Mesh set question
Carl Ollivier-Gooch
cfog at mech.ubc.ca
Thu Oct 29 01:26:21 CDT 2009
Tim Tautges wrote:
> Carl Ollivier-Gooch wrote:
>>> In this case I view the service as the application
>> That doesn't solve anything, though. Here's the problem: some
>> application creates a bunch of sets that mean something to it. Then
>> the application calls a swapping service that has no idea what those
>> sets mean, because the service is naturally meant to be application
>> independent. What should the swapping service do? It can't be wired
>> to understand AppXYZ's sets, because then it won't work on AppPQR's
>> sets, which mean something else. Should it ignore set membership,
>> forcing the app to rebuild all those sets after swapping? Swap only
>> highest-dimensional entities such that if entity A is in set Z, entity
>> B (and how ever many others) are also in set Z? Something else? And
>> how does the service do this with our current interface?
> One of the implications of what we're developing in itaps is that
> multiple services may be applied to a given data base, and those
> services may leave data and metadata around on the mesh. We all agree
> we should avoid the combinatorial problem of all services needing to
> code to all implementations' native interfaces (thus the common
> interface). Getting multiple services working on a database, though,
> also means that we can't require each service to understand the metadata
> potentially left there by other services. What we can do is provide a
> way for the application, which often knows about all the services it's
> calling, to specify the proper behavior when handling this metadata, in
> the language or data model used by the interfaces.
This I definitely agree with, to the extent that it's possible to -have-
proper behavior for the metadata. Some of that behavior is still going
to be expensive, though (example: entity handle tags are going to be
difficult or impossible for a service to update properly).
> For example... I've written a copy/move/merge mesh capability in
> MeshKit, to help mesh these large fuel pin assemblies and lattices of
> assemblies. Performing this operation on actual mesh entities is
> trivial. Properly handling metadata that comes with typical meshes is
> not. However, these behaviors can be abstracted and specified in terms
> of our data model. In the copy/move/merge case, I use the notion of
> "copy" and "expand" set types; "copy" sets having entities which get
> copied themselves get copied, and given the copies as contents. For
> expand sets, the new entities get added to those. Criteria for
> determining whether a set is copy or expand can be specified by passing
> the sets themselves or tag types (and optionally values) which identify
> the sets. Using this scheme, it's a very simple matter to have my
> service do "the right thing" with material sets (expand), neumann bcs
> (expand), geometric volumes (copy), parts (copy), reactor assemblies
> (copy), and lots of other things. This is all without knowing the
> purpose of all these sets.
So this is an example of using a tag convention as a way to communicate
between an app and a service, with (as I understand it) all the work at
the iMesh level being standard. If my understanding is correct, this
example would work with any compliant implementation as a back end, so
long as the app and service know about the same tag convention.
> In summary: I don't believe it's possible to define the "right" behavior
> for sets under mesh modification at the mesh interface level, because
> the semantics of what the sets represent and how they behave can vary
> infinitely with the application.
That's true in general, but doesn't preclude the possibility of certain
common behaviors that are (at least) worth creating documented tag
conventions for, or more (since an implementation will have to be
tricksy to take advantage of a tag convention).
>> The semantics that make the most sense to me, at least at first
>> glance, for modification are classification / reverse classification,
>> which I (as a service writer) would run through iRel rather than
>> looking at sets anyway. And in any case, working on a classification
>> basis will necessarily trash other sets.
> There are examples where you'll want to do this without iRel too. For
> example, material types and boundary conditions. This is the point
> where Mark will say that he requires geometry to track these too, but
> not the only way to do it. In fact, you can abstract this such that the
> application calling the adapt service can specify rules for modifying
> sets, without the adapt service needing to know the set semantics, while
> also preserving the ability to relate to the geometry subsequently.
> That may not always be the right way to do it, but I think it can also
> be said that there are non-trivial cases where that is the right way to
> do things.
