Mesh set question
Tim Tautges
tautges at mcs.anl.gov
Thu Oct 29 11:25:03 CDT 2009
For those not following the thread closely, I think we're converging, right Carl?
Carl Ollivier-Gooch wrote:
> Tim Tautges wrote:
>>> One of the implications of what we're developing in itaps is that
>> multiple services may be applied to a given data base, and those
>> services may leave data and metadata around on the mesh. We all agree
>> we should avoid the combinatorial problem of all services needing to
>> code to all implementations' native interfaces (thus the common
>> interface). Getting multiple services working on a database, though,
>> also means that we can't require each service to understand the
>> metadata potentially left there by other services. What we can do is
>> provide a way for the application, which often knows about all the
>> services it's calling, to specify the proper behavior when handling
>> this metadata, in the language or data model used by the interfaces.
> This I definitely agree with, to the extent that it's possible to -have-
> proper behavior for the metadata. Some of that behavior is still going
> to be expensive, though (example: entity handle tags are going to be
> difficult or impossible for a service to update properly).
That'll always be the case when applications can embed information in the data model. I think this is better than the
alternatives (changing the interface for each new application, or not allowing apps to embed data using the data model).
>> For example... I've written a copy/move/merge mesh capability in
>> MeshKit, to help mesh these large fuel pin assemblies and lattices of
>> assemblies. Performing this operation on actual mesh entities is
>> trivial. Properly handling metadata that comes with typical meshes is
>> not. However, these behaviors can be abstracted and specified in
>> terms of our data model. In the copy/move/merge case, I use the
>> notion of "copy" and "expand" set types; "copy" sets having entities
>> which get copied themselves get copied, and given the copies as
>> contents. For expand sets, the new entities get added to those.
>> Criteria for determining whether a set is copy or expand can be
>> specified by passing the sets themselves or tag types (and optionally
>> values) which identify the sets. Using this scheme, it's a very
>> simple matter to have my service do "the right thing" with material
>> sets (expand), neumann bcs (expand), geometric volumes (copy), parts
>> (copy), reactor assemblies (copy), and lots of other things. This is
>> all without knowing the purpose of all these sets.
> So this is an example of using a tag convention as a way to communicate
> between an app and a service, with (as I understand it) all the work at
> the iMesh level being standard. If my understanding is correct, this
> example would work with any compliant implementation as a back end, so
> long as the app and service know about the same tag convention.
It's slightly easier than that: the convention is how the application recognizes things like material sets and neumann
bcs; communication between the app and the copy/move service is in terms of data model characteristics, and does not
rely on conventions. This example will work with any compliant application; this hasn't been demonstrated, but would be
useful to demonstrate.
>> In summary: I don't believe it's possible to define the "right"
>> behavior for sets under mesh modification at the mesh interface level,
>> because the semantics of what the sets represent and how they behave
>> can vary infinitely with the application.
> That's true in general, but doesn't preclude the possibility of certain
> common behaviors that are (at least) worth creating documented tag
> conventions for, or more (since an implementation will have to be
> tricksy to take advantage of a tag convention).
Yes, modulo what "or more" means (e.g. changing the interface is right out).
>>> The semantics that make the most sense to me, at least at first
>>> glance, for modification are classification / reverse classification,
>>> which I (as a service writer) would run through iRel rather than
>>> looking at sets anyway. And in any case, working on a classification
>>> basis will necessarily trash other sets.
>> There are examples where you'll want to do this without iRel too. For
>> example, material types and boundary conditions. This is the point
>> where Mark will say that he requires geometry to track these too, but
>> not the only way to do it. In fact, you can abstract this such that
>> the application calling the adapt service can specify rules for
>> modifying sets, without the adapt service needing to know the set
>> semantics, while also preserving the ability to relate to the geometry
>> subsequently. That may not always be the right way to do it, but I
>> think it can also be said that there are non-trivial cases where that
>> is the right way to do things.
> But doesn't this require the ability to go from entity to set, to check
> whether the entities you're about to replace with a different collection
> of entities are in the same set (material type for regions, BC for bdry
> faces, etc), as well as some sort of tag convention to specify that
> these sets matter and those don't? The latter is pretty easy, I
> suspect, but the former is not (interface functionality aside, it costs
> either time or space to implement...). I agree that, if the
> modification app knows "replace only co-setted entities with entities
> that you also put in that set" then you don't lose mesh set->geom entity
> classification, or anything else you cared about with that set, but the
> current interface is awkward for this, at best.
In some cases, this does require going from entity to set with reasonable speed. Whether this is easy or not depends on
the implementation. If the implementation is too slow doing it with the current interface, another option is to
implement it as a service on top of the interface, with the application caching entity->set relationships. If tag
retrieval has "reasonable speed", this will no worse. In either case, of course you will pay either memory or speed.
You'll pay similarly with any type of observer pattern.
Note that a key part of our interface that allows us to do this from the service level is limiting ourselves to only
primitive create/delete operations on entities. That is, entities don't get deleted under the interface w/o the
application having requested it. Though, if the app is a service, and there are other services depending on the mesh,
then chaos ensues. There are ways to handle this, though, too.
