[Swift-user] File header does not match type
Yadu Nand Babuji yadunand at uchicago.edu
Thu Mar 5 11:13:50 CST 2015
Update: As Mike pointed out, this was indeed an error from a mismatch
between
the file header readData( ) was reading and the target struct.
-Yadu
On 03/03/2015 12:24 PM, Michael Wilde wrote:
> Jason,
> This sounds like an error from readData( ).  Do you have a readData
> statement that's reading a file into a structure of four fields, but is
> only finding 2 fields on the header line.
> Its remotely possible that a ext_mapper could give a similar error.
> Does that help narrow it down?
> - Mike
> On 3/3/15 12:17 PM, Jason James Pitt wrote:
>> Hi All,
>> I was hoping someone could help shed some light on an issue I'm having running a Swift script (with Swift 0.95-RC6). When running my code I get the following failure (execution stops immediately after).
>> Progress: Fri, 27 Feb 2015 04:59:20-0600
>> Execution failed:
>> File header does not match type. Expected 4 whitespace separated items. Got 2 instead.
>> I've been comparing this swift script and the configurations files to other swift scripts that have run successfully. I can't seem to identify the problem. Is the above a general failer for all kinds of swift configuration files? Perhaps there is a specific file I should be looking at ?
>> Thanks, and I'd be grateful for any insight.
>> Jason
>> Swift-user mailing list
>> Swift-user at ci.uchicago.edu
>> https://lists.ci.uchicago.edu/cgi-bin/mailman/listinfo/swift-user
More information about the Swift-user mailing list
