compute maximum shear stress on objects
> c
> c
> c
>       INCLUDE 'SIZE'
>       INCLUDE 'TOTAL'
>       real    strsmx(maxobj),x0(3),w1(0:maxobj)
>      $                , scale_vf(3)
>       endif
> by
> case,
> in
> c
> c    Compute sij
> c
>       nij = 3
> c
> c
> c
> c
> c
> c
> c
>       call rzero(strsmx,maxobj)
> c
> c
>       nobj = 0
>       do ii=1,nhis
>           iobj   = lochis(1,ii)
> c
>             ifield = 1
> c
> c           Compute max stress for this object
> c
>             strsmx(ii) = 0.
>             do mem=1,memtot
> contribution
>                   ie = gllel(ieg)
>                   call get_strsmax
>      $                    (strsmxl,xm0,ym0,zm0,sij,pm1,vdiff,ifc,ie)
>                   call cmult(strsmxl,scale,1)
>                   strsmx(ii)=max(strsmx(ii),strsmxl)
>                endif
>             enddo
>           endif
>         endif
>       enddo
> c
> c     Max contributions over all processors
> c
>       call gop(strsmx,w1,'M  ',maxobj)
>       return
>       end
>       subroutine get_strsmax(strsmax,xm0,ym0,zm0,sij,pm1,visc,f,e)
> c
>       INCLUDE 'SIZE'
>       INCLUDE 'GEOM'
>       INCLUDE 'INPUT'
>       INCLUDE 'TOPOL'
>       INCLUDE 'TSTEP'
> c
>       real dgtq(3,4)
>       integer f,e,pf
>       real    n1,n2,n3
>       js1    = skpdat(1,pf)
>       jf1    = skpdat(2,pf)
>       js2    = skpdat(4,pf)
>       jf2    = skpdat(5,pf)
>          i       = 0
>          strsmax = 0
>             i = i+1
>             n1 = unx(i,1,f,e)
>             n2 = uny(i,1,f,e)
>             n3 = unz(i,1,f,e)
> c
>             v  = visc(j1,j2,1,e)
> c
> c
>             stress1 = -v*(s11*n1 + s12*n2 + s13*n3) ! viscous drag
>             stress2 = -v*(s21*n1 + s22*n2 + s23*n3)
>             stress3 = -v*(s31*n1 + s32*n2 + s33*n3)
>             strsnrm = stress1*stress1+stress2*stress2+stress3*stress3
>             strsmax = max(strsmax,strsnrm)
>          enddo
>          enddo
>       else ! 2D
>          i       = 0
>          strsmax = 0
>             i = i+1
>             v  = visc(j1,j2,1,e)
>             stress1 = -v*(s11*n1 + s12*n2) ! viscous drag
>             stress2 = -v*(s21*n1 + s22*n2)
>        enddo
>        enddo
>       endif
>       if (strsmax.gt.0) strsmax = sqrt(strsmax)
>       return
>       end
>       subroutine fix_geom ! fix up geometry irregularities
>       include 'SIZE'
>       include 'TOTAL'
>       parameter (lt = lx1*ly1*lz1)
>       common /scrns/ xb(lt,lelt),yb(lt,lelt),zb(lt,lelt)
>       common /scruz/ tmsk(lt,lelt),tmlt(lt,lelt),w1(lt),w2(lt)
>       integer e,f
>       character*3 cb
>       n      = nx1*ny1*nz1*nelt
>       nxyz   = nx1*ny1*nz1
>       nfaces = 2*ndim
>       ifield = 1                   ! velocity field
>       if (ifheat) ifield = 2       ! temperature field
>       call rone  (tmlt,n)
>       call dssum (tmlt,nx1,ny1,nz1)  ! denominator
>       call rone  (tmsk,n)
>       do e=1,nelfld(ifield)      ! fill mask where bc is periodic
>       do f=1,nfaces              ! so we don't translate periodic bcs
> (z only)
>          cb =cbc(f,e,ifield)
>          if (cb.eq.'P  ') call facev (tmsk,e,f,0.0,nx1,ny1,nz1)
>       enddo
>       enddo
>       do kpass = 1,ndim+1   ! This doesn't work for 2D, yet.
>                             ! Extra pass is just to test convergence
> c        call opcopy (xb,yb,zb,xm1,ym1,zm1) ! Must use WHOLE field,
> c        call opdssum(xb,yb,zb)             ! not just fluid domain.