But doesn't this require the ability to go from entity to set, to check
whether the entities you're about to replace with a different collection
of entities are in the same set (material type for regions, BC for bdry
faces, etc), as well as some sort of tag convention to specify that
these sets matter and those don't? The latter is pretty easy, I
suspect, but the former is not (interface functionality aside, it costs
either time or space to implement...). I agree that, if the
modification app knows "replace only co-setted entities with entities
that you also put in that set" then you don't lose mesh set->geom entity
classification, or anything else you cared about with that set, but the
current interface is awkward for this, at best.
> Again, I think we need to think more abstractly here. Classification
> and reverse classification are only one application of relations; even
> calling something "reverse" is specific to the semantics of how the mesh
> is generated and adapted. Thinking of these things in terms of generic
> sets greatly reduces the number of operations you have to support to
> implement those semantics.
Maybe. I'd have to think about this a lot more to be sure one way or
the other. I suspect that some operations are really easy one way and
hard the other, and vice versa.
>> I stand by my statement. The interaction of sets and tags with mesh
>> modification is something that I don't recall ever discussing,
> "ever" is a pretty strong statement. I won't go trolling through old
> emails, as I'm sorely tempted to do here. But, I can say that I had a
> hard enough time convincing people that sets were even needed or even
> useful, so we may not have spent much time on the deeper question about
> what to do with them under modification.
I did say I didn't recall it; that's my protection if you go digging.
;-) Certainly I missed the original set discussions. But given that we
didn't get iterators right under modification without changing them (at
least?) once, it would be surprising if sets and tags are much better.
> and our
>> current interface provides no way for a service that does mesh
>> modification to correctly and efficiently handle sets that the
>> application that called it thinks are important (even if given enough
>> info to be correct, a service can't be efficient).
> At best, that statement is way stronger than it should be ("no way"?
> c'mon...). First, you're arguing from the standpoint of a very specific
> kind of mesh modification.
True, but for the specific case of swapping, I can't even efficiently
identify (i.e., without querying all sets) which sets an entity belongs
to so that I can try to make the decision about what to do with the new
entities. Hence, my statement, which I probably should have qualified
to say that it applies to at least some services, though not all.
There may be an alternative way to implement swapping that doesn't have
this problem, but I can't see it offhand. Iterating over
highest-dimensional entities in a set almost works, but you have to know
which of its second-adjacent highest-dimensional entities are -also- in
the set, which gets you back in trouble. Plus, you examine all the swap
candidates twice in an iteration over the set.
>> The easiest fix is to document that the sets may be garbage on return
>> and caveat app. Intermediate would be to ignore sets in mesh
>> modification, but to remove ents from sets if they get deleted
>> (otherwise you can't re-use that memory without potentially putting an
>> entity in the wrong set).
> We can't specify these types of rules at the interface spec level,
> because that will overconstrain some implementations and use cases. For
> maximum interoperability, one could implement the service to provide
> options for the application to select. For example, an option for
> whether the service deletes entities from sets before deleting the
> entity itself, or not. The first case would work better on an
> implementation that was minimal and efficient in time and space (e.g.
> MOAB under certain conditions). The second would be better for
> implementations that already had a rich observer capability (e.g.
> GRUMMP, or MOAB under other conditions).
From an interoperability point of view, having the -service- provide
options that cause it to interact differently with the implementation is
very different from having different implementations do things that only
they can do. The former I have no issues with at all; the latter is a
slippery slope away from where I believe we should be. (Yes, I know,
are an O(n) implementation and an O(n^2) implementation of the same
capability interoperable? Good question. I'm glad you asked it. Next
question?)
> And c'mon, you made it that far in my message but passed up the chance
> to ridicule my obscure Vonnegut reference? :)
I'm not familiar with those particular Vonnegut pieces, and I couldn't
muster any nuanced ridicule by that time anyway. ;-)
Carl
Dr. Carl Ollivier-Gooch, P.Eng. Voice: +1-604-822-1854
Associate Professor Fax: +1-604-822-2403
Department of Mechanical Engineering email: cfog at mech.ubc.ca
University of British Columbia http://www.mech.ubc.ca/~cfog
Vancouver, BC V6T 1Z4 http://tetra.mech.ubc.ca/ANSLab/
More information about the tstt-interface