>> Again, I think we need to think more abstractly here. Classification
>> and reverse classification are only one application of relations; even
>> calling something "reverse" is specific to the semantics of how the
>> mesh is generated and adapted. Thinking of these things in terms of
>> generic sets greatly reduces the number of operations you have to
>> support to implement those semantics.
> Maybe. I'd have to think about this a lot more to be sure one way or
> the other. I suspect that some operations are really easy one way and
> hard the other, and vice versa.
>>> I stand by my statement. The interaction of sets and tags with mesh
>>> modification is something that I don't recall ever discussing,
>> "ever" is a pretty strong statement. I won't go trolling through old
>> emails, as I'm sorely tempted to do here. But, I can say that I had a
>> hard enough time convincing people that sets were even needed or even
>> useful, so we may not have spent much time on the deeper question
>> about what to do with them under modification.
> I did say I didn't recall it; that's my protection if you go digging.
> ;-) Certainly I missed the original set discussions. But given that we
> didn't get iterators right under modification without changing them (at
> least?) once, it would be surprising if sets and tags are much better.
I'm not saying the interface will never need changing, just that the data model it's built on can support the things
we're talking about, and support it efficiently. That also doesn't mean it's easy to support efficiently on all types
of implementations.
>> and our
>>> current interface provides no way for a service that does mesh
>>> modification to correctly and efficiently handle sets that the
>>> application that called it thinks are important (even if given enough
>>> info to be correct, a service can't be efficient).
>> At best, that statement is way stronger than it should be ("no way"?
>> c'mon...). First, you're arguing from the standpoint of a very
>> specific kind of mesh modification.
> True, but for the specific case of swapping, I can't even efficiently
> identify (i.e., without querying all sets) which sets an entity belongs
> to so that I can try to make the decision about what to do with the new
> entities. Hence, my statement, which I probably should have qualified
> to say that it applies to at least some services, though not all.
> There may be an alternative way to implement swapping that doesn't have
> this problem, but I can't see it offhand. Iterating over
> highest-dimensional entities in a set almost works, but you have to know
> which of its second-adjacent highest-dimensional entities are -also- in
> the set, which gets you back in trouble. Plus, you examine all the swap
> candidates twice in an iteration over the set.
I think the way this needs to be done is to allow applications to tell you which sets they want the swapping service to
update. After that, the tracking is the cost of traversing the sets once, the storage of entity->set membership, and
the cost of querying those relationships as you swap. If your implementation already stores that information, then the
query of sets an entity is in is likely efficient, and you don't need it.
Actually, this begs another question: should we have the equivalent of an AdjacencyTable functionality, but for entities
in sets?
>>> The easiest fix is to document that the sets may be garbage on return
>>> and caveat app. Intermediate would be to ignore sets in mesh
>>> modification, but to remove ents from sets if they get deleted
>>> (otherwise you can't re-use that memory without potentially putting
>>> an entity in the wrong set).
>> We can't specify these types of rules at the interface spec level,
>> because that will overconstrain some implementations and use cases.
>> For maximum interoperability, one could implement the service to
>> provide options for the application to select. For example, an option
>> for whether the service deletes entities from sets before deleting the
>> entity itself, or not. The first case would work better on an
>> implementation that was minimal and efficient in time and space (e.g.
>> MOAB under certain conditions). The second would be better for
>> implementations that already had a rich observer capability (e.g.
>> GRUMMP, or MOAB under other conditions).
> From an interoperability point of view, having the -service- provide
> options that cause it to interact differently with the implementation is
> very different from having different implementations do things that only
> they can do. The former I have no issues with at all; the latter is a
> slippery slope away from where I believe we should be. (Yes, I know,
> are an O(n) implementation and an O(n^2) implementation of the same
> capability interoperable? Good question. I'm glad you asked it. Next
> question?)
The slippery slope argument is a good one, and we should be careful about options in general. Carl, I'm not sure you
were around that early, but I did vehemently resist the notion of options early on in TSTT for things like identifying
tags in tag get data functions (arguing in favor of tag handles instead). Also, I think it should be understood that
the options are recommendations only.
The argument for options is that they give both implementations and applications flexibility. In fact, why do we have
options for load and save? As another example, the notion of dense vs. sparse tags seems to be gaining momentum. But,
if we put that into the interface, I can bet that will put a burden on many implementations, and some implementations
may not support it for a long time or ever (mesh shape interface, anybody?) Using options gives them the option.
One more note, I think we do need an additional error code, which is really a warning, about unhandled options. That's
already turned up as an issue in reactor simulation, where the application was passing an option wrongly, and never knew.
- tim
>> And c'mon, you made it that far in my message but passed up the chance
>> to ridicule my obscure Vonnegut reference? :)
> I'm not familiar with those particular Vonnegut pieces, and I couldn't
> muster any nuanced ridicule by that time anyway. ;-)
> Carl
steadfast, because he trusts in you." Isaiah 26:3
Tim Tautges Argonne National Laboratory
(tautges at mcs.anl.gov) (telecommuting from UW-Madison)
phone: (608) 263-8485 1500 Engineering Dr.
fax: (608) 263-4499 Madison, WI 53706
More information about the tstt-interface