>          call copy   (xb,xm1,n)
>          call copy   (yb,ym1,n)
>          call copy   (zb,zm1,n)
>          call dssum  (xb,nx1,ny1,nz1)
>          call dssum  (yb,nx1,ny1,nz1)
>          call dssum  (zb,nx1,ny1,nz1)
>          xm = 0.
>          ym = 0.
>          zm = 0.
>             do i=1,nxyz                       ! compute averages of
> geometry
>                s     = 1./tmlt(i,e)
>                xb(i,e) = s*xb(i,e)
>                yb(i,e) = s*yb(i,e)
>                zb(i,e) = s*zb(i,e)
>                xb(i,e) = xb(i,e) - xm1(i,1,1,e)   ! local displacements
>                yb(i,e) = yb(i,e) - ym1(i,1,1,e)
>                zb(i,e) = zb(i,e) - zm1(i,1,1,e)
>                xb(i,e) = xb(i,e)*tmsk(i,e)
>                yb(i,e) = yb(i,e)*tmsk(i,e)
>                zb(i,e) = zb(i,e)*tmsk(i,e)
>                xm = max(xm,abs(xb(i,e)))
>                ym = max(ym,abs(yb(i,e)))
>                zm = max(zm,abs(zb(i,e)))
>             enddo
>             if (kpass.le.ndim) then
>                call gh_face_extend(xb(1,e),zgm1,nx1,kpass,w1,w2)
>                call gh_face_extend(yb(1,e),zgm1,nx1,kpass,w1,w2)
>                call gh_face_extend(zb(1,e),zgm1,nx1,kpass,w1,w2)
>             endif
>          enddo
>             call add2(xm1,xb,n)
>             call add2(ym1,yb,n)
>             call add2(zm1,zb,n)
>          endif
>          xx = glamax(xb,n)
>          yx = glamax(yb,n)
>          zx = glamax(zb,n)
>          xm = glmax(xm,1)
>          ym = glmax(ym,1)
>          zm = glmax(zm,1)
>          if (nid.eq.0) write(6,1) xm,ym,zm,xx,yx,zx,kpass
>     1    format(1p6e12.4,' xyz repair',i2)
>       enddo
>       param(59) = 1.       ! ifdef = .true.
>       call geom_reset(1)   ! reset metrics, etc.
>       return
>       end
>       subroutine gh_face_extend(x,zg,n,gh_type,e,v)
>       include 'SIZE'
>       real x(1),zg(1),e(1),v(1)
>       integer gh_type
>       if (ndim.eq.2) then
>          call gh_face_extend_2d(x,zg,n,gh_type,e,v)
>       else
>          call gh_face_extend_3d(x,zg,n,gh_type,e,v)
>       endif
>       return
>       end
>       subroutine gh_face_extend_2d(x,zg,n,gh_type,e,v)
> c
> c     Extend 2D faces into interior via gordon hall
> c
> c     gh_type:  1 - vertex only
> c               2 - vertex and faces
> c
> c
>       real x(n,n)
>       real zg(n)
>       real e(n,n)
>       real v(n,n)
>       integer gh_type
> c
> c     Build vertex interpolant
> c
>       ntot=n*n
>       call rzero(v,ntot)
>       do jj=1,n,n-1
>       do ii=1,n,n-1
>          do j=1,n
>          do i=1,n
>             si     = 0.5*((n-ii)*(1-zg(i))+(ii-1)*(1+zg(i)))/(n-1)
>             sj     = 0.5*((n-jj)*(1-zg(j))+(jj-1)*(1+zg(j)))/(n-1)
>             v(i,j) = v(i,j) + si*sj*x(ii,jj)
>          enddo
>          enddo
>       enddo
>       enddo
>       if (gh_type.eq.1) then
>          call copy(x,v,ntot)
>          return
>       endif
> c     Extend 4 edges
>       call rzero(e,ntot)
> c
> c     x-edges
> c
>       do jj=1,n,n-1
>          do j=1,n
>          do i=1,n
>             hj     = 0.5*((n-jj)*(1-zg(j))+(jj-1)*(1+zg(j)))/(n-1)
>             e(i,j) = e(i,j) + hj*(x(i,jj)-v(i,jj))
>          enddo
>          enddo
>       enddo
> c
> c     y-edges
> c
>       do ii=1,n,n-1
>          do j=1,n
>          do i=1,n
>             hi     = 0.5*((n-ii)*(1-zg(i))+(ii-1)*(1+zg(i)))/(n-1)
>             e(i,j) = e(i,j) + hi*(x(ii,j)-v(ii,j))
>          enddo
>          enddo
