[Swift-user] Remote SGE cluster
Igor Russo igor.souza.russo at gmail.com
Fri May 1 14:29:42 CDT 2015
Hi Yadu,
Thank you very much!
I changed the config file with the data from my cluster.
When executing the 4th part of Swift-tutorial, i'm getting the following
error:
"Failed to download bootstrap jar from ..."
RunID: run031
Progress: Sex, 01 Mai 2015 15:40:42-0300
Progress: Sex, 01 Mai 2015 15:40:43-0300  Submitting:1
Execution failed:
Exception in sort:
    Arguments: [-n, unsorted.txt]
    Host: mmc
    Directory: p4-run031/jobs/s/sort-go28d68m
exception @ swift-int-staging.k, line: 165
Caused by:
exception @ swift-int-staging.k, line: 160
Caused by: null
Caused by:
org.globus.cog.abstraction.impl.common.task.TaskSubmissionException: Could
not submit job
Caused by:
not start coaster service
Caused by:
org.globus.cog.abstraction.impl.common.task.TaskSubmissionException: Task
ended before registration was received.
Failed to download bootstrap jar from http://igor-ubuntu:51251
k:assign @ swift.k, line: 174
Caused by: Exception in sort:
    Host: mmc
Caused by:
Caused by: null
Caused by:
not submit job
Caused by:
Caused by:
Igor
2015-05-01 13:47 GMT-03:00 Yadu Nand Babuji <yadunand at uchicago.edu>:
>  Hi Igor,
> Swift does support SGE clusters, and you can refer to the swift-tutorial
> for sample code and configurations from this link:
> https://github.com/swift-lang/swift-tutorial
> Here's a sample config from our test-suite for Godzilla, an SGE cluster at
> UChicago:
> https://github.com/swift-lang/swift-k/blob/master/tests/sites/godzilla/swift.conf
> You could modify and add this config to the swift.conf file in the
> swift-tutorial to run
> Swift on any machine and execute on a remote SGE cluster.
> SGE is a widely used resource manager and most sites have differences in
> their setups that make each site unique. If you run into issues with the
> default
> swift package, and could provide help in figuring out specifics of your
> cluster, we
> will help you adapt the Swift SGE provider to support your cluster.
> Thanks,
> Yadu
> On 04/28/2015 05:09 PM, Igor Russo wrote:
> Hi All,
>  It is possible to use Swift with a remote SGE/OGE cluster?
>  Regards,
> Igor
> Swift-user mailing listSwift-user at ci.uchicago.eduhttps://lists.ci.uchicago.edu/cgi-bin/mailman/listinfo/swift-user
URL: <http://lists.mcs.anl.gov/pipermail/swift-user/attachments/20150501/0c5b7120/attachment.html>
More information about the Swift-user mailing list
