Mesh set question
Mark Shephard shephard at scorec.rpi.edu
Thu Oct 29 12:48:39 CDT 2009
I must admit I have gotten pretty lost in this chain of discussion. If
this converges, I expect that there will need to be something that
states what the conclusion is.
Tim Tautges wrote:
> For those not following the thread closely, I think we're converging,
> right Carl?
> Carl Ollivier-Gooch wrote:
>> Tim Tautges wrote:
>>>> One of the implications of what we're developing in itaps is that
>>> multiple services may be applied to a given data base, and those
>>> services may leave data and metadata around on the mesh.  We all
>>> agree we should avoid the combinatorial problem of all services
>>> needing to code to all implementations' native interfaces (thus the
>>> common interface).  Getting multiple services working on a database,
>>> though, also means that we can't require each service to understand
>>> the metadata potentially left there by other services.  What we can
>>> do is provide a way for the application, which often knows about all
>>> the services it's calling, to specify the proper behavior when
>>> handling this metadata, in the language or data model used by the
>>> interfaces.
>> This I definitely agree with, to the extent that it's possible to
>> -have- proper behavior for the metadata.  Some of that behavior is
>> still going to be expensive, though (example: entity handle tags are
>> going to be difficult or impossible for a service to update properly).
> That'll always be the case when applications can embed information in
> the data model.  I think this is better than the alternatives (changing
> the interface for each new application, or not allowing apps to embed
> data using the data model).
>>> For example... I've written a copy/move/merge mesh capability in
>>> MeshKit, to help mesh these large fuel pin assemblies and lattices of
>>> assemblies.  Performing this operation on actual mesh entities is
>>> trivial.  Properly handling metadata that comes with typical meshes
>>> is not.  However, these behaviors can be abstracted and specified in
>>> terms of our data model.  In the copy/move/merge case, I use the
>>> notion of "copy" and "expand" set types; "copy" sets having entities
>>> which get copied themselves get copied, and given the copies as
>>> contents.  For expand sets, the new entities get added to those.
>>> Criteria for determining whether a set is copy or expand can be
>>> specified by passing the sets themselves or tag types (and optionally
>>> values) which identify the sets.  Using this scheme, it's a very
>>> simple matter to have my service do "the right thing" with material
>>> sets (expand), neumann bcs (expand), geometric volumes (copy), parts
>>> (copy), reactor assemblies (copy), and lots of other things.  This is
>>> all without knowing the purpose of all these sets.
>> So this is an example of using a tag convention as a way to
>> communicate between an app and a service, with (as I understand it)
>> all the work at the iMesh level being standard.  If my understanding
>> is correct, this example would work with any compliant implementation
>> as a back end, so long as the app and service know about the same tag
>> convention.
> It's slightly easier than that: the convention is how the application
> recognizes things like material sets and neumann bcs; communication
> between the app and the copy/move service is in terms of data model
> characteristics, and does not rely on conventions.  This example will
> work with any compliant application; this hasn't been demonstrated, but
> would be useful to demonstrate.
>>> In summary: I don't believe it's possible to define the "right"
>>> behavior for sets under mesh modification at the mesh interface
>>> level, because the semantics of what the sets represent and how they
>>> behave can vary infinitely with the application.
>> That's true in general, but doesn't preclude the possibility of
>> certain common behaviors that are (at least) worth creating documented
>> tag conventions for, or more (since an implementation will have to be
>> tricksy to take advantage of a tag convention).
> Yes, modulo what "or more" means (e.g. changing the interface is right
> out).
>>>> The semantics that make the most sense to me, at least at first
>>>> glance, for modification are classification / reverse
>>>> classification, which I (as a service writer) would run through iRel
>>>> rather than looking at sets anyway.  And in any case, working on a
>>>> classification basis will necessarily trash other sets.
>>> There are examples where you'll want to do this without iRel too.
>>> For example, material types and boundary conditions.   This is the
>>> point where Mark will say that he requires geometry to track these
>>> too, but not the only way to do it. In fact, you can abstract this
>>> such that the application calling the adapt service can specify rules
>>> for modifying sets, without the adapt service needing to know the set
>>> semantics, while also preserving the ability to relate to the
>>> geometry subsequently.  That may not always be the right way to do
>>> it, but I think it can also be said that there are non-trivial cases
>>> where that is the right way to do things.
>> But doesn't this require the ability to go from entity to set, to
>> check whether the entities you're about to replace with a different
>> collection of entities are in the same set (material type for regions,
>> BC for bdry faces, etc), as well as some sort of tag convention to
>> specify that these sets matter and those don't?  The latter is pretty
>> easy, I suspect, but the former is not (interface functionality aside,
>> it costs either time or space to implement...).  I agree that, if the
>> modification app knows "replace only co-setted entities with entities
>> that you also put in that set" then you don't lose mesh set->geom
>> entity classification, or anything else you cared about with that set,
>> but the current interface is awkward for this, at best.
> In some cases, this does require going from entity to set with
> reasonable speed.  Whether this is easy or not depends on the
> implementation.  If the implementation is too slow doing it with the
> current interface, another option is to implement it as a service on top
> of the interface, with the application caching entity->set
> relationships.  If tag retrieval has "reasonable speed", this will no
> worse.  In either case, of course you will pay either memory or speed.
> You'll pay similarly with any type of observer pattern.