>       enddo
>       call add3(x,e,v,ntot)
>       return
>       end
>       subroutine gh_face_extend_3d(x,zg,n,gh_type,e,v)
> c
> c     Extend faces into interior via gordon hall
> c
> c               2 - vertex and edges
> c               3 - vertex, edges, and faces
> c
> c
>       real x(n,n,n)
>       real zg(n)
>       real e(n,n,n)
>       real v(n,n,n)
>       integer gh_type
> c
> c
>       ntot=n*n*n
>       call rzero(v,ntot)
>       do kk=1,n,n-1
>       do jj=1,n,n-1
>       do ii=1,n,n-1
>          do k=1,n
>          do j=1,n
>          do i=1,n
>             sk       = 0.5*((n-kk)*(1-zg(k))+(kk-1)*(1+zg(k)))/(n-1)
>             v(i,j,k) = v(i,j,k) + si*sj*sk*x(ii,jj,kk)
>          enddo
>          enddo
>          enddo
>       enddo
>       enddo
>       enddo
>          call copy(x,v,ntot)
>          return
>       endif
> c
> c
> c     Extend 12 edges
>       call rzero(e,ntot)
> c
> c     x-edges
> c
>       do kk=1,n,n-1
>       do jj=1,n,n-1
>          do k=1,n
>          do j=1,n
>          do i=1,n
>             hk       = 0.5*((n-kk)*(1-zg(k))+(kk-1)*(1+zg(k)))/(n-1)
>             e(i,j,k) = e(i,j,k) + hj*hk*(x(i,jj,kk)-v(i,jj,kk))
>          enddo
>          enddo
>          enddo
>       enddo
>       enddo
> c
> c     y-edges
> c
>       do kk=1,n,n-1
>       do ii=1,n,n-1
>          do k=1,n
>          do j=1,n
>          do i=1,n
>             e(i,j,k) = e(i,j,k) + hi*hk*(x(ii,j,kk)-v(ii,j,kk))
>          enddo
>          enddo
>          enddo
>       enddo
>       enddo
> c
> c     z-edges
> c
>       do jj=1,n,n-1
>       do ii=1,n,n-1
>          do k=1,n
>          do j=1,n
>          do i=1,n
>             e(i,j,k) = e(i,j,k) + hi*hj*(x(ii,jj,k)-v(ii,jj,k))
>          enddo
>          enddo
>          enddo
>       enddo
>       enddo
> c
>       call add2(e,v,ntot)
> c
>       if (gh_type.eq.2) then
>          call copy(x,e,ntot)
>          return
>       endif
> c
> c     Extend faces
> c
>       call rzero(v,ntot)
> c
> c     x-edges
> c
>       do ii=1,n,n-1
>          do k=1,n
>          do j=1,n
>          do i=1,n
>             v(i,j,k) = v(i,j,k) + hi*(x(ii,j,k)-e(ii,j,k))
>          enddo
>          enddo
>          enddo
>       enddo
> c
> c     y-edges
> c
>       do jj=1,n,n-1
>          do k=1,n
>          do j=1,n
>          do i=1,n
>             v(i,j,k) = v(i,j,k) + hj*(x(i,jj,k)-e(i,jj,k))
>          enddo
>          enddo
>          enddo
>       enddo
> c
> c     z-edges
> c
>       do kk=1,n,n-1
>          do k=1,n
>          do j=1,n
>          do i=1,n
>             v(i,j,k) = v(i,j,k) + hk*(x(i,j,kk)-e(i,j,kk))
>          enddo
>          enddo
>          enddo
>       enddo
> c
>       call add2(v,e,ntot)
>       call copy(x,v,ntot)
>       return
>       end
>       function ran1(idum)
> c
>       integer idum,ia,im,iq,ir,ntab,ndiv
>       real    ran1,am,eps,rnmx
> c
>       parameter (ia=16807,im=2147483647,am=1./im,iq=127773,ir=2836)
>       parameter (ntab=32,ndiv=1+(im-1)/ntab,eps=1.2e-7,rnmx=1.-eps)
> c
> c     Numerical Rec. in Fortran, 2nd eD.  P. 271
> c
>       integer j,k
>       integer iv(ntab),iy
>       save    iv,iy
>       data    iv,iy /ntab*0,0/
> c
>       if (idum.le.0.or.iy.eq.0) then
>          idum=max(-idum,1)
>          do j=ntab+8,1,-1
>             k    = idum/iq
>             idum = ia*(idum-k*iq)-ir*k
>             if(idum.lt.0) idum = idum+im
>             if (j.le.ntab) iv(j) = idum
>          enddo
