[Swift-user] Remote SGE cluster
Yadu Nand Babuji
yadunand at uchicago.edu
Fri May 1 11:47:13 CDT 2015
Hi Igor,
Swift does support SGE clusters, and you can refer to the swift-tutorial
for sample code and configurations from this link:
https://github.com/swift-lang/swift-tutorial
Here's a sample config from our test-suite for Godzilla, an SGE cluster
at UChicago:
https://github.com/swift-lang/swift-k/blob/master/tests/sites/godzilla/swift.conf
You could modify and add this config to the swift.conf file in the
swift-tutorial to run
Swift on any machine and execute on a remote SGE cluster.
SGE is a widely used resource manager and most sites have differences in
their setups that make each site unique. If you run into issues with the
default
swift package, and could provide help in figuring out specifics of your
cluster, we
will help you adapt the Swift SGE provider to support your cluster.
Yadu
On 04/28/2015 05:09 PM, Igor Russo wrote:
> Hi All,
> It is possible to use Swift with a remote SGE/OGE cluster?
> Regards,
> Igor
> Swift-user mailing list
> Swift-user at ci.uchicago.edu
> https://lists.ci.uchicago.edu/cgi-bin/mailman/listinfo/swift-user
URL: <http://lists.mcs.anl.gov/pipermail/swift-user/attachments/20150501/e186c8f1/attachment.html>
More information about the Swift-user