> Note that a key part of our interface that allows us to do this from the
> service level is limiting ourselves to only primitive create/delete
> operations on entities.  That is, entities don't get deleted under the
> interface w/o the application having requested it.  Though, if the app
> is a service, and there are other services depending on the mesh, then
> chaos ensues.  There are ways to handle this, though, too.
>>> Again, I think we need to think more abstractly here.  Classification
>>> and reverse classification are only one application of relations;
>>> even calling something "reverse" is specific to the semantics of how
>>> the mesh is generated and adapted.  Thinking of these things in terms
>>> of generic sets greatly reduces the number of operations you have to
>>> support to implement those semantics.
>> Maybe.  I'd have to think about this a lot more to be sure one way or
>> the other.  I suspect that some operations are really easy one way and
>> hard the other, and vice versa.
>>>> I stand by my statement.  The interaction of sets and tags with mesh
>>>> modification is something that I don't recall ever discussing,
>>> "ever" is a pretty strong statement.  I won't go trolling through old
>>> emails, as I'm sorely tempted to do here.  But, I can say that I had
>>> a hard enough time convincing people that sets were even needed or
>>> even useful, so we may not have spent much time on the deeper
>>> question about what to do with them under modification.
>> I did say I didn't recall it; that's my protection if you go digging.
>> ;-)  Certainly I missed the original set discussions.  But given that
>> we didn't get iterators right under modification without changing them
>> (at least?) once, it would be surprising if sets and tags are much
>> better.
> I'm not saying the interface will never need changing, just that the
> data model it's built on can support the things we're talking about, and
> support it efficiently.  That also doesn't mean it's easy to support
> efficiently on all types of implementations.
>>> and our
>>>> current interface provides no way for a service that does mesh
>>>> modification to correctly and efficiently handle sets that the
>>>> application that called it thinks are important (even if given
>>>> enough info to be correct, a service can't be efficient).
>>> At best, that statement is way stronger than it should be ("no way"?
>>> c'mon...).  First, you're arguing from the standpoint of a very
>>> specific kind of mesh modification.
>> True, but for the specific case of swapping, I can't even efficiently
>> identify (i.e., without querying all sets) which sets an entity
>> belongs to so that I can try to make the decision about what to do
>> with the new entities.  Hence, my statement, which I probably should
>> have qualified to say that it applies to at least some services,
>> though not all.
>> There may be an alternative way to implement swapping that doesn't
>> have this problem, but I can't see it offhand.  Iterating over
>> highest-dimensional entities in a set almost works, but you have to
>> know which of its second-adjacent highest-dimensional entities are
>> -also- in the set, which gets you back in trouble.  Plus, you examine
>> all the swap candidates twice in an iteration over the set.
> I think the way this needs to be done is to allow applications to tell
> you which sets they want the swapping service to update.  After that,
> the tracking is the cost of traversing the sets once, the storage of
> entity->set membership, and the cost of querying those relationships as
> you swap.  If your implementation already stores that information, then
> the query of sets an entity is in is likely efficient, and you don't
> need it.
> Actually, this begs another question: should we have the equivalent of
> an AdjacencyTable functionality, but for entities in sets?
>>>> The easiest fix is to document that the sets may be garbage on
>>>> return and caveat app.  Intermediate would be to ignore sets in mesh
>>>> modification, but to remove ents from sets if they get deleted
>>>> (otherwise you can't re-use that memory without potentially putting
>>>> an entity in the wrong set).
>>> We can't specify these types of rules at the interface spec level,
>>> because that will overconstrain some implementations and use cases.
>>> For maximum interoperability, one could implement the service to
>>> provide options for the application to select.  For example, an
>>> option for whether the service deletes entities from sets before
>>> deleting the entity itself, or not.  The first case would work better
>>> on an implementation that was minimal and efficient in time and space
>>> (e.g. MOAB under certain conditions).  The second would be better for
>>> implementations that already had a rich observer capability (e.g.
>>> GRUMMP, or MOAB under other conditions).
>>  From an interoperability point of view, having the -service- provide
>> options that cause it to interact differently with the implementation
>> is very different from having different implementations do things that
>> only they can do.  The former I have no issues with at all; the latter
>> is a slippery slope away from where I believe we should be.  (Yes, I
>> know, are an O(n) implementation and an O(n^2) implementation of the
>> same capability interoperable?  Good question.  I'm glad you asked
>> it.  Next question?)
> The slippery slope argument is a good one, and we should be careful
> about options in general.  Carl, I'm not sure you were around that
> early, but I did vehemently resist the notion of options early on in
> TSTT for things like identifying tags in tag get data functions (arguing
> in favor of tag handles instead).  Also, I think it should be understood
> that the options are recommendations only.
> The argument for options is that they give both implementations and
> applications flexibility.  In fact, why do we have options for load and
> save?  As another example, the notion of dense vs. sparse tags seems to
> be gaining momentum.  But, if we put that into the interface, I can bet
> that will put a burden on many implementations, and some implementations
> may not support it for a long time or ever (mesh shape interface,
> anybody?)  Using options gives them the option.
> One more note, I think we do need an additional error code, which is
> really a warning, about unhandled options.  That's already turned up as
> an issue in reactor simulation, where the application was passing an
> option wrongly, and never knew.
> - tim
>>> And c'mon, you made it that far in my message but passed up the
>>> chance to ridicule my obscure Vonnegut reference? :)
>> I'm not familiar with those particular Vonnegut pieces, and I couldn't
>> muster any nuanced ridicule by that time anyway. ;-)
>> Carl
More information about the tstt-interface mailing list