>          iy = iv(1)
>       endif
>       k    = idum/iq
>       j     = 1+iy/ndiv
>       iy    = iv(j)
>       iv(j) = idum
>       ran1  = min(am*iy,rnmx)
> c     ran1  = cos(ran1*1.e8)
>       return
>       end
>       subroutine rand_fld_h1(x)
>       include 'SIZE'
>       real x(1)
>       n=nx1*ny1*nz1*nelt
>       id = n
>       do i=1,n
>          x(i) = ran1(id)
>       enddo
>       call dsavg(x)
>       return
>       end
>       subroutine rescale_x (x,x0,x1)
>       include 'SIZE'
>       real x(1)
>       xmin = glmin(x,n)
>       xmax = glmax(x,n)
>       if (xmax.le.xmin) return
>       scale = (x1-x0)/(xmax-xmin)
>       do i=1,n
>          x(i) = x0 + scale*(x(i)-xmin)
>       enddo
>       return
>       end
>       subroutine z_distribute(u)
> c
> c     Compute the z average of quantity u() and redistribute
> c
> c     Assumes you have nelx*nely elements, in the same order,
> c     within each z plane
> c
> c
>       include 'SIZE'
>       include 'TOTAL'
>       include 'ZPER'
>       character*2 c2,name
>       common /scravg/ ua(lyavg)
>      $              , w1(lyavg)
>      $              , w2(lyavg)
>       call z_average          (ua,u,w1,w2)
>       call z_average_transpose(u,ua) ! distribute ua to each z-plane
>       return
>       end
>       subroutine z_average(ua,u,w1,w2)
> c
> c
>       include 'SIZE'
>       include 'GEOM'
>       include 'PARALLEL'
>       include 'WZ'
>       include 'ZPER'
>       real dy2
>       nelxy = nelx*nely
>       if (nelxy.gt.lelx*lely) call exitti
>      $  ('ABORT IN z_average. Increase lelx*lely in SIZE:$',nelxy)
>       call rzero(ua,mxy)
>       call rzero(w1,mxy)
>       do e=1,nelt
>          eg = lglel(e)
>          do j=1,ny1
>          do i=1,nx1
>             dz2 = 1.0  !  Assuming uniform in "z" direction
>             do k=1,nz1
>                ua(i,j,ex,ey) = ua(i,j,ex,ey)+dz2*wzm1(k)*u(i,j,k,e)
>                w1(i,j,ex,ey) = w1(i,j,ex,ey)+dz2*wzm1(k) ! redundant
> but clear
>             enddo
>          enddo
>          enddo
>       enddo
>       call gop(w1,w2,'+  ',mxy)
>       do i=1,mxy
>       enddo
>       return
>       end
>       subroutine z_average_transpose(u,ua) ! distribute ua to each
> z-plane
>       include 'SIZE'
>       include 'GEOM'
>       include 'PARALLEL'
>       include 'WZ'
>       include 'ZPER'
>       real u(nx1,ny1,nz1,nelv),ua(nx1,ny1,nelx,nely)
>       do e=1,nelt
>          eg = lglel(e)
>          do j=1,ny1
>          do i=1,nx1
>             do k=1,nz1
>                u(i,j,k,e) = ua(i,j,ex,ey)
>             enddo
>          enddo
>          enddo
>       enddo
>       return
>       end
>       subroutine no_z_profile(u)
> c     Subtract the z_profile from u for a tensor-product array of
> elements
> c     Assumes you have nelx*nely*nelz elements, in the same order,
> c     and that lelx,lely,lelz are defined to be >= nelx,nely,nelz
>       include 'SIZE'
>       include 'TOTAL'
>       include 'ZPER'         ! nelx,nely,nelz
>       real u(1)
>       parameter (lyavg = ly1*lely)
>      $              , w1(lyavg)
>      $              , w2(lyavg)
>       common /scrmg/  ub(lx1*ly1*lz1*lelt)
>       call z_profile          (ua,u,w1,w2)
>       call z_profile_transpose(ub,ua) ! distribute ua to each z-plane
>       call sub2(u,ub,n)
>       return
>       end
>       subroutine z_profile(ua,u,w1,w2)
> c
> c     Compute the z profile of quantity u() - assumes global tens.prod.
> c
>       include 'SIZE'
>       include 'GEOM'
>       include 'PARALLEL'
>       include 'WZ'
>       include 'ZPER'
>       real ua(lz1,lelz),u (nx1,ny1,nz1,nelv)
>      $    ,w1(lz1,lelz),w2(lz1,lelz)
>       mz = nz1*nelz
>       call rzero(ua,mz)
>       call rzero(w1,mz)
>       do e=1,nelt
>          eg = lglel(e)
>          do k=1,nz1
>          do i=1,nx1*ny1
>             ua(k,ez) = ua(k,ez) + area(i,1,5,e)*u(i,1,k,e)
>             w1(k,ez) = w1(k,ez) + area(i,1,5,e)
>          enddo
>          enddo
>       enddo
>       call gop(ua,w2,'+  ',mz)
>       call gop(w1,w2,'+  ',mz)
>       do i=1,mz
>       enddo
>       return
>       end
>       subroutine z_profile_transpose(u,ua) ! distribute ua to each
> z-plane
>       include 'SIZE'
>       include 'PARALLEL'
>       include 'ZPER'
>       real u(nx1,ny1,nz1,nelv),ua(lz1,lelz)
>       do e=1,nelt
>          eg = lglel(e)
>          do k=1,nz1
>          do i=1,nx1*ny1
>             u(i,1,k,e) = ua(k,ez)
>          enddo
>          enddo
>       enddo
>       return
>       end
>       subroutine no_y_profile(u)
> c     Subtract the y_profile from u for a tensor-product array of
> elements
>       include 'SIZE'
>       include 'TOTAL'
>       real u(1)
>      $              , w1(lyavg)
>      $              , w2(lyavg)
>       call y_profile          (ua,u,w1,w2)
>       call y_profile_transpose(ub,ua) ! distribute ua to each y-plane
>       call sub2(u,ub,n)
>       return
>       end
>       subroutine y_profile(ua,u,w1,w2)
> c
> c
>       include 'SIZE'
>       include 'GEOM'
>       include 'PARALLEL'
>       include 'WZ'
>       include 'ZPER'
>       my = ny1*nely
>       call rzero(ua,my)
>       call rzero(w1,my)
>       do e=1,nelt
>          eg = lglel(e)
>          do k=1,nz1
>          do j=1,ny1
>          do i=1,nx1
>             ua(j,ey) = ua(j,ey) + area(i,k,1,e)*u(i,j,k,e)
>             w1(j,ey) = w1(j,ey) + area(i,k,1,e)
>          enddo
>          enddo
>          enddo
>       enddo
>       call gop(ua,w2,'+  ',my)
>       call gop(w1,w2,'+  ',my)
>       do i=1,my
>       enddo
>       return
>       end
>       subroutine y_profile_transpose(u,ua) ! distribute ua to each
> z-plane
>       include 'SIZE'
>       include 'PARALLEL'
>       include 'ZPER'
>       do e=1,nelt
>          eg = lglel(e)
>          do k=1,nz1
>          do j=1,ny1
>          do i=1,nx1
>             u(i,j,k,e) = ua(j,ey)
>          enddo
>          enddo
>          enddo
>       enddo
>       return
>       end
>       subroutine build_filter(f,diag,nx)
>       include 'SIZE'
>       real f(nx,nx),diag(nx),zpts(nx)
>       parameter (lm=4*lx1) ! Totally arbitrary
>       common /cfilt1/ phi,pht,ft,rmult,Lj,gpts,indr,indc,ipiv
>       real      phi(lm2),pht(lm2),ft(lm2),rmult(lm),Lj(lm),gpts(lm)
>       integer nxl
>       save    nxl
>       data    nxl / -9 /
>       if (nx.gt.lm) call exitti('ABORT in build_filter:$',nx)
>       if (nx.ne.nxl) then
>         nxl = nx
>         call zwgll (gpts,f,nx)  ! Get nx GLL points
>         kj = 0
>         n  = nx-1
>         do j=1,nx
>          z = gpts(j)
>          kj = kj+1
>          pht(kj) = Lj(1)
>          kj = kj+1
>          pht(kj) = Lj(2)
>          do k=3,nx
>             kj = kj+1
>          enddo
>         enddo
>       endif ! End of save section
>       ij=0
>       do j=1,nx
>       do i=1,nx
>          ij = ij+1
>          ft(ij) = diag(i)*pht(ij)
>       enddo
>       enddo
>                                           !          -1
>       call mxm  (phi,nx,ft,nx,f,nx)       !     V D V
>       return
>       end
>       subroutine g_filter(u,diag,ifld)
> c
> c     Generalized filter: F(u) with F = J^T D J, where D=diag(diag)
> c
>       include 'SIZE'
>       include 'TOTAL'
>       real u(1),diag(1)
>       parameter (lxx=lx1*lx1,lxyz=lx1*ly1*lz1)
>       common /ctmp0/ f(lxx),wk1(lxyz),wk2(lxyz),wk3(lxyz)
>       ifldt = ifield
>       ifield = ifld
>       call build_filter(f,diag,nx1)
>       call filterq(u,f,nx1,nz1,wk1,wk2,wk3,if3d,umax)
>       ifield = ifldt
>       return
>       end
>       subroutine cut_off_filter(u,mx,ifld) ! mx=max saved mode
> c
> c
>       include 'SIZE'
>       include 'TOTAL'
>       real u(1)
>       common /ctmp0/ f(lxx),wk1(lxyz),wk2(lxyz),wk3(lxyz),diag(lx1)
>       ifldt = ifield
>       ifield = ifld
>       call rone(diag,nx1)
>       do i=mx+1,nx1
>          diag(i)=0.
>       enddo
>       ifield = ifldt
>       return
>       end
>       subroutine filter_d2(v,nx,nz,wgt,ifd4)
>       include 'SIZE'
>       include 'TOTAL'
>       parameter (lt=lx1*ly1*lz1)
>       real v(lt,nelt)
>       logical ifd4
>       common /ctmp1/ w(lt,lelt),ur(lt),us(lt),ut(lt),w1(2*lt)
>       integer e
>       nn  = nx-1
>       bmax = glamax(v,n)
>       if (if3d) then
>         do e=1,nel
>           call local_grad3(ur,us,ut,v(1,e),nn,1,dxm1,dxtm1)
>           do i=1,lt
>             ur(i) = ur(i)*w3m1(i,1,1)
>             us(i) = us(i)*w3m1(i,1,1)
>             ut(i) = ut(i)*w3m1(i,1,1)
>           enddo
>           call local_grad3_t(w(1,e),ur,us,ut,nn,1,dxm1,dxtm1,w1)
>         enddo
>         call dsavg(w)  !NOTE STILL NEED BC TREATMENT !
>         if (ifd4) then
>            wght = 20./(nx1**4)
>            do e=1,nel
>              do i=1,lt
>                w(i,e)  = wght*w(i,e)/w3m1(i,1,1)
>              enddo
>              call local_grad3(ur,us,ut,w(1,e),nn,1,dxm1,dxtm1)
>              do i=1,lt
>              enddo
>            enddo
>         endif
>         wght = wgt/(nx1**4)
>         do e=1,nel
>           do i=1,lt
>             v(i,e)  = v(i,e) - wght*w(i,e)/w3m1(i,1,1)
>           enddo
>         enddo
>       else  ! 2D
>         do e=1,nel
>           call local_grad2(ur,us,v(1,e),nn,1,dxm1,dxtm1)
>           do i=1,lt
>           enddo
>           call local_grad2_t(w(1,e),ur,us,nn,1,dxm1,dxtm1,w1)
>         enddo
>         if (ifd4) then
>            wght = 200./(nx1**4)
>            do e=1,nel
>              do i=1,lt
>              enddo
>              call local_grad2(ur,us,w(1,e),nn,1,dxm1,dxtm1)
>              do i=1,lt
>              enddo
>            enddo
>         endif
>         wght = wgt/(nx1**4)
>         do e=1,nel
>           do i=1,lt
>           enddo
>         enddo
>       endif
>       vmax = glamax(v,n)
>       if (nid.eq.0) write(6,1) istep,time,vmax,bmax,' filter max'
>     1 format(i9,1p3e12.4,a11)
>       return
>       end
>       function dist3d(a,b,c,x,y,z)
>       d = (a-x)**2 + (b-y)**2 + (c-z)**2
>       dist3d = 0.
>       if (d.gt.0) dist3d = sqrt(d)
>       return
>       end
>       function dist2d(a,b,x,y)
>       dist2d = 0.
>       if (d.gt.0) dist2d = sqrt(d)
>       return
>       end
>       subroutine domain_size(xmin,xmax,ymin,ymax,zmin,zmax)
>       include 'SIZE'
>       include 'TOTAL'
>       xmin = glmin(xm1,n)
>       xmax = glmax(xm1,n)
>       ymin = glmin(ym1,n)
>       ymax = glmax(ym1,n)
>       if (if3d) then
>          zmin = glmin(zm1,n)
>          zmax = glmax(zm1,n)
>       else
>          zmin = 0.
>          zmax = 0.
>       endif
>       return
>       end
>       subroutine cheap_dist(d,ifld,b)
> c     Finds a pseudo-distance function.
> c     INPUT:  ifld - field type for which distance function is to be
> found.
> c             ifld = 1 for velocity
> c             ifld = 2 for temperature, etc.
> c     OUTPUT: d = "path" distance to nearest wall
> c     This approach has a significant advantage that it works for
> c     periodict boundary conditions, whereas most other approaches
> c     will not.
>       include 'SIZE'
>       include 'GEOM'       ! Coordinates
>       include 'INPUT'      ! cbc()
>       include 'TSTEP'      ! nelfld
>       include 'PARALLEL'   ! gather-scatter handle for field "ifld"
>       real d(lx1,ly1,lz1,lelt)
>       character*3 b  ! Boundary condition of interest
>       integer e,eg,f
>       nel = nelfld(ifld)
>       n = nx1*ny1*nz1*nel
>       call domain_size(xmin,xmax,ymin,ymax,zmin,zmax)
>       xmn = min(xmin,ymin)
>       xmx = max(xmax,ymax)
>       if (if3d) xmn = min(xmn ,zmin)
>       if (if3d) xmx = max(xmx ,zmax)
>       big = 10*(xmx-xmn)
>       call cfill(d,big,n)
>       nface = 2*ndim
>       do e=1,nel     ! Set d=0 on walls
>       do f=1,nface
>          if (cbc(f,e,ifld).eq.b) call facev(d,e,f,0.,nx1,ny1,nz1)
>       enddo
>       enddo
>       do ipass=1,10000
>          dmax    = 0
>          nchange = 0
>          do e=1,nel
>            do k=1,nz1
>            do j=1,ny1
>            do i=1,nx1
>              i0=max(  1,i-1)
>              j0=max(  1,j-1)
>              k0=max(  1,k-1)
>              i1=min(nx1,i+1)
>              j1=min(ny1,j+1)
>              k1=min(nz1,k+1)
>              do kk=k0,k1
>              do jj=j0,j1
>              do ii=i0,i1
>               if (if3d) then
>                dtmp = d(ii,jj,kk,e) + dist3d(
>      $           xm1(ii,jj,kk,e),ym1(ii,jj,kk,e),zm1(ii,jj,kk,e)
>      $          ,xm1(i ,j ,k ,e),ym1(i ,j ,k ,e),zm1(i ,j ,k ,e))
>               else
>                dtmp = d(ii,jj,kk,e) + dist2d(
>      $          ,xm1(i ,j ,k ,e),ym1(i ,j ,k ,e))
>               endif
>               if (dtmp.lt.d(i,j,k,e)) then
>                 d(i,j,k,e) = dtmp
>                 nchange = nchange+1
>                 dmax = max(dmax,d(i,j,k,e))
>               endif
>              enddo
>              enddo
>              enddo
>            enddo
>            enddo
>            enddo
>          enddo
>          call gs_op(gsh_fld(ifld),d,1,3,0) ! min over all elements
>          nchange = iglsum(nchange,1)
>          dmax = glmax(dmax,1)
>          if (nid.eq.0) write(6,1) ipass,nchange,dmax
>     1    format(i9,i12,1pe12.4,' max wall distance 1')
>          if (nchange.eq.0) goto 1000
>       enddo
>  1000 return
>       end
> c-----------------------------------------------------------------------
>       subroutine distf(d,ifld,b,dmin,emin,xn,yn,zn)
> c     Generate a distance function to boundary with bc "b".
> c     This approach does not yet work with periodic boundary
> conditions.
> found.
> c     OUTPUT: d = distance to nearest boundary with boundary condition
> "b"
> c     Work arrays:  dmin,emin,xn,yn,zn
>       include 'SIZE'
>       character*3 b
>       real dmin(lx1,ly1,lz1,lelt),emin(lx1,ly1,lz1,lelt)
>       real xn(lx1,ly1,lz1,lelt),yn(lx1,ly1,lz1,lelt)
>       real zn(lx1,ly1,lz1,lelt)
>       integer e,eg,f
>       nel = nelfld(ifld)
>       n = nx1*ny1*nz1*nel
>       big = 10*(xmx-xmn)
>       call cfill (d,big,n)
>       call opcopy(xn,yn,zn,xm1,ym1,zm1)
>       nface = 2*ndim
>       do f=1,nface
>          if (cbc(f,e,1).eq.b) call facev(d,e,f,0.,nx1,ny1,nz1)
>       enddo
>       enddo
>       nxyz = nx1*ny1*nz1
>       do ipass=1,10000
>          dmax    = 0
>          nchange = 0
>          do e=1,nel
>             do k=1,nz1
>             do j=1,ny1
>             do i=1,nx1
>               i0=max(  1,i-1)
>               j0=max(  1,j-1)
>               k0=max(  1,k-1)
>               i1=min(nx1,i+1)
>               j1=min(ny1,j+1)
>               k1=min(nz1,k+1)
>               do kk=k0,k1
>               do jj=j0,j1
>               do ii=i0,i1
>                dself  = d(i,j,k,e)
>                dneigh = d(ii,jj,kk,e)
>                if (dneigh.lt.dself) then  ! check neighbor's nearest
> point
>                   d2 = (xm1(i,j,k,e)-xn(ii,jj,kk,e))**2
>      $               + (ym1(i,j,k,e)-yn(ii,jj,kk,e))**2
>                   if (if3d) d2 = d2 + (zm1(i,j,k,e)-zn(ii,jj,kk,e))**2
>                   if (d2.gt.0) d2 = sqrt(d2)
>                   if (d2.lt.dself) then
>                     nchange = nchange+1
>                     d (i,j,k,e) = d2
>                     xn(i,j,k,e) = xn(ii,jj,kk,e)
>                     yn(i,j,k,e) = yn(ii,jj,kk,e)
>                     zn(i,j,k,e) = zn(ii,jj,kk,e)
>                   endif
>                endif
>               enddo
>               enddo
>               enddo
>             enddo
>             enddo
>             enddo
>             re = lglel(e)
>             call cfill(emin(1,1,1,e),re,nxyz)
>             call copy (dmin(1,1,1,e),d(1,1,1,e),nxyz)
>          enddo
>          call gs_op(gsh_fld(ifld),dmin,1,3,0) ! min over all elements
>          nchange2=0
>          do e=1,nel
>          do i=1,nxyz
>           if (dmin(i,1,1,e).ne.d(i,1,1,e)) then
>              nchange2 = nchange2+1
>              emin(i,1,1,e) = 0  ! Flag
>           endif
>          enddo
>          enddo
>          call copy(d,dmin,n)                !   Ensure updated distance
>          nchange2 = iglsum(nchange2,1)
>          nchange  = nchange + nchange2
>          call gs_op(gsh_fld(ifld),emin,1,4,0) ! max over all elements
>          do e=1,nel    ! Propagate nearest wall points
>          do i=1,nxyz
>           eg = emin(i,1,1,e)
>           if (eg.ne.lglel(e)) then
>              xn(i,1,1,e) = 0
>              yn(i,1,1,e) = 0
>              zn(i,1,1,e) = 0
>           endif
>          enddo
>          enddo
>          call gs_op(gsh_fld(ifld),xn,1,1,0) !   Sum over all elements
> to
>          call gs_op(gsh_fld(ifld),yn,1,1,0) !   convey nearest point
>          call gs_op(gsh_fld(ifld),zn,1,1,0) !   to shared neighbor.
>     1    format(i9,i12,1pe12.4,' max wall distance 2')
>       enddo
>  1000 continue
> c     wgt = 0.3
> c     call filter_d2(d,nx1,nz1,wgt,.true.)
>       return
>       end
> Nek5000-users mailing list
